Cisco Meraki
MG51 Internal Antenna Datasheet
MG51 also has a GPS antenna but the GPS functionality is not supported yet.
The internal antenna on the MG51 are enclosed inside for a sleek look while maintaining excellent performance. When in use the internal antenna has a bias towards the front face. The dipole shape of coverage the antennas generally excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. A benefit of the internal antenna is the smaller footprint where it will be mounted. Internally, the MG51 has 2 main and 2 diversity antennas.
Specifications
Category Specifications
Electrical
Antenna Type
Planar Inverted F Antenna (PIFA)
Main 0 Antenna
Frequency Range
  • 860 (617 - 960) MHz
  • 1452 (1452 - 1496) MHz
  • 2100 (1710 - 2200) MHz
  • 2600 (2300 - 2700) MHz
  • 4050 (3300 - 4200) MHz
  • 4750 (4400 - 5000) MHz
  • 5950 (5150 - 5925) MHz
Peak Gain (per range)
  • 860 @ 2.87dBi
  • 1452 @ 4.04dBi
  • 2100 @ 3.98dBi
  • 2600 @ 4.97dBi
  • 4050 @ 2.26dBi
  • 4750 @ 2.91dBi
  • 5925 @ 5.0dBi
Polarization
Linear, vertical
Main 1 Antenna
Frequency Range
  • 1475 (1452 - 1496) MHz
  • 2200 (1710 - 2200) MHz
  • 2550 (2300 - 2700) MHz
  • 4200 (3300 - 4200) MHz
  • 4400 (4400 - 5000) MHz
  • 5300 (5150 - 5925) MHz
  • 1475 @ 0.86dBi
  • 2200 @ 4.40dBi
  • 2550 @ 4.97dBi
  • 4200 @ 2.37dBi
  • 4400 @ 2.64dBi
  • 5300 @ 3.13dBi
Polarization
Linear, vertical
Div 0 Antenna
Frequency Range
  • 920 (617 - 960) MHz
  • 1496 (1452 - 1496) MHz
  • 1800 (1710 - 2200) MHz
  • 4150 (3300 - 4200) MHz
  • 4800 (4400 - 5000) MHz
  • 5250 (5150 - 5925) MHz
  • 920 @ 3.43dBi
  • 1496 @ 2.39dBi
  • 1800 @ 4.40dBi
  • 2550 @ 4.93dBi
  • 4150 @ 2.22dBi
  • 4800 @ 3.42dBi
  • 5250 @4.14dBi
Polarization
Linear, vertical
Div 1 Antenna
Frequency Range
  • 2500 (2300 - 2700) MHz
  • 3950 (3300 - 4200) MHz
  • 5400 (5150 - 5925) MHz
  • 1496 @ 1.91dBi
  • 1800 @ 3.69dBi
  • 2500 @ 4.67dBi
  • 3950 @ 2.49dBi
  • 4750 @ 3.47dBi
  • 5400 @ 4.43dBi
Polarization
Linear, vertical
Physical and Environmental
MG51 Dimensions
173 x 173 x 36.5mm
MG51 Operating Temperature
-40°C to 50°C (-40°F to 122°F)
Material of Radiator
Sheet metal
Regulatory Certified for use in the MG51
Radiation Patterns
Div 0 Antenna
clipboard_e4a530d1d342502856875da8bc1655683.pngclipboard_e139565de4c179b1149d4f4d51b43c7f7.png
Main 0 Antenna
Div 1 Antenna
Main 1 Antenna
  • Was this article helpful?
