Configuration Settings Payload - Restrictions
Meraki is committed to providing an inclusive experience for our customers. The following section contains language that does not adhere to our standards for inclusivity. We are working with our partners to replace it.
Apple MDM Restrictions for iOS Devices
Cross-platform Restrictions:
Setting
Functionality
Supervised Enrollment Required?
Minimum Supported OS
Camera:
  • Allow Use of Camera
If disabled - Cameras are disabled and the Camera icon is removed from the Home Screen in iOS and iPadOS. Users can’t take photographs or videos.
Yes
iOS 5 or iPadOS 13.1
Device Functionality:
  • Allow installing apps
If disabled - App Store is disabled and its icon is removed from the Home Screen. Users can’t install or update apps.
This applies to App Store apps, marketplace apps, and locally installed apps (using Configurator, Xcode, etc).
**In iOS 10 or later, MDM app commands can still be used.
Yes
iOS 10 or iPadOS 13.1
  • Allow screen capture
When disabled - Users can’t save a screenshot or recording of the screen.
No
  • Allow device assistant (Siri/Cortana)
When disabled - Siri can't be used.
No
  • Allow Siri while locked
    • **Allow device assistant must be enabled for this setting
When disabled - Siri responds only when the device is unlocked.
No
iOS 5.1 or iPadOS 13.1
Apple Restrictions- iOS:
Setting
Functionality
  • Allow voice dialing (while device locked)
If disabled -  the system disables voice dialing if the device is locked with
a passcode.
No
Only Supported on iOS versions iOS 4 - iOS 16.
**This feature has been deprecated by Apple as of iOS 17.
  • Allow automatic sync when roaming
If disabled, Devices that are roaming sync only when an account is accessed by the user.
No
  • Allow Passbook notifications while locked
If disabled, the system hides Passbook notifications from the lock screen.
No
iOS 6 +
  • Allow in-app purchases
If disabled, the system prohibits in-app purchasing.
Yes
  • Force user to enter iTunes Store password for all purchases
If enabled, the system forces the user to enter their iTunes password for each transaction
No
Only Supported on iOS versions iOS 6 - iOS 16.
  • Show Control Center in lock screen
If disabled, the system prevents the Control Center from appearing on the Lock screen.
Users can’t swipe up to view Control Centre.
No
iOS 7 or iPadOS 13.1
  • Show Notification Center in lock screen
Users can’t view the Notification history when the screen is locked; however, they can still view a Notification when it appears.
No
  • Show Today view in lock screen
If disabled, users can’t swipe down to see the Notification Centre using Today View in the Lock Screen.
No
  • Allow remote screen observation by the Classroom app
    • **Screenshot feature must be enabled for this.
If disabled, the system disables remote screen observation by the Classroom app.
Yes
iOS 12+
  • Do not containerize work data and contacts from unmanaged apps
Unmanaged apps will have access to work data and contacts
No
iOS 12+
  • Do not containerize personal data and contacts from managed apps
Managed apps will have access to work data and contacts
No
iOS 12+
iOS can natively separate work and personal data and contacts. For more information, see our article on iOS containerization.
  • Require managed pasteboard
Helps control the pasting of content from an app that’s using Open In management by following the Managed Open In restrictions in force. Apple apps that work with the managed pasteboard include Calendar, Files, Mail and Notes. Third-party apps are controlled based on whether they’re managed. When a user attempts to paste content where it isn’t permitted, a Paste Not Allowed notice appears along with the organisation’s name (which can be changed using the Settings command). Apps also can’t request items from the pasteboard when this restriction is used and the content crosses the managed boundary.
Default is off.
No
iOS 15 or iPadOS 15
  • Allow Handoff
Users can’t use Handoff with their Apple devices.
No
iOS 8 or iPadOS 13.1
  • Require passcode on outgoing AirPlay pairing requests
If enabled, the system forces all devices receiving AirPlay requests from this device to use a pairing password.
No
iOS 7.1+
  • Require passcode on incoming AirPlay pairing requests
No
iOS 7.1+
  • Force paired Apple Watch to use Wrist Detection
If enabled, Apple Watch locks automatically when it’s removed from the user’s wrist. It can be unlocked with its passcode or the paired iPhone.
Default is off.
