| Client | Event type | Details | ||
| Mar 29 13:14:04 | iOS | Client IP conflict | MAC: F0:DE:F1:39:1C:7B also claims IP: 192.168.64.2 | ||
| Mar 29 13:14:04 | Windows | Client IP conflict | MAC: 64:20:0C:4D:DC:B9 also claims IP: 192.168.64.2 | ||
Following the example above, a user connects to a home network and corporate network that use the same 192.168.64.0/24 subnet scheme. The iOS device received a DHCP assigned IP address of 192.168.64.2 from the home network. When the user takes the iOS device into work and connects to the corporate network, it attempts to re-use IP address 192.168.64.2 before obtaining an IP address via DHCP from the corporate server. Because a machine named Windows on the corporate network is already assigned the IP address 192.168.64.2, the iOS device is now in conflict. The MX detects this and logs an IP conflict event for IP address 192.168.64.2.
A packet capture above shows in detail how iOS (64:20:0c:4d:dc:b9) attempts to re-use IP address 192.168.64.2 at link up. The device sends ARP requests to locate 192.168.64.1, the default gateway used on the home network, when connecting to the corporate network. In this instance, DHCP clients on the users home network and corporate network even share the same default gateway IP address configuration. The MX, 192.168.64.1, which is the default gateway on the corporate network detects an IP conflict and sends an ARP response back to iOS. On the corporate network a machine named Windows (f0:de:f1:39:1c:7b) is already using 192.168.64.2 and actually received this IP address via DHCP from the MX so the iOS device is now in conflict.
After a short period of time, in milliseconds, iOS realizes it is in conflict and stops using 192.168.64.2. Now the device attempts to obtain an IP address using DHCP. When the DHCP process completes successfully, iOS gets a different IP address from the DHCP server, 192.168.64.252, which is not in conflict on the corporate network.
In conclusion, this issue can be prevalent on any IP network where iOS devices are connected. The problem is not specific to the MX, Dashboard, or any other networking device. In most cases, this IP conflict occurs so briefly that it does not affect network performance and is merely a nuisance.
Please refer to the following link with similar scenarios reported by other users at the Apple's discussion site and contact Apple support for more assistance.
https://discussions.apple.com/thread/3681645?start=0&tstart=0
See also:
Troubleshooting DHCP conflicts
Using Packet capture to troubleshoot client-side DHCP issues
Detecting Network Attachment in IPv4 - Apple RFC for this behavior
