MS Switch Access Policies (802.1X)
Summary
Cisco Meraki MS switches offer the ability to configure access policies, which require connecting devices to authenticate against a RADIUS server before they are granted network access. These access policies are typically applied to ports on access-layer switches to prevent unauthorized devices from connecting to the network.
This article outlines what options are available for access policies, how to configure access policies in the Meraki dashboard, and the configuration requirements for RADIUS servers.
As of MS 9.16, changes to an existing access policy will cause a port-bounce on all ports configured for that policy.
Each network can have a maximum of 8 access policies configured.
For troubleshooting guidance, please follow RADIUS Issue Resolution Guide.
Organization-wide RADIUS servers
Org-wide RADIUS servers are currently in Early Access Preview. Please refer to the Organization Settings document here for more information on how to define and utilize RADIUS server configurations at the organization level.
The Org-Wide RADIUS servers feature provides the ability to define one or many RADIUS servers once and then re-use the configuration across the organization for access policies.
Configuration
- After Org-Wide RADIUS Servers are configured at the organization level, navigate to the target access policy under Switching > Configure > Access policies
- Scroll to Radius Servers, and then in the box that says 'Select RADIUS', check the box beside the desired RADIUS server and save the changes
A maximum of 3 RADIUS servers defined in each access policy still applies when using Org-Wide Radius Servers
Host Modes
Support for all host modes is available from firmware version MS 10.12.
There are four authentication host modes to choose from:
- Single-Host (Default)
With single-host authentication, a connected device will attempt authentication and if it fails to authenticate, the client will be denied access. This mode is recommended for switch ports with only one client attached. If multiple devices are connected to the same switch port (for example a device connected via a hub or daisy-chained off of a VoIP phone), only one client will be allowed network access upon successful authentication. All subsequent authentication requests from other clients will be ignored and they will not be granted access as a result.
Multi-Domain
With multi-domain authentication, one device can be authenticated on each of the data and voice VLANs; if a second device is detected on one of the VLANs, the device will not be granted access. In this mode, Hybrid Authentication is used and Voice VLAN authentication is required. This mode is recommended for switch ports connected to a phone with a device behind the phone. Authentication is independent on each VLAN and will not affect the forwarding state of each other.
Cisco Meraki switches require the following attribute pairs within the Access-Accept frame to put devices on the voice VLAN:-
Cisco-AVPair
device-traffic-class=voice
- Multi-Auth
With multi-auth, each connected device is required to authenticate. Multiple devices may be connected to each port. After a VLAN is assigned to a host on the port, subsequent hosts must have matching VLAN information or be denied access to the port. Only one client is supported on the voice VLAN. Guest VLANs are not supported in this mode.
Cisco-AVPair
- Multi-Host
With multi-host, a single successful authentication will put the port into a forwarding state. All subsequent authentication attempts are ignored. This is recommended in deployments where the authenticated device acts as a point of access to the network, for example, hubs and access points.
Note: The MS390 and C9300-Ms supports multi-auth multi-VLAN and will allow for multiple data domain sessions behind the same switch port to have different VLAN IDs assigned without blocking access.
Note: VLAN Profiles feature simplifies VLAN management across multiple sites by enabling dynamic assignment of VLANs based on descriptive names rather than numerical IDs. This facilitates easier management across multiple sites with varying VLAN configuration reducing the need for multiple RADIUS policies. Click here for additional information.
Access Policy Types
There are three options available for an access policy in Dashboard:
- 802.1X (Default)
When an 802.1X access policy is enabled on a switch port, a client that connects to that switch port will be prompted to provide their domain credentials. If the RADIUS server accepts these credentials as valid, their device will be granted access to the network and get an IP configuration. If no authentication is attempted, they will be put on a "guest" VLAN, if one is defined.
802.1X access policies are commonly used in enterprise environments, since they can authenticate against the existing domain userbase.
- MAC Authentication Bypass (MAB)
When a MAB access policy is enabled on a switch port, the client's MAC address is authenticated against a RADIUS server without needing to prompt the user. If the server accepts the MAC as valid credentials for the network, the device will be allowed access.
MAB access policies are useful for a more seamless user experience, restricting the network to specific devices without needing to prompt the user.
- Hybrid Authentication
When a hybrid access policy is enabled on a switch port, the client will first be prompted to provide their domain credentials for 802.1X authentication. If 802.1X authentication fails, or if the switch does not receive any EAP packets within 8 seconds to begin 802.1X authentication, then the client's MAC address will be authenticated via MAB. If both methods of authentication fail, the device will be put on a "guest" VLAN, if one is defined.
