MG41/41E Technical Specifications
By Unni Rajagopalan
Overview
Connectivity is critical for any organization that depends on reliable internet access in order to function. Wireless WAN connectivity options, such as cellular networks, serve as a reliable backup internet uplink in the event of a primary uplink failure.
The MG41 cellular gateway simplifies the path to wireless WAN connectivity and makes cellular a viable uplink option for many networks. The MG41 acts as a gateway to the internet cellular networks by converting LTE signal from a cellular provider to an Ethernet handoff, which can be used as an internet uplink for a variety of use-cases.
MG41 can work with any routing or switching device, Meraki or non-Meraki. With additional 802.3af compatibility, the MG can be placed anywhere and powered via power over ethernet (PoE) like any access point. This gives users the option for optimal physical placement for signal quality  - a cornerstone for wireless WAN communications.
MG41E deviceMG41 device
MG series and Meraki Cloud Management: A Powerful Combo
All Meraki devices are managed via the Meraki cloud, with an intuitive browser-based interface. The MG series are self-configuring and managed over the web, and  can be rapidly deployed at remote locations without any assistance from end-users.
Meraki Cloud services monitor all devices 24x7 and deliver real-time alerts if any devices encounter a problem. Remote diagnostics tools enable real-time troubleshooting through any web browser. New features and enhancements are delivered seamlessly over the web, so you never have to manually download software updates or worry about missing critical security vulnerability patches.
Features
  • Highlights
    • Built in CAT18 connectivity
    • Dual SIM support
    • Supports 2 separate downstream router connections
    • Small form factor
    • PoE or DC powered
    • IP67 rating
    • Optional Patch antenna
    Management
    • Manageability from the Cisco Meraki dashboard
    • Self-configuring Cellular Gateway
    • Automatic firmware upgrades with scheduling control
    • Extensive API support
    Remote Diagnostics
    • Email, SMS and Mobile push notification alerts
    • Ping, traceroute, cable testing, and link failure detection with alerting
    • Remote packet capture
    • Combined event and configuration change logs with instant search
    • DM logging via local status page
The MG41 cellular gateway uses 6 to 8 megabytes a day of data for telemetry on dashboard and connection monitoring when the unit is idle. Any additional Cisco Meraki devices that are added to the MG41 may increase data usage further. Cisco Meraki products are cloud connected devices that report telemetry into Dashboard for network monitoring purposes. The usage will be reduced in future firmware updates.
Use Cases
Note that the following use-cases refer to using a Meraki MX appliance with the MG41 as a WAN uplink. However, the use-cases can also apply to non-Meraki devices.
  • Antenna placement where cellular coverage is best
    • Signal strength is key for cellular performance. The MG41 makes cellular a viable option in situations where the best location for the MX is not necessarily the best location  for a strong cellular signal. The separation of cellular antenna and MX expands cellular options for all networks, particularly for mid-range MXs mounted in a data center. The 4 x 4 DL MIMO is capable of supporting deployments that demands higher throughput capacity.
  • Primary WAN
    • In areas where wired internet services are not available, the MG41 provides a simple, viable option for wireless WAN connectivity.
  • Secondary WAN for Failover
    • An MX's secondary WAN interface connected to an MG41 may use the cellular network in the event of a primary uplink failure.
  • Secondary WAN for SD-WAN
    • An MX with an MG41 as a secondary WAN uplink may use the cellular network to establish VPNs for SD-WAN.
  • High Availability Uplink
    • The MG41 can be used as either a primary or secondary internet uplink for MX HA topologies. Its two LAN ports allow the MXs to share access to the same cellular network.
