MV44X Installation Guide
This is a comprehensive guide for the MV44X camera, detailing its overview, power requirements, dashboard setup, and step-by-step installation instructions.
MV44X Overview
The Cisco Meraki MV44X is a dual-imager smart camera that is exceptionally simple to deploy and configure due to its integration into the Meraki dashboard and cloud-augmented edge storage. The MV Smart Camera family eliminates complex and expensive servers and video recorders required by traditional solutions, removing the limitations typically placed on video surveillance deployments.
Image showing the Cisco Meraki MV84X, a smart camera designed for easy deployment and configuration with the Meraki Dashboard and cloud-augmented edge storage, eliminating the need for traditional video surveillance equipment like complex servers and video recorders.
What’s In the Box?
The following items are included with the MV44X.
Verify that all contents are present before beginning installation.
Item Specification Quantity
Camera
MV44X 1
Camera Ceiling Base Plate*
- 1
Weather Shield*
- 1
Installation Template
- 1
Weather Shield Fastening Screw
M3*0.5*8 2
Conduit Adapter Screw
M2.5*0.45*4 2
Mount Plate Security Screw M6*0.5*11.2  1
Mounting Screws φ4*1.58*30 4
Wall Anchors
  4
Dessicant Pack
- 1
Rubber Gasket (additional) 6.3 - 8.3 mm  1
Screwdriver
Secure T10 Torx 1
Cable Connector
RJ45 cable puller 1
Powering the MV44X Camera
The MV44X features a 1000BASE-TX Ethernet port and requires PoE+ 802.3at for operation. Route the Ethernet cable from an active port on a PoE+ switch or injector.
  • Power over Ethernet supports a maximum cable length of 328 ft (100 m).
Pre-Install Preparation
You must complete the following steps before going on-site to perform an installation.
Configure Your Network in the Dashboard
The following is a brief overview of the steps required to add an MV44X camera to your network. For detailed instructions about creating, configuring and managing the Meraki Camera networks, refer to the MV - Smart Cameras documentation.
  • Login to http://dashboard.meraki.com. If this is your first time, create a new account.
  • Find the network to which you plan to add your cameras or create a new network.
  • Add your cameras to your network. You will need your Meraki order number (found on your invoice) or the serial number of each camera, which looks like Qxxx-xxxx-xxxx and is found on the unit label.
  • Verify that the camera is now listed under Cameras > Monitor > Cameras.
Check and Configure Firewall Settings
If a firewall is in place, it must allow outgoing connections on particular ports to IP addresses. The most current list of outbound ports and IP addresses for your organization can be found under Help > Firewall Info on the dashboard.
DNS Configuration Best Practices for LAN Streaming
Each camera will generate a unique domain name for secured direct streaming functionality. These domain names resolve an A record for the private IP address of the camera. Any public recursive DNS server will resolve this domain.
If utilizing an on-site DNS server, please allow *.devices.meraki.direct or configure a conditional forwarder so that local domains are not appended to *.devices.meraki.direct and that these domain requests are forwarded to Google public DNS.
Assigning IP Addresses
Currently, the MV44X camera does not support static IP assignment. MV44X units must be added to a subnet that uses DHCP and has a pool of available DHCP addresses to operate correctly.
Installation Instructions
Step 1: Loosen the Dome Housing Screws
  • Using the provided security-bit screwdriver, locate the six (6) perimeter screws around the MV44X dome housing.
    • Loosen each screw to about 50%—AVOID removing them completely. This will allow the lifting or removal of the dome cover without losing the screws.
  • Ensure the screws remain securely in their slots so they don’t fall out during the following steps.
Step 2: Lift the Dome Housing
  • After partially loosening the six perimeter screws in Step 1, gently lift the cover away from the rest of the housing
Tip: If the dome doesn’t move freely, ensure each screw is loosened enough to allow rotation, but not too loose that it detaches from the base.
Step 3: Replace the Desiccant Packet
  • The MV44X ships with a pre-installed desiccant pack to ensure the camera is moisture-free during transit and installation, this pack must be removed and replaced with a fresh desiccant pack provided in the box.
  • Remove the desiccant pack and identify the designated spots inside the camera assembly where the desiccant packet should be placed.
  • Find the new desiccant pack and remove it from its silver-colored protective pouch.
Important: Avoid touching sensitive components inside the camera. Smudges or debris on the lenses can impact video quality.
Step 4: Unlatch and Lift the Camera Base
Image illustrating the steps to unlock and rotate the Camera Base of the MV84X camera.
  • On the camera base plate, you’ll see two latches on either side of the camera lens, lift the latches to the upright position to unlock the camera from the base plate.
Step 5: Detach the Mounting Plate
Image showing the process of detaching the Mounting Plate from the MV84X camera.