Hybrid authentication is helpful in environments where not every device supports 802.1X authentication since MAB exists as a failover mechanism. - Increase Access Speed
When a policy is set to increase access speed, the 802.1X and MAB access-request will be send in parallel, which can allow for MAB devices with no supplicant to gain access to the network without waiting for the 802.1X process to time-out. The 802.1X response for the same device will always override the MAB result received. For devices with a supplicant, it is advised to either configure the supplicant, or disable the supplicant to use MAB when the MAB result is the desired authentication mechanism.
Warning: Cisco Identity Services Engine does not officially support increase access speed behaviors and can cause outcomes that are not desirable including higher Policy Services Node and Monitoring node load, as well as potentially undesirable authentication/authorization behaviors.
Change of Authorization (CoA)
Meraki MS and Catalyst 9300-M switches support CoA for RADIUS reauthentication and disconnection as well as port bouncing. For more information, please see the following KB article.
URL Redirect Walled Garden (Supported on MS210/225/250/350/355/390**/410/420/425 and C9300-M)
By default, URL redirect is enabled with CoA. This can be used to redirect clients to a webpage for authentication. Before authentication, http traffic is allowed but the switch redirects it to the redirect-url. The walled garden can be used to limit access to the web server only. This feature will only be enabled if one or more supported switches are in the network. Configurations on this feature will be ignored by unsupported switches. -
For URL redirect on the MS390 and C9300-Ms, there needs to be a walled-garden ACL name sent with the access-accept message from the RADIUS server. The first access-policy in the list will require an ACL name of Walled-Garden-00 and each subsequent access-policy will increment by 1. e.g. Access Policy 2 will be Walled-Garden-01. The Walled Garden ACL on the MS390 and C9300-Ms will allow DHCP, DNS, and IP access to the walled garden IP addresses.
NOTE: UDP/1700 is the default port used by all MS for CoA
**NOTE: MS390s and C9300-Ms support RADIUS URL-Redirect as of MS 15
Other RADIUS Features
- RADIUS Accounting
RADIUS Accounting can be enabled to send start, interim-update (default interval of 20 minutes) and stop messages to a configured RADIUS accounting server for tracking connected clients. Meraki’s implementation follows the IETF’s RFC 2869 standard.
As of MS 10.19, device sensor functionality for enhanced device profiling has been added by including CDP/LLDP information the RADIUS Accounting message (MS120/125/130/130R/220/225/250/320/350/355/410/425/450). As of 14.19+ the MS390 and C9300-Ms also supports device sensor with enhanced attributes across LLDP, CDP, mDNS, and DHCP for profiling.
- RADIUS Testing
Meraki switches will periodically send Access-Request messages to these RADIUS servers using identity 'meraki_8021x_test' to ensure that the RADIUS servers are reachable. If unreachable, the switch would transition into an alerting status to indicate a failure. Actual server failover is based on the client authentication requests. Failed client authentications will have the switch failover to the next available configured server.
- RADIUS Monitoring
In addition to the mechanism in RADIUS Testing, if all RADIUS servers are unreachable, clients attempting to authenticate will be put on the Guest or Critical Auth VLAN depending on which is defined. When the connectivity to the server is regained, the switch port will be cycled to initiate authentication. Please contact Meraki Support to enable this feature.This feature must be enabled to track RADIUS server reachability. If not enabled, clients will continue to be put on the Guest or Critical Auth VLANs even after connectivity between the MS and RADIUS server has been restored.
RADIUS test messages are sent every 5 minutes.
- Dynamic VLAN Assignment
MS switches can dynamically assign a VLAN to a client device by configuring the switch port to use the VLAN ID received via the RADIUS attribute Tunnel-Pvt-Group-ID. It may be necessary to perform dynamic VLAN assignment on a per computer or per user basis. This can be done on your wired network via 802.1X authentication (RADIUS).MS390s and C9300-Ms support multi-vlan assignment, when using Multi-Auth as the host mode. This means that multiple client devices connected in the Data domain on the same port can be mapped to different VLANs through RADIUS assignment.
This functionality is currently supported only on the MS390 and C9300-Ms switches.
In order to do so, the following RADIUS attributes must be configured and passed in the RADIUS Access-Accept message from the RADIUS server. Once these attributes are configured on the RADIUS server, client devices can receive their VLAN assignment dynamically.
Dynamic assignment of the VLAN for the Voice domain requires an additional attribute, device-traffic-class=voice, to be included in the Access-Accept message from the RADIUS server.Support for Dynamic VLAN Assignment for the Voice VLAN / domain was introduced in firmware version MS 15.