Technical Breakdown
Physical Specifications
Models  MG41 MG41E
Dimensions (w x d x h) 168 x 168 x 35mm 168 x 168 x 35mm
Weight (without accessories) 670g 670g
Power Supply 12V/1A, 48-57V DC/0.35A 12V/1A, 48-57V DC/0.35A
Power Load 10 Watt Maximum (PoE 802.3AF) 10 Watt Maximum (PoE 802.3AF)
Operating Temperature -22°F to 122°F (-30°C to 50°C) -22°F to 122°F (-30°C to 50°C)
Humidity 5% to 95% non-condensing 5% to 95% non-condensing
Storage and Transportation Temperature
-22°F - 158°F
-30°C - 70°C
-22°F - 158°F
-30°C - 70°C
Product Category CAT18 CAT18
Maximum Wireless Data Rate (Down/Up) 1.2 Gbps / 150 Mbps 1.2 Gbps / 150 Mbps
Antennas Internal Dipole, optional patch antenna
LAN Interfaces - Dedicated 1x Dedicated GbE RJ45 1x Dedicated GbE RJ45
LAN Interfaces - Convertible 1x Convertible LAN/WAN GbE RJ45 1x Convertible LAN/WAN GbE RJ45
SIM Slots 2 2
Physical Specifications (MG41 vs MG21)
Models  MG21/E MG41/E
Dimensions (w x d x h) 160.45 x 160.45 x 34.45mm 168 x 168 x 35mm
Weight (without accessories) 489/497g 670g
PoE Ports 1 2
External Antennas 2 4
Patch Antennas 1 2
Product Category CAT6 CAT18
Maximum Wireless Data Rate (Down/Up) 300 Mbps / 50 Mbps 1.2 Gbps / 150 Mbps
SIM Slots 1 2
Carrier Aggregation DL - 2CA DL - 5CA, UL - 2CA
Feature Specifications (MG41 vs MG21)
Auto SIM failover No Yes
Dual SIM Info No Yes
Custom APN configuration via dashboard No Yes
Carrier Aggregation info on dashboard No Yes
Troubleshooting tools (DM logging) on local status page No Yes
SIM switch via Dashboard/Local status page No Yes
Band 66, 71 No Yes
Private LTE (CBRS) No Yes
FirstNet band 14 No Yes
Interfaces
LAN Interfaces 2x GbE
WAN Interfaces 1 * CAT 18 Cellular modem
SIM Card Slot Nano (4FF)
Cellular
MG41-HW & MG41E-HW
LTE bands
B1 (2100)
B2 (1900)
B3 (1800)
B4 (1700)
B5 (850)
B7 (2600)
B8 (900)
B12 (700ac)
B13 (700c)
B14 (700PS)
B17 (700b)
B18 (800)
B19 (800)
B20 (800DD)
B25 (1900)
B42 (TDD 3500)
B38 (TDD 2600)
B40 (TDD 2300)
B43 (TDD 3600)
B26 (US 850 Ext)
B28 (700 APAC)
B29 (US 700de Lower)
B39 (TDD 1900)
B41 (TDD 2500)
B30 (2300 WCS)
B66 (AWS-3)
B32 (1500)
B46 (TDD 5200)
B48 (3600)
B71 (600)
UMTS bands
B1 (2100)
B2 (1900)
B8 (900)
B4 (AWS)
B5 (850)
B9 (1700)
B19 (800)
LTE Category
CAT 18 LTE-A PRO
Certifications
PTCRB (US), RCM (ANZ, APAC), GCF (EU)
Certified Carriers AT&T (US), Verizon Wireless (US), T-Mobile (US), Optus (AU), Telstra (AU), Bell (CA), Telus (CA), Vodafone (NZ), DoCoMo (Japan)
Carriers leveraging GCF https://www.globalcertificationforum...f-members.html
