Home > Switches > Other Topics > Configure MS Swtich to Pickup an IP Address from a Specific DHCP Range
Table of contents
No headers
Connect to the switch you want to configure and point the browser to "switch.meraki.com" the switch serial number is the username with password, under "Uplink configuration" select DHCP and specify the VLAN you want the switch to pickup an IP address on.
In the example below, the switch to always pickup an IP in VLAN 60.
You must to post a comment.
Last modified
19:19, 2 Feb 2015
Tags
This page has no custom tags.
Classifications
Article ID
Contact Support
Open a Case
