Home > Switches > Installation Guides > MS220-24/48 Series Installation Guide
Models
Model number
Description
MS220-24 Layer-2 24-port GigabitEthernet switch with 4 SFP interfaces
MS220-24P
Layer-2 24-port GigabitEthernet 370W PoE switch with 4 SFP interfaces
MS220-48 Layer-2 48-port GigabitEthernet switch with 4 SFP interfaces
MS220-48LP Layer-2 48-port GigabitEthernet 370W PoE switch with 4 SFP interfaces
MS220-48FP Layer-2 48-port GigabitEthernet 740W PoE switch with 4 SFP interfaces
Package contents
In addition to the MS switch, the following are provided (mounting kit provided with 1U models only):
Rack Mount Kit includes:
  • US 12-24 mounting screws and cage nuts, 5 of each
  • INTL M5 mounting screws and cage nuts, 5 of each
  • INTL M6 mounting screws and cage nuts, 5 of each
  • Mounting washers
MS220-24 Series front panel
MS220-48 Series front panel
Ports and Status Indicators
The MS uses LEDs to inform the user of the device's status. When the device powers on, all the Internet LEDs flash twice. Additional functions are described below, from left to right.
Item
Function
LED Status
Meaning
1
Power
Solid orange
Switch is unable to connect to the Meraki cloud
Flashing green
Firmware upgrade in process
Solid green
Switch is fully operational and connected to the Meraki cloud
    Off Switch does not have power
2 Restore N/A Restore button to clear switch IP and local configuration settings
3
Switch Ports
Off
No client connected
Solid orange
Link operating at 10/100 Mbps
Solid green
Link operating at 1000 Mbps
In addition, there is a RESTORE button available on the front panel.
Insert a paper clip if a restore is required.
  • A brief, momentary press: To delete a downloaded configuration and reboot.
  • Press and hold for more than 10 sec: To force the unit into a full factory restore.
MS220 Series back panel
Power input The MS comes standard with US power cord. EU/UK/AU power cords may be ordered separately.
Equipment is to be used only in a restricted access location and installed/operated only by trained service personnel.
RPS2300 Redundant Power Supply (Optional)
The MS220-24 series supports connecting the Cisco RPS2300 for optional power redundancy. MS220-24 series models support failover and reversion to main power once it has been restored. The following Cisco part numbers are supported:
Part number
Description
PWR-RPS2300
RPS Chassis
C3K-PWR-750WAC 750W RPS Power supply (see recommendations)
C3K-PWR-1150WAC 1150W RPS Power supply (see recommendations)
CAB-RPS2300-E= RPS 22-pin cable
RPS power supply matrix
Switch Model
Full power load, [switch only / including PoE]
MS220-24 18 W / not applicable
MS220-24P 77 W / 447W
MS220-48 51 W / not applicable
MS220-48LP 135 W / 505 W
MS220-48FP 163 W / 903 W
Example configurations
Example 1: "I have 3 x MS220-24 and 3 x MS220-48 switches connected to my RPS2300"
3 x 18W = 54W
3 x 51W = 153W
54W + 153W = 207W total power draw
Recommended hardware:
1 x PWR-RPS2300
1 x C3K-PWR-750WAC (750W) OR 2 x C3K-PWR-750WAC (750W) for redundancy
6 x CAB-RPS2300-E=
Example 2: I have 6 x MS220-24P switches connected to my RPS2300. I also intend to use the full PoE budget of 370W on each switch and want to back it up in case of a failure.
6W x 447W = 2683W total power draw
1 x PWR-RPS2300
2 x C3K-PWR-1150WAC (2300W)
6 x CAB-RPS2300-E=
Example 3: I have 3 x MS220-48 and 3 x MS220-48LP connected to RPS2300.  I also intend to use the full PoE budget on each of the PoE switches but I do not need to back it up in case of a failure.
3 x 51 = 153W
3 x 135 = 405W
153W + 405W = 558W total power draw
1 x PWR-RPS2300
6 x CAB-RPS2300-E=
Only the RPS2300 chassis (PWR-RPS2300) and accessories are supported. For more information, see the RPS2300 datasheet
Mounting hardware
The mounting hardware includes a rack mount kit for standard 1U racks. When installing the device, make sure that there is sufficient space between the rear of the rack and other obstacles to ensure adequate airflow.
You must to post a comment.
Last modified
09:34, 7 Jun 2017
Tags
This page has no custom tags.
Classifications
Article ID
Contact Support
Open a Case