No
iOS 8.2+ and iPadOS 13.1+
  • Allow user to add App Clips
If disabled, users can’t add App Clips. Any existing App Clips are removed when this restriction is applied
Yes
iOS 14 and iPadOS 14
  • Disallow sharing of managed documents with AirDrop
If enabled, the system considers AirDrop to be an unmanaged drop target
No
iOS 9
  • Allow managed apps to write contacts to unmanaged contacts accounts
Managed Apps can edit contacts to unmanaged accounts, even if Managed Apps are prevented from editing unmanaged destinations
Default is off
No
iOS 12 and iPadOS 13.1
  • Allow unmanaged apps to read from managed contacts accounts
Unmanaged apps can read contacts from managed accounts, even if unmanaged apps are prevented from reading to managed destinations
Default is off
No
  • Allow server-side Siri logging
if enabled, Allows Siri from logging to its server
Yes
iOS 12.2
  • Allow shared device temporary session
If disabled, Shared iPad won’t allow a Temporary Session
Yes
iPadOS 13.4
  • Allow NFC
If disabled, the system disables NFC. Prevents users from using built-in NFC (near–field communications) hardware in compatible devices.
Yes
iOS 14.2
  • Allow Apple personalized advertising
If disabled, users’ data won’t be used by the Apple advertising platform to deliver personalized ads.
No
  • Allow unpaired external boot to recovery
If enabled, the system allows unpaired devices to boot devices into recovery.
Previously, (iOS 14 and below) any external host computer was allowed to restart a connected iPhone or iPad into the recoveryOS (also known as Recovery Mode), completely erase it, restore iOS or iPadOS over a USB connection without any other physical interaction with the device. iOS 14.5 and iPadOS 14.5 or later, prevent this behaviour by default.
Yes
  • Force on-device-only dictation
Prevents dictated content from being sent to Siri servers for processing. Supported on the following devices.
  • iPhone XR, iPhone XS, iPhone XS Max or later
  • iPad Air (3rd generation), iPad mini (5th generation), iPad Pro (2nd generation) or later
Default is off.
No
  • Force on-device-only translation
Won’t let the device connect to Siri servers for the purposes of translation.
Default is off
No
  • Enforce SSID allowlisting (Deprecated)
This Feature has been deprecated by Apple, Please use the restriction payload key "Force WiFi to Allowed Networks Only" Instead
N/A
N/A
  • Force WiFi to Allowed Networks Only
    • ** The WiFi Network payload must be pushed on the device before the profile, otherwise, the device will not be able to connect to any network and will need to be DFU'd.
If enabled, the system limits the device to only join Wi-Fi networks set up through a configuration profile.
Important: If the Wi-Fi network isn’t available, the device can’t be managed.
Yes
iOS 14.5
  • Allow Mail Privacy Protection
If disabled, the system disables Mail Privacy Protection on the device.
Yes
iOS 15.2
  • Preserve eSIM on erase
If enabled,  the system preserves eSIM when it erases the device due to too many failed password attempts or the Erase All Content and Settings option in Settings > General > Reset
The system doesn’t preserve eSIM if Find My initiates erasing the device.
Yes
iOS 17.2 and iPadOS 17.2
  • Allow Web Distribution App Installation
If disabled, prevents installation of apps directly from the web
Yes
iOS 17.4
  • Allow Auto Dim
If disabled, Prevents a device with a Tandem OLED screen from dimming.
Yes
iPadOS 17.4
  • Allow eSIM Outgoing Transfers
If disabled , prevents the transfer of an eSIM from the device on which the restriction is installed to a different device.
Yes
iOS 18 and iPadOS 18
  • Allow Genmoji
If disabled, prevents users from creating a Genmoji.
Yes
  • Allow Image Wand
If disabled, Prevents users from using Image Wand.
Yes
  • Allow Writing Tools
If disabled, prevents Apple Intelligence writing tools.
Yes
  • Allow Image Playground
If disabled, prevents users from using Image Playground.
Yes
  • Allow Call Recording
If disabled, prevents the use of call recording on iPhone.
Yes
iOS 18
  • Allow Personalized Handwriting Results
If disabled, Prevents iOS and iPadOS from generating text in the user’s handwriting.
Yes
  • Allow iPhone Mirroring
If disabled, On iPhone, prevents an iPhone from mirroring to a Mac.
Yes
iOS 18
  • Allow Apps to be Hidden
If disabled, prevents users from hiding apps.
Yes
  • Allow Apps to be Locked
If disabled, prevents users from locking apps. If this restriction is used, hiding apps is also prevented.
Yes
  • Allow Mail Summary
If disabled Prevents the ability to create summaries of email messages manually.