For more information on how to configure with NPS, visit Microsoft's article on Configuring a Network Policy for VLANs.- Tunnel-Medium-Type: Choose 802 (Includes all 802 media plus Ethernet canonical format) for the Attribute value Commonly used for 802.1X.
- Tunnel-Private-Group-ID: Choose String and enter the VLAN desired (ex. "500"). This string will specify the VLAN ID 500.
- Tunnel-Type: Choose Attribute value Commonly used for 802.1X and select Virtual LANs (VLANs)
- 802.1X Control Direction (Wake-on-LAN support)
802.1X Control Direction is set by default to "both" directions. In this mode, the switch port doesn't allow ingress or egress traffic through the switch port until after the port is authorized via 802.1X or MAB authentication. Control Direction can also be set to "inbound-only", in which case the switch port doesn't allow ingress traffic, but will allow limited egress traffic from the network through the switch port to reach the connected device. This is often used to allow Wake-on-LAN magic packets to wake a sleeping host on the connected port, at which point the host can attempt a normal 802.1X or MAB authentication to authorize the switch port for full ingress and egress traffic.
This feature is available in public preview/beta in dashboard as of Aug 2022 beginning in MS 15 for classic switches. The toggle will only appear on networks running MS 15 or later. Support is not available on MS390 switches as of MS 15, but is anticipated to be added in an upcoming release.
- Guest VLAN
Guest VLANs can be used to allow unauthorized devices access to limited network resources. This is not supported on the voice VLAN/domain.RADIUS Monitoring must be enabled to track RADIUS server reachability. If not enabled, clients will continue to be put on the Guest or Critical Auth VLANs even after connectivity between the MS and RADIUS server has been restored.
- Failed Authentication VLAN
A client device connecting to a switch port controlled by an access policy can be placed in the failed authentication VLAN if the RADIUS server denies its access request.Client devices may fail RADIUS authentication because they do not comply with the network's security requirements. The failed authentication VLAN provides such clients with limited access to the network for remediation purposes.
Failed Authentication VLAN is only supported in the Single Host, Multi Host and Multi Domain modes. Access policies using Multi Auth mode are not supported.
Re-authentication Interval
When the Re-authentication Interval (time in seconds) is specified, the switch will periodically attempt authentication for clients connected to switch ports with access policies. Apart from providing for a better security policy by periodically validating client authentication in a network, the re-authentication timer also enables the recovery of clients placed in the Failed Authentication VLAN because of incomplete provisioning of credentials.
Re-authentication will not occur if no re-authentication interval has been configured, or if a reauthentication-interval has been configured but the switch has lost connectivity to all of the RADIUS servers listed under the access policy.Suspend Re-authentication when RADIUS servers are unreachable
Periodic re-authentication of clients can be an issue when RADIUS servers are unreachable. The Suspend Re-authentication when RADIUS servers are unreachable allows users to choose whether the re-authentication should occur or not when none of the RADIUS servers are reachable. By default, re-authetication gets suspended when RADIUS servers are not reachable.'Suspend re-authentication when RADIUS servers are unreachable,' is not a configurable option on the MS390 and C9300-M series switches
. An MS390 and C9300-M switch will automatically ignore this configuration, and will always suspend client re-authentication, if it loses connectivity with the RADIUS server. -
Critical Authentication VLAN
The critical authentication VLAN can be used to provide network connectivity to client devices connecting on switch ports controlled by an access policy when all of the RADIUS servers for that policy are unreachable or fail to respond to the authentication request on time.
When the RADIUS servers are not reachable from the switch, authentication requests for clients attempting to connect to the network will fail, resulting in clients being denied access. Critical authentication VLAN ensures that these clients are still able to access the business-critical resources by placing them in a separate VLAN. This also allows network administrators to better control the network access available to clients when their identities cannot be established using RADIUS.The critical data and critical voice VLANs should not be the same.
Configuring Critical Authentication VLAN or Failed Authentication VLAN under an access policy may affect its existing Guest VLAN behavior. Please consult the Interoperability and backward compatibility section of this document for details.
An "802.1X Canned EAP Success" event will be triggered if the authentication process places a client's VLAN on the critical, guest, or failed authentication VLAN. This alert is different from the "802.1X EAP Success" event where authentication is successful and planned connectivity is provided.
Suspend port bounce
When connectivity between the switch and any of the RADIUS servers is restored, the switch will attempt to authenticate the clients which it had placed in the Critical Authentication VLAN. The switch does this by bouncing (turning off and on) the switch ports on which these clients are connected. If required, this port-bounce action can be disabled by enabling the Suspend port bounce option. When port-bounce is suspended, the clients will be retained in the Critical Authentication VLAN until a re-authentication for these clients is manually triggered.
