Home > Security Appliances > Installation Guides > MX600 Installation Guide
This document describes how to install and set up the MX600 security appliance. Additional reference documents are available online at: www.meraki.com/library/products.
MX600 Overview
The Meraki MX600 is an enterprise security appliance designed for for distributed networks that require remote administration. It is ideal for network administrators who demand both ease of deployment and a state-of-the-art feature set. The MX600 appliance provides the following new features:
  • Four bypass (fail-to-wire) ports
  • USB port, to support approved 3G/4G cards for failover to cellular networks.
  • Support for two interface modules. Each module can have either eight 1Gbit RJ45 or SFP ports or two 10Gbit SFP+ ports.
  • Dedicated management port.
  • Rail-kit for rack mounting
Package contents
In addition to the MX600, the following are provided.
The MX600 front panel
Ports and Status Indicators
The MX600 uses LEDs to inform the user of the device's status. When the device powers on, all the Internet LEDs flash twice. Additional functions are described below, from left to right.
Item
Function
LED Status
Meaning
1
Power
Solid orange
Power is applied
Flashing green
Operation in progress
Solid green
Fully operational
2
Warning
Off
During boot or no USB link
Orange
Device requires attention.
Dashboard will contain additional information
3
Disk status
Off
No disk activity
Orange
Requires attention
Green
Disk activity
4
Bypass status
Off
WAN and LAN ports are separated
  Green
WAN and LAN ports are connected through virtual wire
Additional functions on the front panel are described below, from left to right.
Reset button
Insert a paper clip if a reset is required.
  • A brief, momentary press: To delete a downloaded configuration and reboot.
  • Press and hold for more than 10 sec: To force the unit into a full factory reset.
USB port
USB 2.0 for 3G/4G wireless cards. Traffic status is indicated by the USB LED.
Interface modules 1 - 2
Interface modules for extended connectivity.
SFP Combo ports
For optional SFP-SX (fiber) or SFP-TX (RJ45 copper) GbE connectivity. The functionality of ports 8 and 8F, and ports 9 and 9F, is mutually exclusive. Only one port of a pair is supported at a time.
Using MX Expansion Slots and Modules
The MX600 has 2 expansion slots which can accept the following Meraki Interface Modules:
  • IM-8-CU-1GB: Meraki 8 x 1 GbE Copper Interface Module for MX600 and MX600.
  • IM-8-SFP-1GB: Meraki 8 x 1 GbE SFP Interface Module for MX600 and MX600.
  • IM-2-SFP-10GB: Meraki 2 x 10 GbE SFP+ Interface Module for MX600 and MX600.
When replacing an interface module, follow the steps below:
  1. Power down the MX600. Interface Modules are not hot-swappable.
  2. Insert the new interface module or modules.
  3. Power up the MX600.
  4. Dashboard will automatically recognize the new module or modules.
Please take caution when working with Interface Modules. Failure to follow the process above can corrupt the unit and void warranty.
The MX600 back panel
Please note that the serial number is located on the product label at the back panel of MX600.
Mounting hardware
The mounting hardware includes a rack mount rail kit. When installing the device, make sure that there is sufficient space between the rear of the rack and other obstacles to ensure adequate airflow.
Safety guidelines
Regardless if you are using a wall power outlet (MAINS) or any other type of power connection (e.g., a UPC device), always ensure that the power cord can be readily disconnected from the hardware unit.
Disconnect all power by turning off the power and unplugging the power cord before installing or removing a chassis or working near power supplies.
Lithium Battery Caution:
Risk of explosion could occur if battery is replaced by an incorrect type. Please dispose of used batteries according to the recycling instructions of your country.
Connecting to WAN
All Meraki MX devices must have an IP address. This section describes how to configure your local area network before you deploy it. A local management web service, running on the appliance, is accessed through a browser running on a client PC. This web service is used for configuring and monitoring basic ISP/WAN connectivity.
Setting up a static IP address
To ensure that the client PC is redirected to the local web service in the following step, you must disable all other network services (ex: wi-fi) on your client machine.
Do the following to configure basic connectivity and other networking parameters:
  1. UUsing a client machine such as a laptop, connect to the management port of the MX.
  2. Using a browser on the client machine, access the appliance's built-in web service by browsing to http://setup.meraki.com. (You do not have to be connected to the Internet to reach this address)
  3. Click Uplink configuration under the Local status tab. The default credentials use the device serial number as the username, with a blank password field.
  4. Choose Static for the IP Assignment option.
  5. Enter the IP address, subnet mask, default gateway IP and DNS server information.
Setting up a DHCP IP address
By default all MX devices are configured to DHCP from upstream WAN / ISP servers. Simply plug the MX's WAN / Internet port to your upstream circuit and wait a few minutes for the unit to negotiate a DHCP address.
When the WAN connection is fully enabled, Internet LED will turn green.
Additional settings
Please note that all these settings below are accessible only via the local management console.
Setting VLANs
If your WAN uplink is on a trunk port, choose VLAN tagging > Use VLAN tagging and enter the appropriate value for VLAN ID for your network.
Setting up secondary WAN interface (dual WAN)
You can toggle the LAN2 port between LAN and Internet, through Uplink configuration under the Local status tab.
Setting PPPoE
PPPoE authentication may be required if you are connecting MX device to a DSL circuit. You need to know your authentication option and credentials (supplied by your ISP) in order to complete these steps.
  • Choose Connection Type > PPPoE.
  • Select your Authentication option.
  • If you select Use authentication, enter appropriate values for Username and Password.
Web proxy settings
These settings take effect if the MX device has to fall back to using HTTP to contact the Cloud Controller. By default, web proxy is disabled. To enable web proxy, do the following:
  • Choose Web proxy > Yes.
  • Enter values as appropriate for Hostname or IP and Port.
  • If you require authentication, choose Authentication > Use authentication, and enter appropriate values for Username and Password.
To apply all configuration settings to the appliance, be sure to click Save Settings at the bottom of the page.
Configuring physical link settings
To configure physical link settings on the Ethernet ports, click Local status > Ethernet configuration. You can enable half duplex, full duplex, and autonegotiation, as well as set 10- or 100-Mbps data rates.
You must to post a comment.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