This doesn’t affect automatic summary generation.
Yes
  • Allow RCS Messaging
If disabled, prevents the use of RCS messaging.
Yes
  • Allow External intelligence Integrations
If disabled, prevents the use of external, cloud-based intelligence services with Siri. On iOS, this restriction is temporarily allowed on unsupervised and user enrollments. In a future release, this restriction will require supervision, and will be ignored on non-supervised devices.
No
iOS 18.2 and macOS 15.2
  • Allow External Intelligence Integrations Sign In
If false, forces external intelligence providers into anonymous mode. If a user is already signed in to an external intelligence provider, applying this restriction will cause them to be signed out when the next request is attempted.
No
iCloud iOS:
  • Allow iCloud Photo Library
If disabled, users can’t use their iCloud Photos.
Yes
iOS 9 and IPadOS 13.1
  • Allow backup of enterprise books (Back up proprietary in-house books)
If disabled, the system disables backup of Enterprise books.
Users can’t back up books distributed by their organisation to iCloud, the Finder (macOS 10.15 or later) or in iTunes (macOS 10.14 or earlier).
No
iOS 8 and iPadOS 13.1
  • Allow notes and highlights sync for enterprise books (Notes and highlights sync for proprietary in-house books)
If disabled, the system disables sync of Enterprise books, notes, and highlights.
users can’t sync notes or highlights to other devices using iCloud.
No
  • Allow photo stream
If disabled, the system disables Photo Stream.
No
Only supported on iOS 5  through iOS 16.
  • Allow shared stream
If disabled, the system disables Shared Photo Stream
Yes
iOS 6
  • Allow managed app to store data in iCloud
If disabled, the system prevents managed apps from using iCloud sync
No
iOS 8
Security and privacy:
  • Allow diagnostic data to be sent to Apple
If disabled, users can’t choose to send diagnostic information to Apple.
No
iOS 6 and iPadOS 13.1
  • Allow user to accept untrusted TLS certificates
If disabled, the system automatically rejects untrusted HTTPS certificates without prompting the user.
No
iOS 5
  • Force encrypted backup
If enabled, the system encrypts all backups.
No
iOS 4
  • Allow automatic updates to certificate trust settings
If disabled, Automatic updates to certificate trust settings can’t occur.
No
iOS 7
  • Force limited ad tracking
If enabled, the system limits ad tracking. Additionally, it disables app tracking and the Allow Apps to Request to Track setting.
No
iOS 7
  • Allow Touch ID to unlock device
If disabled, users must use a passcode to unlock the device.
No
iOS 7 and iPadOS 13.1
  • Allow Rapid Security Response Instal
If disabled, the system prohibits installation of rapid security responses.
No
iOS 16 and macOS 13
  • Allow Rapid Security Response Removal
If disabled, the system prohibits removal of rapid security responses
No
iOS 16 and macOS 13
Ratings region
  • Regions
    • This feature can not be disabled and the default by Apple is the United States.
  • Australia - iOS and tvOS 11.3+
  • Canada - iOS and tvOS 11.3+
  • France - iOS and tvOS 11.3+
  • Germany - iOS and tvOS 11.3+
  • Ireland - iOS and tvOS 11.3+
  • Japan - iOS and tvOS 11.3+
  • New Zealand - iOS and tvOS 11.3+
  • United Kingdom - iOS and tvOS 11.3+
  • United States - iOS and tvOS 11.3+
No
N/A
Allowed Content Ratings
  • Movies
  • Do not allow movies
  • G
  • PG
  • PG-13
  • R
  • NC-17
  • Allow all movies
No
  • TV Shows
  • Do not allow TV shows
  • TV-Y
  • TV-7
  • TV-G
  • TV-PG
  • TV-14
  • TV-MA
  • Allow all TV shows
No
  • Apps
  • Do not allow apps
  • 4+
  • 9+
  • 12+
  • 17+
  • Allow all apps
No
Software updates
  • Delay user visibility of all OS software updates
If enabled, the system delays user visibility of software updates. In macOS, the system allows seed build updates without delay. The delay is 30 days unless you set another value under hid all software updates.
