Managing Access for Organization 802.1X Users
You can manage network access for certain access types on the Organization > Monitor > Users page. Use the users list for bulk changes, and the Users detail page for individual access updates. This page also supports access management for other product
Access Manager
To manage access based on user attributes and configured rule sets, integrate with Access Manager.
Access Types
Organization Users can be authorized for access to network zones. Currently, administrators can manage the following types of access:
For 802.1X Users
  • Switch Access Policies
  • Enterprise Splash with Meraki Auth
  • Enterprise Meraki Auth
For Guest Users, see additional documentation.
  • Splash with MerakiAuth
  • Client VPN (Meraki-hosted users only)
Configuring 802.1X User Access
Currently, administrators can manage the following types of access for 802.1X user accounts:
Account Type
Zone
Configuration
Authentication Type
802.1X
Wireless SSID
Enterprise
Meraki Cloud Radius
802.1X
Switch Access Policy
Enterprise
Meraki Cloud Radius
To manage access for Guest accounts, see additional documentation.
Wireless 802.1X Access via Meraki Cloud Radius
Grant access (bulk)
To authorize access for multiple users:
1. Navigate to Organization > Monitor > Users, and select the target users.
2. Click Edit Access on the action menu
3. Select Wireless 802.1X
4. In the Edit Access drawer, select the target networks and SSIDs from the dropdowns of available access zones.
5. Set a duration for the access
  • “Does not expire” gives access with an indefinite end date
  • “Limited” grants access for a defined number of days (Duration) or until an exact calendar date (Expiration Date)
  • “Do not authorize” will remove existing access for the given network and SSID
This action will fail if the target users do not have an 802.1X account. You can create a 802.1x account using one of the following methods:
  • From the user list page, click the Add User button from the action bar and select 802.1X from the dropdown menu
  • Click the Add user for 802.1X access button on the user's details page for an individual target user
Grant access (single user)
To authorize access for a single user:
1. Navigate to Organization > Monitor > Users, and click the target user.
2. On the user details page, navigate to the Access section.
3. Click the Add dropdown and select Wireless 802.1X access
4. In the Add Access drawer, select the networks and SSIDs where Wireless 802.1X access should be granted.
Edit access time period (single user)
To edit the expiration criteria for Splash access for a single user:
3. Select the currently assigned Wireless 802.1x access types from the list
4. Click the Edit dropdown and select Change access time period
Revoke access (single user)
To revoke 802.1x access for a single user:
1. Navigate to the Organization > Monitor > Users page and click the target user.
2. On the user details page, navigate to the Manage Access section
3. Select the target authorizations in the list to remove by enabling the checkmark next to each option.
3. Click Revoke Access.
Users with Switch Access Policies
This configuration supports access for Client VPN over L2TP.
Grant access (bulk)
To authorize access for a multiple users:
1. Navigate to Organization > Monitor > Users and select the target users.
3. Select Switch Access
4. In the Edit Access drawer, select the target networks from the available access zones.
1. Navigate to Organization > Monitor > Users and click the target user.
3. Click Add and select Switch Access.
4. In the Switch Authorization drawer, select the target zones where the user should be authorized.
Edit access (bulk)
To edit the network scope or the access period for Client VPN access for multiple users:
1. Navigate to the Organization > Monitor > Users page.
2. Select the target users from the list by checking the box next to each user with access you want to edit.
3. Click Edit Access and select 802.1X to make changes.
4. In the Edit Switch Access drawer, change the networks or access period, and click Save
Edit access time (single user)
To edit the expiration criteria for 802.1X access for a single user:
2. Select the desired authorizations from the list by checking the box next to each option you want to edit.
3. Click Edit to make changes and select Change access time period
4. In the Change access time period popup, change the authorization access period, and click Save
To revoke Switch access for a single user:
2. On the user details page, navigate to the Access section, and select the target authorizations in the list to remove by enabling the checkmark next to each option.
4. Click Revoke Access.
