Home > Security and SD-WAN > Client VPN > Client VPN clients cannot connect to machines with dual-nic's
Table of contents
No headers
Client VPN is valuable for the fact that it can connect remote users to the internal LAN securely. Sometimes a Client VPN may have connection issues to devices on the LAN with dual NIC's. Often times these machines have a WAN and a LAN NIC. If you cannot connect or ping to these devices from a Client VPN check the routes of the Machines in question. Do this by using the command "route print" in the command prompt. Check that there are gateways set for the LAN and not just the WAN.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
