Home > Security Appliances > Firewall and Traffic Shaping > Using Packet Prioritization on a Traffic Shaping Rule
Table of contents
No headers
Traffic priority is a way of ensuring that specific applications or subnets are guaranteed a certain amount of the uplink bandwidth at all times. Traffic priorities only come into play when the network is using all of the pre-configured bandwidth on the uplink. Take note that this bandwidth can change when link aggregation is enabled because the uplink changes per stream based upon the ratio specified.
Specifying a traffic shaping rule as High, Normal, Low guarantees a certain fraction of the uplink to each priority level. The ratios are as follows:
  • High       4/7
  • Normal   2/7
  • Low       1/7
By default all traffic is marked as having a Normal priority level. Traffic shaping rules that are marked at the same priority level share the same fraction of their respective levels. For instance if there are 5 traffic shaping rules marked as High priority on a 10Mbps pipe each rule would have access to ~1.1Mbps.
Each traffic rule supersedes each rule below it and the rules below it must strictly adhere to their fractional bandwidth limits. For instance if there is a high traffic shaping rule but no low traffic shaping rules configured then the the high priority traffic would have access to 5/7 of the available bandwidth on the uplink and normal traffic would have 2/7s. Additionally if there are no high priority traffic shaping rules then normal priority traffic gets 6/7 of the bandwidth and low priority gets 1/7 of the uplink's bandwidth.
Here are some examples on a 7 Mbps Up link:
Case 1:
With 2 high priority rules each get 2Mbps for a total of 4Mbps
With 2 normal priority rules each get 1Mbps for a total of 2Mbps
With 2 low priority rules each get .5Mbps for a total of 1 Mbps
Case 2:
With 1 normal priority rule it gets 2Mbps for a total of 2Mbps
With 10 low priority rules each get .1Mbps for a total of 1 Mbps
Case 3:
With 2 high priority rules each get 3Mbps for a total of 6Mbps
With no normal priority rules there is a total of 0Mbps
With 5 low priority rules each get .2Mbps for a total of 1 Mbps
Case 4:
With 5 high priority rules each get 1Mbps for a total of 5Mbps
With 4 normal priority rules each get .5Mbps for a total of 2Mbps
With no low priority rules there is a total of 0Mbps
Case 5:
With no high priority rules there is a total of 0Mbps
With 3 normal priority rules each get 2Mbps for a total of 6Mbps
With 2 low priority rules each get .5Mbps for a total of 1Mbps
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
