Home > Switches > Installation Guides > MS220-8 Series Installation Guide
Models
Model Number
Description
MS220-8 8-port gigabit switch with 2 SFP interfaces
MS220-8P 8-port PoE gigabit switch with 2 SFP interfaces
MS220-8 Series front panel
Ports and Status Indicators
The MS uses LEDs to inform the user of the device's status. When the device powers on, all the Internet LEDs flash twice. Additional functions are described below, from left to right.
Item
Function
LED Status
Meaning
1
Power
Solid orange
Switch is unable to connect to the Meraki cloud
Flashing green
Firmware upgrade in process
Solid green
Switch is fully operational and connected to the Meraki cloud
    Off Switch does not have power
2 Restore N/A Restore button to clear switch IP and local configuration settings
3
Switch Ports
Off
No client connected
Solid orange
PoE Active on MS220-8P
Solid green
1000 Mbps (10000 Mbps on SFP+, MS42/P Only)
In addition, there is a RESTORE button available on the front panel.
Insert a paper clip if a device restore is required.
  • A brief, momentary press: To delete a downloaded configuration and reboot.
  • Press and hold for more than 10 sec: To force the unit into a full factory restore.
MS220-8 Series back panel
Additional functions on the back panel are described below, from left to right.
Power input Power cords may be ordered separately.
Equipment is to be used only in a restricted access location and installed/operated only by trained service personnel.
Mounting hardware
MS220-8 and MS220-8P models come with unique and easy-to-use integrated mounting slides for one-step mounting.
Connecting to the Meraki Cloud
All Meraki MS devices must have a logical network connection and valid IP address. An IP address can be assigned dynamically through a local DHCP server or statically through a local management interface. For details on getting started, read the Quick Start.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
