In a distributed deployment of locations connected via a site-to-site VPN, a network administrator may need to have address translation performed on traffic traversing the site-to-site VPN. A 1:1 subnet translation can be used in cases where multiple locations have the same subnet present, but both need to participate in the site-to-site VPN. Alternatively, administrators may need to conserve IP space for large deployments. For this, 1:M NAT can be used to translate entire subnets into a single IP address that is exported across the site-to-site VPN.
Note: This feature is only supported for Auto VPN and is not intended to work with non-Meraki VPN peers.
Note: The features described in this article must be enabled by Cisco Meraki Support.
VPN subnet translation allows for a subnet that is allowed in the site-to-site VPN to be translated to a different, equally sized subnet. This option is ideal for deployments where the same subnet is used in multiple locations and each of those subnets need to have access to the site-to-site VPN.
To configure VPN subnet translation:
Please consider the following example:
When VPN subnet translation is configured, the MX will check the source IP address against a address translation table. When 192.168.128.44 attempts to send traffic to the web server across the VPN, the source IP address is evaluated to be contained within the local subnet of 192.168.128.0/24, which requires a translation to be performed. The MX will then map the client's IP to the equivalent IP in the translated subnet. When the example client's traffic egresses the site-to-site VPN, it will have an IP address of 10.15.30.44.
If VPN subnet translation is configured, the translated subnet will automatically be advertised to all remote site-to-site VPN participants. In this example, in order for the web server at 172.16.30.8 to communicate with the example client, traffic must be sent to 10.15.30.44 (the equivalent IP offset within the translated subnet). When the web server's traffic is sent to 10.15.30.44 and received by it's local MX, it will be routed to the appropriate remote MX and the destination IP address will be translated back to 192.168.128.44 before it egresses the MX's LAN.
1:M NAT for VPN allows for a subnet that is allowed in the site-to-site VPN to be translated to a single IP address. This option is ideal for large deployments where IP addresses within the site-to-site VPN must be conserved.
The functionality discussed in this part of the article is only available in beta.
To configure 1:M NAT for VPN:
When 1:M NAT for site-to-site VPN is configured, the MX will check the source IP address against a address translation table. When 192.168.128.44 attempts to send traffic to the web server across the VPN, the source IP address is evaluated to be contained within the local subnet of 192.168.128.0/24, which requires a translation to be performed. The MX will then map the source IP address to the IP address specified in the VPN subnet. When the example client's traffic egresses the site-to-site VPN, it will have an IP address of 10.15.30.18.
If 1:M NAT for VPN is configured, the translated subnet (10.15.30.18 in this example) will automatically be advertised to all remote site-to-site VPN participants. In this example, response traffic from the web server must be sent to the client using a destination IP address of 10.15.30.18. When the web server's traffic is sent to 10.15.30.18 and received by it's local MX, it will be routed to the appropriate remote MX.
If the web server's traffic is in response to a previously established VPN flow originating from the client, then it will be allowed through the VPN, the destination IP address will be translated back to the original client's, and the traffic will be forwarded to the original client. If the traffic is not in response to an existing flow that was originated by the client, the traffic will be dropped. Effectively, when 1:M NAT for VPN is used, the NAT is stateful and unsolicited inbound traffic will not be allowed, even if the site-to-site VPN firewall rules would permit it.
