Cisco Meraki AI Assistant Prompting Guide: Deep Reasoning Mode
A collection of ready-to-use prompts for investigating, optimizing, troubleshooting, and monitoring Cisco Meraki networks with Deep Reasoning Mode.
This guide has ready-to-use prompts for every major network task. Pick one that matches what you need, copy it into the AI Assistant, and the agent will pull live data from your network and tell you what it finds.
How to use this guide • Pick a prompt that fits what you are trying to do • Copy it into the AI Assistant with Deep Reasoning Mode turned on • The agent pulls live data from your network. Give it anywhere from 30 seconds to 10 minutes depending on the scope • If the prompt has text in [brackets], replace it with your actual values before you send it ORG-WIDE prompts look across your entire organization. NETWORK prompts work on whichever network you have selected. |
Network Audit and Optimization
Use these prompts to get a clear picture of where your network stands before problems show up.
Lifecycle and Inventory
ORG-WIDE |
Design and Architecture
ORG-WIDE |
NETWORK |
NETWORK |
Capacity Planning
ORG-WIDE |
NETWORK |
NETWORK |
NETWORK |
ORG-WIDE |
Tip: If a site comes back with more than 365 days to saturation on client counts, check the airtime section. Airtime congestion often becomes the real problem before client density gets there. |
Wireless Performance
NETWORK |
NETWORK |
NETWORK |
DHCP Health
NETWORK |
NETWORK |
Network Health
Quick checks for when you want an immediate read on what is happening right now.
NETWORK |
NETWORK |
Troubleshooting
Describe what you are seeing and the agent will dig into WAN, switching, and wireless data to figure out where the problem is coming from.
Outages and Connectivity
NETWORK |
Tip: Replace [site name] with the name of the site as it appears in your Meraki dashboard. |
NETWORK |
Tip: Replace [start time] and [end time] with the actual times, for example 2:15 PM and 2:45 PM. |
NETWORK |
Performance and Slowness
NETWORK |
NETWORK |
NETWORK |
WiFi Problems
NETWORK |
NETWORK |
NETWORK |
NETWORK |
NETWORK |
VPN Issues
NETWORK |
NETWORK |
NETWORK |
Wired and Switching
NETWORK |
NETWORK |
NETWORK |
NETWORK |
Changes, Alerts and Security
Use these when you need to understand what changed, what is alerting, or whether there is something suspicious going on.
Changes and Impact
NETWORK |
NETWORK |
Alerts and Events
NETWORK |
NETWORK |
NETWORK |
NETWORK |
Security
NETWORK |
NETWORK |
NETWORK |
Power User Tips
A few ways to get more out of every prompt.
Be specific to get better answers Instead of: Troubleshoot wireless capacity. Try this: Look at wireless capacity for this network. Show me the client load and channel utilization per access point by band, and for any that are overloaded tell me specifically what you would recommend. |
Follow up to go deeper After an initial result, you can ask a more targeted question to keep digging: You found 3 switches with high PoE utilization. For each of them, show me which ports are drawing the most power and whether any of those devices could be moved to a different switch. |
Ask across multiple domains at once The agent can connect findings from WAN, wireless, and switching together in one response: Do the VPN tunnel drops seem to line up with the WAN utilization spikes you found earlier? |
Submitting Feedback
After every response, use the thumbs up or down buttons in the AI Assistant. Your rating is captured automatically.
• Thumbs up: select Correct or Helpful so we know what is working
• Thumbs down: select Incorrect, Not helpful, or Unsafe so we know what to fix
• The comment box is optional but useful. Even a short note like 'missed the secondary uplink' helps us improve quickly
For longer feedback or to continue the conversation, email cisco-agenticops@cisco.com.