Carriers pending certification Spark (NZ)
Beta Tested Carriers
AT&T (United States), Verizon (United States),  Rogers (Canada), Telus (Canada), Bell (Canada), Deutsche Telekom (Germany), Sunrise (Switzerland), Vodafone (NZ, UK, Germany, Ireland), Telstra (Australia), Optus (Australia),  NTT docomo (Japan), KDDI (Japan)
Carrier Aggregation
Global Carriers
2CA
CA_1A-3A, CA_1A-5A, CA_1A-7A, CA_1A-8A, CA_1A-18A, CA_1A-
19A, CA_1A-20A, CA_1A-26A, CA_1A-28A, CA_1A-32A, CA_1A-38A,
CA_1A-40A, CA_1A-41A, CA_1A-42A, CA_[2A]-[4A], CA_[2A]-5A,
CA_[2A]-7A, CA_[2A]-12A, CA_[2A]-28A, CA_[2A]-46A, CA_[2A]-48A,
CA_[2A]-[66A], CA_[2A]-71A, CA_3A-5A, CA_3A-7A, CA_3A-8A,
CA_3A-19A, CA_3A-20A, CA_3A-26A, CA_3A-28A, CA_3A-32A,
CA_3A-38A, CA_3A-40A, CA_3A-42A, CA_[4A]-5A, CA_4A-7A,
CA_[4A]-12A, CA_[4A]-28A, CA_[4A]-46A, CA_5A-7A, CA_7A-8A,
CA_7A-12A, CA_7A-20A, CA_7A-28A, CA_7A-42A, CA_8A-38A,
CA_8A-40A, CA_8A-42A, CA_12A-[66A], CA_20A-32A, CA_20A-38A,
CA_20A-40A, CA_20A-42A, CA_26A-[41A], CA_28A-40A, CA_28A-
42A, CA_39A-41A, CA_40A-42A, CA_46A-[66A], CA_48A-[66A],
CA_[66A]-71A, CA_1A-1A, CA_[2A]-[2A], CA_3A-3A, CA_[4A]-[4A],
CA_7A-7A, CA_40A-40A, CA_42A-42A, CA_48A-48A, CA_[66A]-[66A], CA_[2C], CA_3C, CA_7B, CA_7C, CA_8B, CA_12B, CA_38C,
CA_39C, CA_40C, CA_[41C], CA_42C, CA_48C, CA_[66B],
CA_[66C]
3CA
CA_1A-1A-3A, CA_1A-3A-3A, CA_1A-3A-7A, CA_1A-3A-8A, CA_1A-
3A-19A, CA_1A-3A-20A, CA_1A-3A-28A, CA_1A-3A-32A, CA_1A-3A-
38A, CA_1A-3A-40A, CA_1A-3A-41A, CA_1A-3A-42A, CA_1A-3C,
CA_1A-7A-7A, CA_1A-7A-8A, CA_1A-7A-20A, CA_1A-7A-28A,
CA_1A-7A-42A, CA_1A-7C, CA_1A-8A-40A, CA_1A-20A-32A,
CA_1A-20A-42A, CA_1A-28A-42A, CA_1A-40C, CA_1A-41C, CA_1A-
42C, CA_1A-46C, CA_1C-3A, CA_[2A]-2A-12A, CA_2A-[2A]-12A,
CA_[2A]-2A-66A, CA_2A-[2A]-66A, CA_2A-2A-[66A], CA_[2A]-2A-
71A, CA_2A-[2A]-71A, CA_[2A]-4A-4A, CA_2A-[4A]-4AC, CA_2A-4A-
[4A], CA_[2A]-4A-5A, CA_2A-[4A]-5A, CA_[2A]-4A-12A, CA_2A-[4A]-
12A, CA_[2A]-4A-29A, CA_2A-[4A]-29A, CA_[2A]-4A-71A, CA_2A-
[4A]-71A, CA_2A-7A-12A, CA_[2A]-12A-66A, CA_2A-12A-[66A],
CA_[2A]-12B, CA_[2A]-46A-46A, CA_[2A]-46A-66A, CA_2A-46A-
[66A], CA_[2A]-46C, CA_[2A]-48A-48A, CA_[2A]-48C, CA_[2A]-48A-
66A, CA_2A-48A-[66A], CA_[2A]-66A-66A, CA_2A-[66A]-66A,
CA_2A-66A-[66A], CA_[2A]-66A-71A, CA_2A-[66A]-71A, CA_[2A]-
[66C], CA_[2A]-66C, CA_2A-[66C], CA_3A-3A-7A, CA_3A-3A-8A,
CA_3A-3A-20A, CA_3A-3A-28A, CA_3C-5A, CA_3A-7A-7A, CA_3A-
7A-8A, CA_3A-7A-20A, CA_3A-7A-28A, CA_3A-7A-42A, CA_3A-7B,
CA_3A-7C, CA_3C-7A, CA_3A-8A-38A, CA_3A-8A-40A, CA_3C-8A,
