Enrolling and Supervising iOS Devices using Apple Configurator 2.5 or Later
NOTE: All references to iOS in this article can be considered to include iPadOS
Overview
Meraki Systems Manager provides administrators the ability to mass enroll and supervise devices using Apple Configurator, a macOS application. Apple Configurator 2 allows for mass configuration of iOS 11+ devices while physically connected to a Mac computer. A USB hub can be used to configure dozens of devices at once. Follow these links to download the application, and view more Apple Configurator documentation.
With Apple Configurator 2.5 or later, Apple has allowed the use of the Automated Device Enrollment (ADE) for Automatic Enrollment into Meraki Systems Manager, which can be used to speed up the process into a no-touch experience for mass enrollment of devices. ADE is accessible to all devices in the Apple Business Manager and Apple School Manager portals. Alternatively, if your iOS devices are not in Apple's ADE, you can use the Manual Enrollment method by configuring your Systems Manager Mobile Device Management (MDM) Server in Apple Configurator via enrollment URL, or provisionally move non-ADE devices into an existing ADE account! This article will cover both MDM options of enrollment via Apple Configurator 2.5 in detail: ADE Automatic enrollment method and Manual enrollment methods.
iOS devices that are using Apple's Automated Device Enrollment (ADE) can be supervised and enrolled over-the-air anytime they are factory reset. ADE is the best way to permanently force your devices to be owned and managed by your organization, and it is important to assign your ADE settings properly before deployment.
Device Supervision
During the enrollment process, it is possible to supervise iOS devices. Supervision enables many additional features including restrictions, which you can find listed in the Meraki Dashboard under Systems Manager > Manage > Settings > Restrictions > iOS restrictions (supervised).
If your iOS devices are not currently Supervised, they will be required to be factory reset to become Supervised. Therefore, it is recommended to Supervise devices (if desired) prior to performing any configuration or providing the device to users. Supervision steps are covered in detail in the guide below.
Prerequisites
Apple Configurator 2.5 or greater
macOS 14 or greater
iOS device(s) powered up and physically connected to Mac
The Mac and iOS device(s) are not locked
Internet access with unblocked access to Apple and Meraki Systems Manager
Refer to Help > Firewall info for a list of ports and IP addresses
For Automatic enrollment: iOS devices must be in Apple’s ADE program.
Access to the internet is critical to the enrollment process. If an iOS device is not able to contact Meraki Systems Manager when trying to enroll, it will be unable to complete the process and/or receive any additional profiles and apps.
Apple Configurator 2.5+ Automatic Enrollment
Automatic Enrollment through Apple Configurator only works on iOS devices that are in Apple’s Automated Device Enrollment (ADE), and allows you to pre-provision wireless settings on devices to seamlessly enroll during the device's setup assistant. Please be sure to add your Apple ADE account to Meraki Systems Manager before beginning this process, and ensure your devices are visible in Systems Manager > Manage > ADE.
If devices are not currently in Apple's Device Enrollment Program, please follow the steps for the Apple Configurator 2.5 - Manual Enrollment later in this guide.
Open your Meraki Dashboard and go to Systems Manager > Manage > ADE.
Checkmark the devices you want to assign ADE settings.
Click on Assign settings.
If you have an existing setting profile created, select it from the dropdown. Otherwise, create a new one and complete the fields/selections that appear in the setup
For a full explanation of ADE setting options check out this article.
For a full zero touch automatic device setup, it is recommended to select "Skip all steps".
Click Assign. Now you will see these devices change to have an orange “Assigned” status next to it. The device is currently waiting to be turned on for the first time, or to be factory reset so it can activate with Apple and receive the new ADE settings.
Download and open Apple Configurator 2.5 on a Mac OS X workstation. Connect your iOS devices to your workstation via USB, they should automatically appear in Apple Configurator. Highlight the devices you want to automatically enroll in Apple Configurator 2 and click on Actions > Prepare…
Choose Prepare with: Automatic Enrollment. Click Next.
[Optional] Upload a wireless profile, so the iOS device(s) can automatically connect to an SSID in range.
For a true automatic / no touch enrollment, Step 8 is very important!
To create a WiFi profile in Apple Configurator 2, go to File > New Profile , and add your WiFi settings.
Save this profile as a mobileconfig file then upload it during Step 8. It is necessary to add a WiFi profile during this step so each iOS device can communicate to Apple to activate and complete the automatic ADE settings assignment for automatic Meraki Systems Manager enrollment.
[Optional] If your Meraki Systems Manager enrollment requires User Authentication (SM > Configure > General), you may input your username/password here to automatically enroll and assign a device user. If these fields are left blank, the device will prompt for username/password credentials during the provisioning process.
Apple Configurator will now download the latest iOS version from Apple and install it on the connected devices. Be patient while the latest iOS version downloads and installs.
These devices now contain the WiFi profile as well as the Meraki Management enrollment profile. These devices will skip the steps chosen in Step 4. Once these devices are at their homescreen, they can have apps and profiles installed through Meraki Systems Manager. All your devices can now be managed in Systems Manager > Configure > Devices.
At this point, the automatic enrollment process is complete - your devices are now managed and ready to be distributed to end users!