Yes
iOS 11.3 and macOS 10.13.4  and tvOS 12.2
  • Hide all software updates until X - Days after release date
Allows admins to determine how many days to delay a software update on the device. With this restriction in place, the user doesn’t see a software update until the specified number of days after the software update release date
Max # of days is 90
Yes
Apple Supervised Restrictions- iOS:
These restrictions only have an effect when a device is in 'supervised' mode. This mode can only be enabled with ADE or Apple Configurator. Read more
Setting
Functionality
Applications:
  • Allow app removal
If disabled, the system disables removal of apps from an iOS device. This applies to App Store apps, marketplace apps, and locally installed apps (using Configurator, Xcode, etc)
Yes
iOS 4.2.1
  • Allow use of iTunes Store
If disabled, the iTunes Store is disabled and its icon is removed from the Home Screen. Users can’t preview, purchase, or download content.
Yes
iOS 4
  • Allow use of Safari
If disabled, the system disables the Safari web browser app, and the system removes its icon from the Home screen. This setting also prevents users from opening web clips.
Yes
iOS 4
  • Force fraud warning
    • Allow Use of Safari must be enabled for this
If enabled, the system enables Safari fraud warning. Also available for user enrollment.
Yes
iOS 4
  • Enable javascript
If disabled, Safari doesn’t execute any JavaScript and  ignores all JavaScript on websites
Yes
iOS 5 and iPadOS 13.1
  • Allow popups
If disabled, Safari doesn’t allow pop-up windows. Pop-ups are blocked in Safari.
Yes
iOS 4
  • Enable Safari autofill
If disabled, the system disables Safari AutoFill for passwords, contact info, and credit cards and also prevents using the Keychain for AutoFill. Safari doesn’t keep track of what users enter in web forms.
Yes
 iOS 4, iPadOS iPadOS 13.1 and macOS 10.13
  • Allow FaceTime
If disabled, users can’t place or receive FaceTime audio or video calls and the system hides the FaceTime app.
Yes
  • Allow iMessage
If disabled, the system disables the use of iMessage on supervised devices. If the device supports text messaging, the user can still send and receive text messages.
For Wi-Fi–only devices, the Messages app is hidden.
Yes
  • Allow Game Center
If disabled, the Game Center app and its icon are removed.
Yes
  • Allow Bookstore
If disabled, the system removes the Book Store tab from the Books app.
Yes
  • Allow Bookstore erotica
If disabled, the system prevents the user from downloading Apple Books media that’s tagged as erotica.
Yes
iOS 4.0, iPadOS 13.1,  macOS 15, and tvOS 17
  • Allow Podcasts
If disabled, the system disables podcasts
Yes
  • Allow App Store
If disabled , the system disables the App Store, and the systems removes its icon from the Home screen. However, users can continue to use host apps such as iTunes or Configurator to install or update their apps.
In iOS 10 and later, MDM commands can override this restriction.
Yes
iOS 9  and iPadOS 13.1
  • Allow News app
If disabled, users can’t use the News app
Yes
  • Allow Apple Music
If disabled, users can’t use Apple Music
Yes
iOS 9.3 and iPadOS 13.1
  • Allow Apple Music Radio
If disabled, sers can’t listen to the radio with Apple Music.
Yes
  • Allowed Single App Mode
Apps listed here are allowed to place themselves in Single App Mode autonomously. It does not restrict which apps can be manually placed into Single App Mode.
Yes
  • Show or hide apps
Regardless of what is selected, the following apps are always allowed: Settings, Phone.
Choose from the options below, please note that "only allow the following apps" will remove system apps from view/use except for settings and phone.
  • Allow all Apps
  • Do not allow the following apps
  • Only allow the following apps
Yes
N/A
Device functionality:
  • Allow UI configuration profile installation
Supervised devices can be configured to not allow the installation of configuration profiles or certificates interactively.
If disabled, the system prohibits the user from installing configuration profiles and certificates interactively.
Yes
iOS 6, iPadOS 13.1, and macOS 13
  • Allow adding Game Center friends
If disabled, the system prohibits adding friends to Game Center.
Yes
iOS 5, iPadOS 13.1 and macOS 10.13
  • Allow modifying account settings
If disabled, the system disables modification of accounts such as Apple IDs and Internet-based accounts such as Mail, Contacts, and Calendar.
Users can’t create new accounts or change their username, password, or other settings associated with their account.
Yes
  • Allow AirDrop
If disabled, users can’t use AirDrop.
Yes
iOS 7 and iPadOS 13.1 and macOS 10.13
  • Allow changes to cellular data usage for apps
If disabled, the system disables changing settings for cellular data usage for apps.
Yes
  • Allow user-generated content in Siri
If disabled, Siri can’t access content from sources that allow user-generated content, such as Wikipedia.