CA_3A-20A-32A, CA_3A-20A-42A, CA_3A-28A-40A, CA_3A-28A-
42A, CA_3C-20A, CA_3C-28A, CA_3A-40A-40A, CA_3A-40C,
CA_3A-42A-42A, CA_3A-42C, CA_3A-46C, CA_3C-32A, CA_3C-38A,
CA_3C-40A, CA_4A-4A-7A, CA_[4A]-4A-12A, CA_4A-[4A]-12A,
CA_[4A]-4A-71A, CA_4A-[4A]-71A, CA_4A-7A-12A, CA_[4A]-12B,
CA_[4A]-46A-46A, CA_[4A]-46C, CA_7A-7A-8A, CA_7A-20A-42A,
CA_7C-20A, CA_7B-28A, CA_7C-28A, CA_7A-46C, CA_8A-40C,
CA_8A-42C, CA_12A-[66A]-66A, CA_12A-66A-[66A], CA_12A-[66C],
CA_19A-42C, CA_20A-38C, CA_28A-40C, CA_28A-42C, CA_40A-
40C, CA_40D, CA_40A-42C, CA_40C-42A, CA_42A-42C, CA_42D,
CA_46C-[66A], CA_48A-48C, CA_48D, CA_48A-48A-[66A], CA_48C-
[66A], CA_[66A]-66A-71A, CA_66A-[66A]-71A
4CA
CA_1A-1A-3A-28A, CA_1A-3A-3A-28A, CA_1A-3A-7A-7A, CA_1A-
3A-7C, CA_1A-3A-7A-8A, CA_1A-3A-7A-20A, CA_1A-3A-7A-28A,
CA_1A-3A-8A-40A, CA_1A-3A-3A-8A, CA_1A-3A-40C, CA_1A-3A-
42C, CA_1A-3C-5A, CA_1A-3C-7A, CA_1A-3C-8A, CA_1A-3C-28A,
CA_1A-7C-28A, CA_1A-42D, CA_1A-46D, CA_2A-2A-12A-66A,
CA_2A-2A-66A-66A, CA_2A-2A-66A-71A, CA_[2A]-2A-66C, CA_2A-
[2A]-66C, CA_2A-2A-[66C], CA_2A-4A-7A-12A, CA_2A-12A-66A-
66A, CA_2A-46A-46A-66A, CA_[2A]-46A-46C, CA_[2A]-46C-66A,
CA_2A-46C-[66A], CA_[2A]-46D, CA_[2C]-66A-66A, CA_2C-[66A]-
66A, CA_2C-66A-[66A], CA_3A-3A-7A-7A, CA_3A-3A-7A-8A, CA_3A-
3A-7A-20A, CA_3A-3A-7A-28A, CA_3A-5A-7A-7A, CA_3A-7A-7A-8A,
CA_3A-7C-20A, CA_3A-7C-28A, CA_3A-28A-40C, CA_3A-28A-42C,
CA_3A-40D, CA_3A-46D, CA_3C-7A-20A, CA_3C-7A-28A, CA_3C-
7C, CA_3C-40C, CA_[4A]-46A-46C, CA_[4A]-46D, CA_7A-46D,
CA_28A-40D, CA_28A-46D, CA_40C-40C, CA_40C-42C, CA_40E,
CA_[41C]-42C, CA_42C-42C, CA_42E, CA_46A-46C-[66A], CA_46D-
[66A], CA_48D-[66A], CA_48E
5CA
CA_1A-3A-7C-28A, CA_1A-3C-7C, CA_1A-3C-40C, CA_2A-46A-
46C-66A, CA_2A-46D-66A, CA_3A-28A-40D, CA_3C-7C-28A,
CA_3A-40E
2UL CA
UL_1A-7A, UL_1A-8A, UL_1A-28A, UL_3A-7A, UL_3A-8A, UL_3A-
20A, UL_3A-28A, UL_4A-7A, UL_3C, UL_7C, UL_38C, UL_39C,
UL_40C, UL_41C, UL_42C
Carrier Aggregation
AT&T
2CA
CA_[2A]-[4A], CA_[2A]-5A, CA_2A-7A, CA_[2A]-12A, CA_[2A]-14A,
CA_[2A]-29A, CA_2A-30A, CA_[2A]-46A, CA_[2A]-48A, CA_[2A]-
[66A], CA_[2A]-71A, CA_[4A]-5A, CA_4A-7A, CA_[4A]-12A, CA_[4A]-
29A, CA_4A-30A, CA_[4A]-46A, CA_[4A]-71A, CA_5A-30A, CA_5A-
[66A], CA_7A-12A, CA_12A-30A, CA_12A-[66A], CA_14A-30A,
CA_14A-[66A], CA_[25A]-26A, CA_25A-41A, CA_26A-[41A],
CA_29A-30A, CA_29A-[66A], CA_30A-66A, CA_46A-[66A], CA_48A-
[66A], CA_[66A]-71A, CA_[2A]-[2A], CA_[4A]-[4A], CA_[25A]-[25A],
CA_[41A]-[41A], CA_48A-48A, CA_[66A]-[66A], CA_[2C], CA_5B, CA_7C, CA_12B, CA_[41C], CA_48C, CA_[66B], CA_[66C]