Interoperability and backward-compatibility in VLAN assignments
If Critical and/or Failed Authentication VLANs are specified in an Access Policy, the Guest VLAN functionality gets modified to ensure backward-compatibility and inter-op between the configured VLANs. Please refer to the Interoperability and backward-compatibility table below for more details on this.
The following matrix shows the remediation VLAN, if any, that client devices would be placed in for the different combinations of the remediation VLAN configuration options and the RADIUS authentication result.
Configured options | Authentication result | ||
EAP timeout (for 802.1X policies only) |
RADIUS timeout (server unreachable) |
Authentication Fail (access-reject) |
Guest (existing behaviour) | Guest VLAN | Guest VLAN | Access denied 1 |
Failed | Access denied | Access denied | Failed Auth VLAN |
Critical | Access denied | Critical Auth VLAN | Access denied |
Guest and Failed | Guest VLAN | Guest VLAN | Failed Auth VLAN |
Guest and Critical | Guest VLAN | Critical Auth VLAN | Access denied 1 |
Critical and Failed | Access denied | Ciritical Auth VLAN | Failed Auth VLAN |
Guest, Failed and Critical | Guest VLAN | Critical Auth VLAN | Failed Auth VLAN |
1 When using hybrid authentication without increase access speed (concurrent-auth), a client failing both 802.1X and MAB authentication will also be placed in the Guest VLAN. Please refer to the Access Policy Types section of the MS Switch Access Policies documentation for details.
MS 14 is the minium firmware version required for the following configuration options.
- Re-authentication Interval,
- Suspend Re-authentication when RADIUS servers are unreachable
- Critical Authentication VLANs
- Suspend port bounce
When using CWA - Central Web Authentication with Cisco ISE, please uncheck Increase Access Speed as this will result in CWA failing.
RADIUS Attributes
When an access policy is configured with a RADIUS server, authentication is performed using PAP. The following attributes are present in the Access-Request messages sent from MS switch to the RADIUS server.
- User-Name
- NAS-IP-Address
- Calling-Station-Id: Contains the MAC address of the end user machine (supplicant) (all caps, octets separated by hyphens, example: "AA-BB-CC-DD-EE-FF").
- Called-Station-Id: Contains the MAC address of the Meraki MS switch (all caps, octets separated by hyphens).
Note: MS390 and C9300-M has an exception, it will send MACID of the switch port in the Called-Station-Id AVP.
- Framed-MTU
- NAS-Port-Type
- EAP-Message
- Message-Authenticator
Note: Please refer to RFC 2865 and RFC 3579 for details on these attributes, additional notes for certain attributes are included below.
Creating an Access Policy on Dashboard
Creating an Access Policy Using a Custom Radius Server
- On the dashboard navigate to Switching > Configure > Access policies.
- Click on the link Add an access policy in the main window then click the link to Add a server.
- Enter the IP address of the RADIUS server, the port (default is 1812), and the secret created earlier.
- Select the required options, as described above.
- Click Save changes.
Creating an Access Policy Using Meraki Authentication
- Under Authentication method select Meraki Authentication.
- Select a Guest VLAN and whether to allow System Manager enrollment.
Apply Access Policy to Switch Ports
- Navigate to Switching > Monitor > Switch ports.
- Select the switch port(s) you would like to apply the access policy to and press the Edit button.
- Convert the switch port type from trunk to access. Note: you can only apply an Access Policy to an access port.
- From the Access Policy drop-down box, select the Access Policy you created and press the Update ports button.
Unmanaged Switches Between MS and Client for RADIUS Authentication
When using PEAP EAP-MSCHAPv2 on an MS switch port, if an unmanaged switch is between the end user machine (supplicant) and the RADIUS client (MS) the authentication will fail. The reasoning is explained below:
- The destination of the eapol (RADIUS exchange) frame is a special multicast address that 802.1D-compliant bridges do not forward.
- This destination is labeled as "nearest" in Wireshark which means that the frame should only be forwarded to the next layer 2 device.
- If the unmanaged switch is added into the topology between the client and the MS, the next layer 2 device is the unmanaged switch and because the multi-cast nearest address is not meant to traverse multiple switches, the unmanaged switch drops the packets. This prevents the client from being authorized.
There is a work-around to this but special considerations must be taken before implementing them:
- This is not due to a fault in the MS but is the way that eapol is designed.
- It is possible to circumvent this by using MAC based RADIUS authentication. If one machine authenticates via MAC based RADIUS through the MS on an unmanaged switch, the machine that has authenticated will be granted access. It is a workaround but it is less secure and requires more configuration on the NPS and DC.