Yes
  • Allow Find My Device in the Find My app
If disabled, the system disables Find My Device in the Find My app
Note: This and other Find My restrictions must be enabled for AirTag pairing.
Yes
iOS 13, iPadOS 13.1 and macOS 10.15
  • Allow Find My Friends in the Find My app
If disabled, the system disables Find My Friends in the Find My app
Yes
  • Allow modifying Find My Friends settings
If disabled, the system disables changes to Find My Friends.
Yes
iOS 7, iPadOS 13.1 and macOS 10.15
  • Allow host pairing
If disabled, the system disables host pairing with the exception of the supervision host. If there’s no configured supervision host certificate, the system disables all pairing. Host pairing lets the administrator control if an iOS device can pair with a host Mac or PC.
Yes
  • Allow multiplayer gaming
If disabled, Users can’t play multiplayer games in Game Center.
Yes
iOS 4 .1 and iPadOS 13.1 and MacOS 10.12
  • Force Wi-Fi power on
If enabled, the system prevents turning off Wi-Fi in Settings or Control Center, even by entering or leaving Airplane Mode. It doesn’t prevent selecting which Wi-Fi network to use.
Yes
iOS  13.0
  • Enable Siri profanity filter
If enabled, the system forces the use of the profanity filter assistant.
Yes
iOS 11 and iPadOS 13.1 and macOIS
  • Allow Files Network Drive Access
If disabled, the system prevents connecting to network drives in the Files app.
Yes
iOS 13.1 and iPadOS 13.1
  • Allow Files USB Drive Access
If disabled, the system prevents connecting to any connected USB devices in the Files app
Yes
iOS 13.1
  • Allow configuring restrictions
If disabled, the system disables the Enable Restrictions option in the Restrictions UI in Settings. In iOS 12 and later, the system disables the Enable ScreenTime option in the ScreenTime UI in Settings and disables ScreenTime if already enabled.
Yes
iOS 8
  • Allow Erase All Content and Settings
If disabled, the system disables the Erase All Content and Settings option in the Reset UI.
Yes
iOS 8, iPadOS 13.1 and macOS 12
  • Allow Internet results in Spotlight
If disabled, the system disables Spotlight Internet search results in Siri Suggestions.
Yes
iOS 8, iPadOS 13.1 and macOS 10.11
  • Allow keyboard auto-correction
If disabled, the system disables keyboard autocorrection.
Yes
iOS 8.1.3, iPadOS 13.1
  • Allow keyboard spell-check
If disabled, the system disables the keyboard spell checker.
Yes
  • Allow definition lookup
If disabled, the system disables definition lookup.
Yes
iOS 8.1.3, iPadOS 13.1 and macOS 10.11
  • Allow predictive keyboard
If disabled, the system disables predictive keyboards.
Yes
  • Allow continuous path keyboard
If disabled,  the system disables QuickPath keyboard
Yes
iOS 13 and iPadOS 13.1
  • Allow keyboard shortcuts
If disabled, the system disables keyboard shortcuts.
Yes
  • Allow pairing with Apple Watch
If disabled,  the system disables pairing with an Apple Watch, and the system unpairs any currently paired Apple Watch and erases its content.
Yes
  • Allow modification of passcode settings
Do not disable this setting if there is a passcode policy pushed to the device.
If disabled, the system prevents adding, changing, or removing the passcode. The system ignores this restriction on Shared iPad
Yes
iOS 9, iPadOS 13.1 and macOS 10.13
  • Allow modification of device name
If disabled, the system prevents the user from changing the device name.
Yes
iOS 9, iPadOS 13.1, macOS 14 and tvOS 11.0
  • Keep device name up-to-date with Dashboard
The device name cannot be set from Dashboard if "Allow modification of device name" is disabled.
When enabled, the system allows the dashboard to push the currently configured hostname in the dashboard to the device.
Yes
iOS 9, tvOS 10.2 and macOS 15.1
  • Allow modification of wallpaper
If disabled, the system prevents changing the wallpaper.
Yes
  • Allow automatic downloading of apps purchased on other devices
If disabled, the system prevents automatic downloading of apps purchased on other devices. This setting doesn’t affect updates to existing apps
Yes
  • Automatically trust enterprise apps
If disabled, the system removes the Trust Enterprise Developer button in Settings > General > Profiles & Device Management, which prevents provisioning apps by universal provisioning profiles. This restriction applies to free developer accounts. However, it doesn’t apply to enterprise app developers, because they’re trusted and the system installed their apps through MDM. It also doesn’t revoke previously granted trust.