3CA
CA_[2A]-2A-5A, CA_2A-[2A]-5A, CA_[2A]-2A-12A, CA_2A-[2A]-12A,
CA_2A-2A-30A, CA_[2A]-2A-66A, CA_2A-[2A]-66A, CA_2A-2A-[66A],
CA_[2A]-2A-71A, CA_2A-[2A]-71A, CA_[2A]-4A-4A, CA_2A-[4A]-4A,
CA_2A-4A-[4A], CA_[2A]-4A-5A, CA_2A-[4A]-5A, CA_[2A]-4A-12A,
CA_2A-[4A]-12A, CA_[2A]-4A-29A, CA_2A-[4A]-29A, CA_2A-4A-30A,
CA_[2A]-4A-71A, CA_2A-[4A]-71A, CA_2A-5A-30A, CA_[2A]-5A-66A,
CA_2A-5A-[66A], CA_2A-7A-12A, CA_2A-12A-30A, CA_[2A]-12A-
66A, CA_2A-12A-[66A], CA_[2A]-12B, CA_2A-14A-30A, CA_[2A]-
14A-66A, CA_2A-14A-[66A], CA_2A-29A-30A, CA_2A-30A-66A,
CA_[2A]-46A-46A, CA_[2A]-46A-66A, CA_2A-46A-[66A], CA_[2A]-
46C, CA_[2A]-48A-48A, CA_[2A]-48C, CA_[2A]-48A-66A, CA_2A-
48A-[66A], CA_[2A]-66A-66A, CA_2A-[66A]-66A, CA_2A-66A-[66A],
CA_[2A]-66A-71A, CA_2A-[66A]-71A, CA_[2A]-[66C], CA_[2A]-66C,
CA_2A-[66C], CA_[4A]-4A-5A, CA_4A-[4A]-5A, CA_4A-4A-7A,
CA_[4A]-4A-12A, CA_4A-[4A]-12A, CA_4A-4A-30A, CA_[4A]-4A-71A,
CA_4A-[4A]-71A, CA_4A-5A-30A, CA_4A-7A-12A, CA_4A-12A-30A,
CA_[4A]-12B, CA_4A-29A-30A, CA_[4A]-46A-46A, CA_[4A]-46C,
CA_5A-30A-66A, CA_5A-[66A]-66A, CA_5A-66A-[66A], CA_5A-[66C],
CA_12A-30A-66A, CA_12A-[66A]-66A, CA_12A-66A-[66A], CA_12A-
[66C], CA_14A-30A-66A, CA_14A-[66A]-66A, CA_14A-66A-[66A],
CA_[25A]-25A-26A, CA_25A-[25A]-26A, CA_25A-41C, CA_26A-
[41C], CA_29A-30A-66A, CA_29A-[66A]-66A, CA_29A-66A-[66A],
CA_30A-66A-66A, CA_[41A]-[41C], CA_[41A]-41C, CA_41A-[41C],
CA_[41D], CA_46C-[66A], CA_48A-48C, CA_48D, CA_48A-48A-
[66A], CA_48C-[66A], CA_[66A]-66A-71A, CA_66A-[66A]-71A
4CA
CA_2A-2A-5A-30A, CA_2A-2A-5A-66A, CA_2A-2A-12A-30A, CA_2A-
2A-12A-66A, CA_2A-2A-29A-30A, CA_2A-2A-66A-66A, CA_2A-2A-
66A-71A, CA_[2A]-2A-66C, CA_2A-[2A]-66C, CA_2A-2A-[66C],
CA_2A-4A-4A-12A, CA_2A-4A-5A-30A, CA_2A-4A-7A-12A, CA_2A-
4A-12A-30A, CA_2A-5A-30A-66A, CA_2A-5A-66A-66A, CA_2A-5B-
30A, CA_[2A]-5B-66A, CA_2A-5B-[66A], CA_2A-12A-30A-66A,
CA_2A-12A-66A-66A, CA_2A-29A-30A-66A, CA_2A-46A-46A-66A, CA_[2A]-46A-46C, CA_[2A]-46C-66A, CA_2A-46C-[66A], CA_[2A]-
46D, CA_2A-66A-66A-71A, CA_2A-66C-71A, CA_[2C]-66A-66A,
CA_2C-[66A]-66A, CA_2C-66A-[66A], CA_4A-4A-12A-30A, CA_[4A]-
46A-46C, CA_[4A]-46D, CA_5A-30A-66A-66A, CA_5B-30A-66A,
CA_5B-66A-66A, CA_12A-30A-66A-66A, CA_25A-41D, CA_29A-
30A-66A-66A, CA_[41A]-41D, CA_[41C]-41C, CA_41C-[41C],
CA_41E, CA_46A-46C-[66A], CA_46D-[66A], CA_48D-[66A], CA_48E
5CA
CA_2A-2A-46D, CA_2A-5B-30A-66A, CA_2A-5B-66A-66A, CA_2A-
46A-46C-66A, CA_2A-46D-66A, CA_5B-30A-66A-66A, CA_46D-66A-
66A
2UL CA
