Home > Security Appliances > Firewall and Traffic Shaping > Layer 3 and 7 Firewall Processing Order
Firewall rules on MR Series Access Points and MX Series Security Appliances are processed in a top down fashion, with Layer 3 rules being processed, followed by Layer 7 rules. Unless traffic is explicitly blocked by at least one rule, it will be allowed through by a default allow all rule.
For clarity, this article will cover a few examples of how this flow would work.
  1. Reference L3 and L7 rules
  2. Traffic allowed by default
  3. Traffic blocked by Layer 3 rule
  4. Traffic blocked by Layer 7 rule
  5. Processing flow diagram
Reference L3 and L7 Rules
For the examples to follow, the Layer 3 (L3) and Layer 7 (L7) firewall rules shown below will be used, with a Security Appliance network used for reference.
Traffic Allowed by Default
By default, outbound traffic will be allowed through the firewall unless explicitly blocked by at least one L3 or L7 rule. In this example, SSH (TCP port 22) traffic will be allowed through the firewall because there are no configured L3 or L7 rules that act upon it.
Layer 3 Rules
  1. No Match
  2. No Match
  3. No Match
Layer 7 Rules
  1. No Match
Traffic Blocked by Layer 3 Rule
In this example, SMTP traffic (TCP port 25) will be blocked by the L3 firewall, because rule 3 under layer 3 explicitly blocks it. Layer 7 rules would be ignored because the traffic has already been blocked.
Layer 3 Rules
  1. No Match
  2. No Match
  3. Matched - Traffic blocked
Layer 7 Rules
  1. Not processed because traffic was already blocked
Traffic Blocked by Layer 7 Rule
The MR access point and MX security appliance differ slightly in their processing of L7 firewall rules after the L3 firewall. On the MR, if traffic matches an allow rule on the L3 firewall, that traffic will bypass the L7 firewall altogether. On the MX, if traffic matches an allow rule on the L3 firewall, it can still be blocked by an L7 firewall rule.
On the MX, HTTP traffic (TCP port 80) to Facebook.com will be blocked by the L7 firewall, because rule 1 under layer 7 explicitly blocks it, even though the traffic was allowed through the layer 3 firewall.
Layer 3 Rules
  1. Matched - Traffic allowed through L3 firewall
  2. Not processed
  3. Not processed
Layer 7 Rules
  1. Matched - Traffic blocked
On the MR, HTTP traffic (TCP port 80) to Facebook.com will be allowed through the firewall, because rule 1 under layer 3 explicitly allows it.
Layer 3 Rules
  2. Not processed
  3. Not processed
Layer 7 Rules
  1. Not processed because traffic was already allowed
MX Processing Flow Diagram
MR Processing Flow Diagram
You must to post a comment.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