Yes
  • Allow changes to Notifications settings
If disabled, the system disables modification of notification settings.
Yes
  • Allow modification of diagnostic submission and app analytics settings
If disabled, the system disables changing the diagnostic submission and app analytics settings in the Diagnostics & Usage UI in Settings.
Yes
iOS 9.3.2 and iPadOS 13.1
  • Allow modification of Bluetooth settings
If disabled, the system prevents modification of Bluetooth settings
Yes
  • Allow dictation input
If disabled, the system disallows dictation input.
Yes
iOS 10.3, iPadOS 13.1 and macOS 10.13
  • Allow AirPrint
If disabled, the system disables AirPrint.
Yes
  • Allow credential storage for AirPrint
If disabled, the system disables keychain storage of user name and password for AirPrint
Yes
  • Require trusted certificates for TLS printing communication
If enabled,  the system requires trusted certificates for TLS printing communication.
Yes
  • Allow iBeacon discovery of AirPrint printers
If disabled,  the system disables iBeacon discovery of AirPrint printers, which prevents spurious AirPrint Bluetooth beacons from phishing for network traffic.
Yes
  • Allow removal of system apps
If disabled,  the system disables the removal of system apps from the device
Yes
  • Allow creation of VPN configurations
If disabled,  the system disables the creation of VPN configurations
Yes
  • Enable USB Restricted Mode
If disabled, the system allows iOS devices to always connect to USB accessories while locked. On macOS, allows new USB and Thunderbolt accessories and SD cards to connect without authorization. If the system has Lockdown mode enabled, it ignores this value.
Yes
iOS 11.4.1, iPadOS 13.1 and macOS 13
  • Turn the Date & Time 'Set Automatically' feature to ON and disallow user disabling
If enabled, the system enables the Set Automatically feature in Date & Time and the user can’t disable it. The system updates the device’s time zone only when the device can determine its location using a cellular connection or Wi-Fi with location services enabled.
Yes
iOS 12, iPadOS 13.1 and tvOS 12.2
  • Allow users to use saved passwords in Safari and AutoFill Passwords feature
If disabled,  the system disables:
  • The AutoFill Passwords feature in iOS, with Keychain and third-party password managers
  • Prompting the user to use a saved password in Safari or in apps
  • Automatic strong passwords
  • Suggesting strong passwords to users
However the system does not prevent autofill contact info and credit cards in safari
Yes
iOS 12, iPadOS 13.1 and macOS 10.14
  • Allow users device to request passwords from nearby devices
If disabled, the system disables requesting passwords from nearby devices.
Yes
iOS 12, iPadOS 13.1, macOS 10.14 and tvOS 12
  • Allow users to share their passwords with the Airdrop Passwords feature
If disabled, the system disables sharing passwords with the Airdrop Passwords feature.
Yes
  • Allow users to add or remove a cellular plan to the eSIM on the device
If disabled, he system disables modifications to carrier plan related settings.
Yes
iOS 11
  • Allow users to modify the personal hotspot setting
If disabled, the system disables modifications of the personal hotspot setting.
Yes
iOS 12.2
  • Allow iPhone widgets on a Mac that has signed in the same Apple ID for iCloud.
If disabled, the system disallows iPhone widgets on a Mac that has signed in the same Apple ID for iCloud.
Yes
iOS 17
  • Allow live voicemail
If disabled,  the system disables live voicemail on the device.
Yes
iOS 17.2
  • Allow installation of Marketplace apps
If disabled, the system prevents installation of alternative marketplace apps from the web and prevents any installed alternative marketplace apps from installing apps.
Yes
iOS 17.4
iCloud iOS:
  • Allow document sync
If disabled, the system disables document and key-value syncing to iCloud.
Yes
iOS 5, iPadOS 13.1 and macOS  10.11
  • Allow cloud Keychain sync
If disabled, the system disables iCloud keychain synchronization.
Yes
iOS 7, iPadOS 13.1 and macOS 10.12
  • Allow backup
If disabled, the system disables backing up the device to iCloud.
Yes
iOS 5, iPadOS 13.1
  • Allow modification of Touch ID or Face ID
If disabled, the system prevents the user from modifying Touch ID or Face ID
Yes
iOS 8.3, iPadOS 13.1 and macOS 14
Content Ratings:
  • Allow explicit music and podcasts
If disabled, the system hides explicit music or video content purchased from the iTunes Store. The system marks explicit content as such by content providers, such as record labels, when sold through the iTunes Store. Explicit content in the News and Podcast apps is also hidden.
