Home > Wireless LAN > Group Policies and Blacklisting > Implementing bandwidth per-device using WPA2-Enterprise with RADIUS authentication - (Enterprise Only)
Table of contents
No headers
A network operator can implement bandwidth limits per user when using WPA2-Enterprise with RADIUS authentication. This functionality requires the use of RADIUS Group Policies.
  1. Login to Dashboard.
  2. Click on the "Configure" --> "Group Policies" link.
  3. Select the SSID you would like to limit from the SSID: drop down list.
  4. Select "Filter-ID" in the "RADIUS attribute specifying the group" list.
  5. Name the group name for this policy is based on the Filter-ID string attribute specified in your RADIUS policy. Access points must receive this attribute in the RADIUS Access-Accept message so the Group policy will apply.
You will then need to setup a corresponding group within your Directory server and ensure that the intended user or computer accounts are members of that group. Finally you will need to specify this group and Filter-ID attribute in your RADIUS servers policy. Please refer to your RADIUS server manual for more details on this portion of the setup.
The following Microsoft link explains creating a Filter-ID attribute on an IAS server.
Use a Standard RADIUS Attribute Filter-ID
You must to post a comment.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