UL_2A-5A, UL_2A-12A, UL_4A-12A, UL_5A-66A, UL_5B, UL_41C
Carrier Aggregation
Verizon
2CA
CA_[2A]-[2A], CA_[2A]-[4A], CA_[2A]-5A, CA_[2A]-13A, CA_[2A]-
[66A], CA_[4A]-[4A], CA_[4A]-5A, CA_[4A]-13A, CA_5A-[66A],
CA_5B, CA_13A-[66A], CA_[66A]-[66A], CA_[66B], CA_[66C],
CA_[2A]-48A, CA_13A-48A, CA_48A-[66A]
3CA
CA_[2A]-2A-5A, CA_[2A]-2A-13A, CA_[2A]-2A-66A, CA_2A-2A-[66A],
CA_[2A]-4A-5A, CA_2A-[4A]-5A, CA_[2A]-4A-13A, CA_2A-[4A]-13A,
CA_[2A]-5A-66A, CA_2A-5A-[66A], CA_[2A]-13A-66A, CA_2A-13A-
[66A], CA_[2A]-66A-66A, CA_2A-[66A]-66A, CA_[2A]-[66B], CA_[2A]-
[66C], CA_[4A]-4A-5A, CA_[4A]-4A-13A, CA_5A-[66A]-66A, CA_5A-
[66B], CA_5A-[66C], CA_13A-[66A]-66A, CA_13A-[66B], CA_13A-
[66C], CA_[66A]-[66C], CA_[66D], CA_[2A]-48A-48A, CA_[2A]-48A-
66A, CA_2A-48A-[66A], CA_[2A]-48C, CA_13A-48A-48A, CA_13A-
48A-[66A], CA_13A-48C, CA_48A-48A-[66A], CA_48A-[66A]-66A,
CA_48A-[66B], CA_48C-[66A]
4CA
CA_2A-48A-48A-66A, CA_[2A]-48D, CA_13A-48A-48A-66A,
CA_13A-48A-48C, CA_13A-48C-[66A], CA_13A-48D, CA_48A-48A-66A-66A, CA_48A-48A-[66B], CA_48A-48A-[66C], CA_48A-48C-
[66A], CA_48D-[66A]
5CA
CA_2A-48E, CA_13A-48A-48C-66A, CA_13A-48C-48C, CA_13A-
48D-66A, CA_13A-48E, CA_48A-48C-66B, CA_48A-48C-66C,
CA_48C-48C-66A, CA_48E-66A
2UL CA
UL_2A-13A, UL_4A-13A
Carrier Aggregation
T-Mobile US
2CA
3CA
CA_2A-[66C], CA_[4A]-4A-5A, CA_4A-[4A]-5A, CA_4A-4A-7A,CA_[4A]-4A-12A, CA_4A-[4A]-12A, CA_4A-4A-30A, CA_[4A]-4A-71A,
4CA
5CA
66A
2UL CA
Carrier Aggregation
CBRS
2CA
CA_42A-42A, CA_48A-48A, CA_42C, CA_48C
3CA
CA_42A-42C, CA_42D, CA_48A-48C, CA_48D
2UL CA
UL_42C
Carrier compatibility is generally based on having compatible bands on the modem. In the open market, carriers may only require regulatory domain certifications and open market certifications, like the PTCRB and GCF, to be compatible for their network. Sometimes carriers will require additional testing before a device can be used on their network. The section Tested Carriers is based on Meraki device certifications being approved by those specific carriers. A carrier being listed above means that they have officially certified the Meraki product for their cellular network. There maybe many unlisted carriers could be functionally compatible with Meraki devices. The list of tested certified carriers is based on the carrier validating Meraki per their network parameter requirements. If a carrier you are looking to use is not listed above, it could be that they do not require additional compliance testing for their network.