Yes
iOS 4.0, iPadOS 13.1, macOS 15 and tvOS 11.3
Apple Education
  • Force Classroom to automatically join classes
If true, automatically gives permission to the teacher's requests without prompting the student.
If Enabled, the system automatically gives permission to the teacher’s requests without prompting the student.
Yes
iOS 11, iPadOS 13.1 and macOS 10.14.4
  • Require permission to leave classes
If enabled, a student enrolled in an unmanaged course through Classroom needs to request permission from the teacher to leave the course.
Yes
iOS 11.3, iPadOS 13.1 and macOS 10.14.4
  • Allow unprompted App and Device Lock
If enabled, the system allows the teacher to lock apps or the device without prompting the student.
Yes
  • Automatically grant observation permission to teachers using Classroom app
If true and Allow MDM to automatically approve screen observation is also true in the Education payload, a student enrolled in a managed course via the Classroom app automatically gives permission to that course teacher's requests to observe the student's screen without prompting the student.
If enable and the setting for  "ScreenObservationPermissionModificationAllowed" is also enabled in the Education payload, a student enrolled in a managed course through the Classroom app automatically gives permission to that course teacher’s requests to observe the student’s screen without prompting the student.
Yes
Apple MDM Restrictions for macOS Devices
Setting
Functionality
Camera:
Yes
macOS 10.11+
No
macOS 10.14.4+
When disabled - Siri/Cortana can't be used.
No
macOS 14
Apple Restrictions - macOS
Setting
Functionality
  • Allow iTunes file sharing services
If disabled, the system disables iTunes file sharing services.
No
macOS 10.13
  • Allow Media Sharing
If disabled,  prevents modification of Media Sharing settings.
Yes
macOS 15.1
Yes
macOS 10.14.4
If enabled, helps control the pasting of content from an app that’s using Open In management by following the Managed Open In restrictions in force. Apple apps that work with the managed pasteboard include Calendar, Files, Mail and Notes. Third-party apps are controlled based on whether they’re managed. When a user attempts to paste content where it isn’t permitted, a Paste Not Allowed notice appears along with the organisation’s name (which can be changed using the Settings command). Apps also can’t request items from the pasteboard when this restriction is used and the content crosses the managed boundary.
Default is off
No
macOS
  • Allow Handoff
No
iOS 8,  iPadOS 13.1 and macOS 10.15
  • Allow Universal Control
If disabled, the system disables Universal Control.
No
macOS 13
  • Allow Local User Creation
If disabled, prevents a user with the role of administrator from creating new users in Users & Groups.
No
macOS 14
  • Allow Remote Apple Events Modification
If disabled, prevents the user from modifying remote Apple events settings.
No
macOS 14
  • Allow ARD Remote Management Modification
If disabled, prevents the user from modifying Remote Desktop management settings.
No
macOS 14
  • Allow Startup Disk Modification
If disabled, prevents the user from selecting a different startup disk.
No
macOS 14
  • Allow Time Machine Backup
If disabled, prevents the user from setting up and using a Time Machine backup.
No
macOS 14
  • Allow Bluetooth Sharing Modification
If disabled, prevents the user from modifying Bluetooth® settings.
No
macOS 14
  • Allow File Sharing Modification
If disabled, revents the user from modifying file sharing settings.
No
macOS 14
  • Allow Internet Sharing Modification
If disabled, revents the user from modifying internet sharing settings.
No
macOS 14
  • Allow Printer Sharing Modification
If disabled, prevents the user from modifying printer sharing settings.
No
macOS 14
Yes
iOS 18 and iPadOS 18 and macOS 15
Yes
iOS 18,  iPadOS 18 and macOS 15
  • Force Bypass Screen Capture Alert
If disabled, revents showing the screen capture alert dialogue.
Default is off
No
macOS 15.1
If disabled, prevents the use of external, cloud-based intelligence services with Siri. On iOS, this restriction is temporarily allowed on unsupervised and user enrollments. In a future release, this restriction will require supervision, and will be ignored on non-supervised devices. Available in iOS 18.2 and later, and macOS 15.2 and later.
No
If false, forces external intelligence providers into anonymous mode. If a user is already signed in to an external intelligence provider, applying this restriction will cause them to be signed out when the next request is attempted. Available in iOS 18.2 and later, and macOS 15.2 and later.