  • After completing the previous unlatch/lift step (Step 4), separate the mounting plate away from the amin camera assembly
  • Place the mounting plate aside safely
Step 6: Remove and Discard Pull Tab
  • Remove pull tab and discard
Step 7: Mounting Plate Instructions
Image showing how to mount the plate and route the cable for the MV84X camera installation.Lasso Mount Step 2@4x.png
  • Mount the small base plate onto the wall surface using the paper template provided
  • Feed the cable
    • Pull the cable through the hole, lining it up with the center opening of the mounting plate.
    • Confirm that you have enough slack on the camera side to attach or adjust the cable later.
  • Use 3x screws to fix the base plate to the wall
  • The MV44 Series cameras have a button to engage the locking mechanism. Press the button while aligning the camera to the small base plate.
  • Twist the camera while holding the button until a click is heard.
  • The camera is locked onto the plate and secured.
  • Secure base plate with final screw
Step 8: Remove Gasket and Thread Ethernet Cable
Image illustrating the positioning of the camera body during the MV84X camera setup.
  • Remove plug from camera body and dispose of the rubber gasket from the RJ45 seal.
  • Once the gasket has been removed insert the RJ45 cable puller.
  • Grab the remaining hanging Ethernet cable from step 7 and attach to the cable puller.
    • Insert Ethernet cable into the cable puller till a click is heard
  • Pull the Ethernet cable through the RJ45 seal
  • Remove cable from cable puller.
Step 9: Power On and Verify Network Connection
Image demonstrating how to reattach the Camera Assembly during the MV84X camera installation.
  • Align the RJ45 connector with the camera’s Ethernet port.
    • Push it in firmly until you hear or feel the latch click into place.
  • Ensure the power source is PoE+ (802.3at).
  • Look for an LED indicator to confirm the camera is powered.
  • Wait for the camera to show online on the Meraki dashboard and ensure the video feed is viewable.
Step 10: Reattach the Camera Assembly
mage showing the process of reassembling the Cable Gland in the MV84X camera setup.
  • Gently lift the camera assembly towards the mounting plate.
  • Push down the latches on either side of the lens to lock the mounting plate to the camera assembly.
  • Ensure the plate and camera assembly sit flush against each other and against the ceiling
Step 11: Adjust the Camera Angle and Orientation
Image illustrating the steps to power on the MV84X camera and verify its network connection.
  • Once the live view is available, the lenses can now be correctly aimed as needed by following these steps:
    • Move the camera imager vertically to capture more ceiling or floor as needed
    • Rotate the lens horizontally on the 360 track to aim the lenses at the areas of interest.
    • Adjust the lens assembly to straighten the image if the scene appears tilted.
    • Use the Meraki dashboard to Optical Zoom each imager if needed, if you want a narrower field of view.
  • Use the Meraki dashboard to verify the camera’s angle is correct.
  • Make fine-tune adjustments until you have the optimal field of view
After the camera is online for a few minutes, it will begin a firmware upgrade sequence. If this occurs during aiming, wait a few minutes for the video feed to appear after the firmware upgrade.
Step 12: Adjust the Camera Angle and Orientation
Image depicting the replacement of desiccant packets in the MV84X camera assembly.
  • Hold the dome cover (the large outer shell) and position it so the alignment markers match up with the camera assembly.
  • You will see small arrows on the dome and camera base indicating the correct orientation.
  • Ensure the dome edges are flush with the camera’s base, no gaps should be visible.
  • Identify the six (6) perimeter screws around the dome cover (the same ones loosened in earlier steps).
  • Using the provided screwdriver, turn each screw clockwise until it’s snug.
  • Tighten them in a star or alternating pattern to ensure even pressure (e.g., top-left, then bottom-right, etc.). Avoid Over-Torquing.
  • Stop once you feel moderate resistance as over-tightening can strip threads.
  • Once fully tightened, the dome should be firmly in place, with no visible gaps.
Step 13: Attach Weather Shield
  • Hold the weather shield parallel to the camera, orienting it so the grooves align with the screw holes.
  • Slide or push the shield onto the dome until is sits flush on the camera housing.
  • If it doesn’t sit evenly, remove and realign.
Tip: The shield directs infrared light correctly at night, and proper installation reduces glare or reflections on the dome.
MV44X LED Status Indicator
Your MV44X is equipped with an LED light on the front of the unit to convey system functionality and performance information.
The following colours and patterns indicate the various status conditions of an MV:
  • Rainbow (solid, rotating through colours) - MV is booting up.
  • Flashing Green - MV is upgrading or initializing for the first time.
  • Solid Green - MV is connected via Ethernet.
  • Solid Amber - MV is not able to connect to the Dashboard.
  • Was this article helpful?
