FAQ: SNMPv3 DES and MD5 Deprecation
Overview
Cisco is enhancing certain default settings on our products to introduce improved security features and retire outdated security functionalities. In our effort to drive resilient infrastructure, we encourage our users to adopt these modern capabilities and align with current best practices. To learn more about Resilient Infrastructure, please visit www.cisco.com/go/ri.
For SNMPv3, Cisco Meraki will require AES-128 privacy and SHA-2 or SHA-1 authentication. A supported SHA-2 algorithm is strongly recommended over SHA-1 (sometimes labeled as “SHA,” which remains supported for backward compatibility and is not being retired as part of this change). Cisco Meraki is retiring support for DES privacy and MD5 authentication in SNMPv3.
Cisco Meraki provides two independent SNMP polling methods:
  1. SNMP device polling
    Your SNMP manager polls your Cisco Meraki devices directly. Configure this method under Network-wide > Configure > General > Reporting. DES support will end when an affected device runs firmware that removes it. MD5 is already unavailable for device polling, so this change does not require an authentication migration for device polling.
  1. SNMP dashboard polling
    Your SNMP manager polls the Meraki Dashboard. Configure this method under Organization > Configure > Settings > SNMP. Support for DES privacy and MD5 authentication is scheduled to end on May 31, 2027, regardless of device firmware.
Frequently Asked Questions
What is happening?
SNMP Device polling. Cisco Meraki is removing DES privacy in affected device firmware releases. SNMP device polling does not currently support MD5 authentication, so this change only removes DES privacy.
SNMP Dashboard polling. Cisco Meraki is removing DES privacy and MD5 authentication from SNMP dashboard polling.
Why is this change happening?
DES and MD5 are legacy cryptographic algorithms. Cisco Meraki is retiring DES for SNMPv3 privacy and MD5 for SNMPv3 dashboard authentication. This change strengthens the security of SNMPv3 polling and aligns with Cisco’s Resilient Infrastructure initiative.
When is this change happening?
This depends on the SNMP method you are using. See below.
DES support for device polling ends when an affected device runs firmware that removes it. The table lists the first planned firmware release without DES support for each product line. DES will remain unavailable in later releases.
Product Line
Firmware Release
MR
CWC 27.2 (formerly known as MR 34.1)
MX
27.2
MS
27.2
Please note, release plans may change. Check the release notes for your product before upgrading, and be sure to migrate any DES configuration in advance.
Support for DES privacy and MD5 authentication is scheduled to end on May 31, 2027. This cutoff applies regardless of the firmware installed on your Meraki devices.
What is the impact?
Device polling: If device polling uses DES, upgrading an affected device to a firmware that removes DES will prompt you to change the privacy mode to AES-128 before an upgrade can be scheduled. After you make this change on the dashboard, also update your SNMP manager configuration. Please note that SNMPv3 settings are applied at the network-wide level.  If your SNMP manager still uses DES, it cannot poll the devices in the network.
Dashboard polling: After the scheduled May 31, 2027 deadline, polls that use DES privacy or MD5 authentication will fail. In either case, your SNMP manager will receive no new data from affected polls, and dependent monitoring views or alerts may stop updating.
What action do I need to take?
Perform the following steps.
1. Identify which SNMP method you are using
SNMP device polling is configured under Network-wide > Configure > General > Reporting.
SNMP dashboard polling is configured under Organization > Configure > Settings > SNMP. Check both locations.
2. Check your current settings
For SNMP device polling, check whether DES privacy is configured in the Network-wide setting or in your SNMP manager.
For SNMP dashboard polling, check whether DES privacy or  MD5 authentication is configured in the Organization setting or in your SNMP manager.
If neither polling method uses an affected setting, this deprecation requires no configuration change.
3. Plan the migration
Schedule the changes for each polling method you use before its applicable cutoff.
Device polling. Check your product’s release notes and schedule the device-polling change before upgrading to firmware that removes DES. The configuration of the SNMP manager you are using for polling those devices would also need to be updated to AES-128 to match the SNMP configuration on the Cisco Meraki devices.
Note: If migration from DES is not currently possible, you may choose to remain on a device firmware version that still supports the legacy setting. This approach should be considered temporary while planning the transition to AES-128.
Dashboard polling. Complete any DES or MD5 migration before the scheduled May 31, 2027, deadline, regardless of device firmware. The configuration of the SNMP manager you are using to poll the Cisco Meraki dashboard would also need to be updated accordingly.
If you use both SNMP methods, you can schedule the SNMP device and dashboard polling migrations separately. Ensure the configuration of your SNMP manager is set correctly for each destination it is polling, whether it is Cisco Meraki devices directly, or the Cisco Meraki dashboard.
4. Update and validate
Make the relevant changes in Meraki Dashboard and your SNMP manager, then confirm that polling and dependent monitoring work. If you are using both methods, make the relevant changes for each SNMP method.
Device polling. Before installing the new affected firmware that removes DES, replace DES privacy with AES-128 under Network-wide > Configure > General > Reporting. Update your SNMP manager to match, and verify polling before and after the upgrade. The SNMP authentication does not need to change since MD5 is already unavailable with this SNMP method.
Dashboard polling. Before May 31, 2027, under Organization > Configure > Settings > SNMP, replace DES with AES-128 if DES privacy is enabled, and replace MD5 with a supported SHA-2 authentication option if MD5 is enabled. Make matching changes in your SNMP manager and verify polling. If your manager does not support SHA-2, use SHA-1 instead of MD5.
For additional configuration guidance, see How to Set Up SNMP Monitoring for Meraki Devices.
Who do I contact if I have additional questions?
If you require assistance with your migration plan or have specific questions regarding your environment, please contact Meraki Support.
  • Was this article helpful?