No
iCloud iOS:
Yes
iOS 9 and IPadOS 13.1 and macOS 10.12
  • Allow Back to My Mac
This feature was discontinued by Apple in 2019 and Apple recommends using iCloud Drive or Apple Remote Desktop in its place.
  • Allow Find My Mac
If disabled, users can't use Find My Device services
No
  • Allow Bookmark sync
If disabled, the system disables iCloud Bookmark sync. Bookmarks won't be uploaded to the cloud
No
macOS 10.12
  • Allow Mail sync
If disabled, the system disables iCloud Mail services. Mail won't be uploaded to the cloud
No
macOS 10.12
  • Allow Calendar sync
If disabled, the system disables iCloud Calendar services. Calendar won't be uploaded to the cloud
No
macOS 10.12
  • Allow Reminder sync
If disabled, the system disables iCloud Reminder services. Reminders won't be uploaded to the cloud
No
macOS 10.12
  • Allow Address Book sync
If disabled, the system disables iCloud Address Book services.  Address Book won't be uploaded to the cloud
No
macOS 10.12
  • Allow Notes sync
If disabled,  the system disables iCloud Notes services.  Notes won't be uploaded to the cloud
No
macOS 10.12
  • Allow desktop and document sync
If disabled, the system disables iCloud Desktop and Document services.
No
macOS 10.12.4
  • Allow Cloud Freeform
If disabled, prevents the user from storing Freeform files in iCloud
No
macOS 14
No
MacOS 10.13
No
iOS 7 and iPadOS 13.1 and mac OS 10.12.4
No
iOS 16 and macOS 13
No
iOS 16 and macOS 13
Software Updates
In macOS, seed build updates are allowed, without delay.
Yes
Max # of days is 90
Yes
  • Hide minor software updates until "X - Days" after release date
  • Delay user visibility of major OS software updates
  • Delay user visibility of non-OS Software Updates
Apple Supervised Restrictions - macOS
Setting
Functionality
Applications
Yes
  • Allow Game Center
Yes
iOS 6 and iPadOS 13.1 and macOS 10.13
Yes
Yes
Yes
iOS 7 and iPadOS 13.1 and macOS 14
  • Allow AirDrop
Yes
Yes
Yes
Yes
Yes
Yes
Yes
If disabled, users can’t use dictation on their device.
Yes
macOS 10.13
Yes
Yes
Yes
Yes
iCloud
If disabled, the system disables document and key-value syncing to iCloud. Shared iPad doesn’t support it.
Yes
iOS 5 and macOS 10.11 and later.
Yes
Yes
Apple Education
Yes
Yes
Yes
Yes
Apple MDM Restrictions for tvOS Devices
Apple Restrictions - tvOS
Setting
Functionality
  • Allow pairing with Remote app or Control Center widget
If disabled, users can’t use the Apple TV Remote app to control the Apple TV.
Yes
tvOS 10.2
Ratings region
  • Regions
No
N/A
  • Movies
  • G
  • PG
  • PG-13
  • R
  • NC-17
  • Allow all movies
No
iOS 5  or iPadOS 13.1 and tvOS 11.3
  • TV Shows
  • TV-Y
  • TV-7
  • TV-G
  • TV-PG
  • TV-14
  • TV-MA
No
  • Apps
  • Do not allow apps
  • 4+
  • 9+
  • 12+
  • 17+
  • Allow all apps
No
Software updates
Yes
iOS 11.3 iPadOS 13.1, macOS 10.13.4  and tvOS 12.2
Max # of days is 90
Yes
iOS 11.3, iPadOS 13.1, macOS 10.13.4  and tvOS 12.2
Apple Supervised Restrictions - tvOS
Setting
Functionality
Applications:
Yes
Yes
Yes
If enabled, the Set Automatically is turned on and users can’t turn it off.
Yes
tvOS 12.2
Yes
Yes
  • Allows tvOS devices to automatically sleep
If disabled, the system prevents the device from automatically sleeping. Requires a supervised device.
Yes
tvOS 13
Content Ratings:
Yes
Android MDM Restrictions
Setting
Functionality
Camera:
  • Allow use of camera
Supported on Samsung KNOX
Windows MDM Restrictions
Setting
Functionality
Camera
Setting
Functionality
  • Allow WiFi
  • Allow Bluetooth
  • Allow use of external storage card
  • Was this article helpful?
