Home > Wireless LAN > Client Addressing and Bridging > Tagging Client VLANs with RADIUS Attributes
Table of contents
No headers
A RADIUS server has the ability to send VLAN information to the AP in RADIUS Access Accept messages. To send VLAN information, three required RADIUS attributes must be configured in your RADIUS policy:
  • Tunnel-Type: Choose  Attribute value Commonly used for 802.1X and select Virtual LANs (VLANs).
  • Tunnel-Medium-Type: Choose 802 (Includes all 802 media plus Ethernet canonical format) for the Attribute value Commonly used for 802.1X.
  • Tunnel-Private-Group-ID: Choose String and enter the VLAN desired (ex. "500")This string will specify the VLAN ID 500.
Sample FreeRADIUS user configuration (/etc/freeradius/3.0/users):
Tunnel-Type = "VLAN",
Tunnel-Medium-Type = "IEEE-802",
Tunnel-Private-Group-ID = "500"
Check your RADIUS vendor-specific documentation for the appropriate values.
Sample FreeRADIUS EAP configuration (/etc/freeradius/3.0/mods-enabled/eap):
use_tunneled_reply = yes
When configuring the Tunnel parameters under the EAP configuration, FreeRADIUS will not inject these parameters into the final Access-Accept unless the EAP configuration is changed from 'use_tunneled_reply = no' (Default) to 'use_tunneled_reply=yes'.
To configure the AP to accept the VLAN information sent from by the RADIUS server, navigate to Wireless > Configure > Access Control and see the Addressing and Traffic section. Enable set "Radius Override" to "RADIUS Response Can Override VLAN tag." This setting can override the configured SSID VLAN or apply a VLAN if one is not specified:
Note: RADIUS override can only be used with WPA2-Enterprise or MAC-based access control.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