Model
MTBF at 25°C
MG41 1,931,000
MG41E 1,931,000
Ordering Guide
To place an order for an MG41 cellular gateway, pair a specific hardware model with a single license (which includes cloud services, software upgrades and support). For example, to order an MG41E with 3 years of enterprise licensing for use in North America, order an MG41E-HW with LIC-MG41-ENT-3Y.
Model SKU Description
MG41-HW Meraki MG41 Cellular Gateway
MG41E-HW Meraki MG41 Cellular Gateway – External Antennas
Licensing
License SKU Description
LIC-MG41-ENT-1Y Meraki MG41 Enterprise License and Support, 1YR
LIC-MG41-ENT-3Y Meraki MG41 Enterprise License and Support, 3YR
LIC-MG41-ENT-5Y Meraki MG41 Enterprise License and Support, 5YR
LIC-MG41-ENT-7Y Meraki MG41 Enterprise License and Support, 7YR
LIC-MG41-ENT-10Y Meraki MG41 Enterprise License and Support, 10YR
Accessories
Accessory SKU Description
MA-PWR-30W-XX Standard power adapter. Regional plugs per SKU.
MA-INJ-4 Gigabit 802.3at PoE injector
MA-ANT-C2-A Dipole Antenna pair included with MG41E
MA-ANT-C1-B Patch Antenna pair for MG41E
Included In The Box
Model Contents
MG41 1 x MG41-HW
1 x Mounting plate and screw set
MG41E 1 x MG41E-HW
4 x dipole antennas
We only support and recommend having all 4 antenna's connected on the MG 41E.
Non-Meraki Antenna not supported
Note: Non-Meraki antennas are not supported. The socket is a reversed RP-SMA that is designed to detect the official MG smart dipole antennas and smart patch antenna. Usage of non-Meraki accessories may damage the MG and degrade performance. The Cisco Meraki antennas are designed for the maximum allowable gain without exceeding the EIRP for local regulatory domains on their supported bands.
Power Adapter vs PoE : The MG can be powered using a PoE or via a power adapter. The power adapter always takes the first preference i.e if the MG is already powered via the PoE and then the power adapter is connected, then the MG will power off and power on using the adapter as the power source. The same scenario applies when the PoE and power adapter are connected simultaneously and the power source from the adapter goes down, the MG will power off and then power on. Plugging/unplugging PoE when power adapter is connected to the MG does not have any bearing on the operation of the MG as the device will always draw power from the adapter whenever it is connected.
Warranty
MG Warranty coverage periods are as follows:
Product
Warranty Period
Warranty Information
MG41/MG41E
Lifetime
Full lifetime hardware warranty with next-day advanced replacement included.
Applies to MG41 and MG41E hardware
MG Accessories
1 Year
The following are considered accessories:
Includes mounting kits, antenna, and additional power cords
Additional warranty information can be found on the Return Policy and Requesting a RMA page of the Cisco Meraki website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
In order to initiate a hardware replacement for non-functioning hardware that is under warranty, you must have access to the original packaging the hardware was shipped in. The original hardware packaging includes device serial number and order information, and may be required for return shipping.
Meraki MG41 and MG41E devices have been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation.
  • Was this article helpful?
