MG41E and MG51E Cellular Patch Antenna Datasheet
image_product_ma-ant-c1-b--front--w-shadow(2).pngimage_product_ma-ant-c1-b--front--w-shadow(2).png
The Cellular Patch Antenna (MA-ANT-DUAL-C1) is ideal for situations that require higher directional gain towards a cellular tower. When mounted high up on a pole for a clearer line of site toward a cellular tower, the MG cellular gateway will have higher signal quality and power. The patch antenna can be used to help increase signal strength if the dipole antennas are not giving you a signal quality you need. This antenna can help boost coverage due to its unique cone shape coverage pattern when pointed towards the correct cellular tower for your preferred carrier.
Specifications
Category Specifications
Ordering Information
MA-ANT-DUAL-C1 (Please use this SKU name when ordering patch antenna set)
MA-ANT-DUAL-C1 is a combination of 2 individual SKUs (patch sets) - MA-ANT-C1-B3, MA-ANT-C1-B4
Electrical
Antenna Type: Narrow Patch
Frequency Range:
  • 960 (617 - 960) MHz
  • 2170 (1710 - 2170) MHz
  • 2690 (2200 - 2690) MHz
  • 4100 (3300 - 4100) MHz
  • 5925 (4400 - 5925) MHz
Peak Gain (per range)
  • 960 @ 5.7dBi
  • 2170 @ 7.7dBi
  • 2690 @ 9.7dBi
  • 4100 @  6.6dBi
  • 5925 @ 6.3dBi
Polarization:  Linear, Horizontally (left) and Vertically (right)
Beamwidth (horizontal): 60°
Beamwidth (vertical): 60°
Cables Length: 90cm
Mounting Mounts to walls and poles
Physical and Environmental
Dimensions: 220mm x 220mm x 48mm
Weight: 595g
Material: PC, UV Resistance
Temperature: -40°C  to +85°C (-40°F to 185°F)
Humidity: 95% at 55°C (131°F)
Connector: RP-SMA
Warranty 1 year hardware warranty included
Ordering Information MA-ANT-C1-B3 (works only with MG41E and MG51E)
Regulatory Certified for use with the MG41E and MG51E: MA-ANT-C1-B3
Electrical
Frequency Range:
  • 2170 @ 7.7dBi
  • 2690 @ 7.8dBi
  • 4100 @  8.4dBi
  • 5925 @ 6.1dBi
Cables Length: 90cm
Weight: 680g
Connector: RP-SMA
Ordering Information MA-ANT-C1-B4 (works only with MG41E and MG51E)
Regulatory Certified for use with the MG41E and MG51E: MA-ANT-C1-B4
The mounting hardware bracket is included with the patch antenna. No other accessories are required to mount.
Install Guide
Below are the step-by-step instructions.
Radiation Patterns
P/N: MA-ANT-C1-B3
P/N: MA-ANT-C1-B4
  • Was this article helpful?