Apple Configurator 2.5+ Manual Enrollment
Manual Enrollment is the way to enroll iOS devices not currently in Apple’s Automated Device Enrollment (ADE). First we will cover how to setup your organization and server in the Apple Configurator. Then, we will use the Apple Configurator to go through the Manual Enrollment process to factory erase the device(s) and enroll your device in supervised mode into your Meraki Systems Manager dashboard.
New in Apple Configurator 2.5 and iOS 11: You can now move non-ADE devices into an existing ADE account! This is an optional step during the Manual Enrollment process to move non-ADE devices into your current ADE account.
If you do not have an ADE account, you can still enroll & supervise devices through the manual enrollment process.
Create Organization and Supervision Identity
- Go to Apple Configurator in the menu bar and choose "Settings"
- Click on the Organizations tab and click the “+” to add a new server.
- Sign in with an Apple ID.
If you want to move a non-ADE device into your ADE account, be sure to sign in with your Apple Business Manager or Apple School Manager Apple ID during this step, so the supervision identity can be pulled from Apple automatically. If not, Skip this step and manually fill in your Name, Phone, Email, and Address on the next page.
- Generate a new supervision identity.
The supervision identity will be pulled automatically from your Apple ID if the Apple ID you signed in with on Step 3 is a "device enrollment manager" account role for Apple Business Manager or Apple School Manager.
Add MDM Server URL
Click on the Servers tab.
Click the “+” to add a new server.
Define your MDM Server:
Name: Any name you choose.
Hostname or URL: Enrollment URL copied from your Meraki Dashboard found in Systems Manager > Manage > Add Devices > iOS > Apple Configurator > Enrollment URL (AC2+)
You have now successfully configured your Systems Manager MDM Server. Close this window and now you can begin the Manual Enrollment process.
Manual Enrollment - Add device(s) to Automated Device Enrollment (ADE)
Now that you have added the organization's supervision identity and MDM server URL, you are ready to begin the manual enrollment process.
Something new in both iOS 11 and Apple Configurator 2.5+ is the ability to move non-ADE devices into an existing ADE account. These steps will show you this process.
Note that after initially adding devices into ADE through Apple Configurator, there is a 30-day provisional period where the management profile can still be removed. After this period, the management profile will no longer be removable.
If you do not have an ADE account, skip this section and move to the Manual Enrollment - Enrollment & supervision without Apple Automated Device Enrollment (ADE) section further below.
Plug your iOS devices to the Mac running Apple Configurator 2.5+. Click the device you would like to enroll and go to the menu bar and choose Actions > Prepare...
Choose Prepare with: Manual Configuration
If you signed into an ADE account in "Create Organization and Supervision Identity" - Step 3 (above), you can check the new Add to Automated Device Enrollment option. This is a new feature for iOS 11 and Apple Configurator 2.5+ that allows you to move non-ADE devices into your existing ADE account. If you do not have an ADE account with Apple (Apple Business Manager / Apple School Manager), leave the Add to Automated Device Enrollment checkbox unchecked.
Furthermore, if you have a school.apple.com account as your ADE account, you can enable Shared iPad mode.
The supervised method of enrollment will allow many additional restrictions to be added to devices in Meraki later.
The Allow devices to pair with other computers option will allow these iOS devices to connect to other computers via USB cable. If you do not allow pairing here, they will be undetectable to other computers via iTunes, Apple Configurator, or any USB data detection.
Click Next.
Choose your Meraki MDM Server (set up in the Add MDM Server URL steps above).
Selecting an MDM server in this menu is incompatible with enrollment authentication (Systems Manager > Configure > General > Enrollment settings > Authentication). If enrollment authentication is enabled, an “invalid profile” error will occur on the device UI. This can be avoided with any of these options:
- Temporarily disable enrollment authentication within the currently selected SM network.
- Create a dedicated Apple Configurator enrollment SM network without enrollment authentication, then move devices to the desired network after enrollment.
- Select "Do not enroll in MDM" during this stage. Once the device has booted to the home screen, visit enroll.meraki.com authenticate and install the enrollment profile.
Click Next.
- Choose the organization that you want to have supervision of these devices.
Click Next.
- Choose what steps you would like the initial iOS Setup Assistant to skip.
Click Next.
- If you selected 'Activate and complete enrollment' in step 2, upload a .mobileconfig wireless profile so the device can automatically connect to an SSID in range and be self-configured with Apple and Meraki.
Click Next.
- If your Meraki Systems Manager network requires enrollment authentication (SM > Configure > General), input your username/password here. If not, leave these fields blank.
Click Prepare.
You may be asked to re-authenticate the ADE account's Apple ID during this step, so the device(s) can be successfully moved into this ADE account with Apple.
Apple Configurator will now download the latest iOS version from Apple and install it on the connected device(s). iOS 11+ is required for this process to complete. Be patient while the latest iOS version downloads and installs. All devices will now be prepared and all data saved on the device will be lost during this process.
- After this process completes, login to the Apple Business Manager or Apple School Manager portal and access "Assignment History." You will find the iOS device(s) assigned to a new “Devices Added by Apple Configurator 2” MDM server.
- In the Apple Business Manager or Apple School Manager portals, click on "Device Assignments" to assign all devices to your Meraki MDM server.
- A 30 day provisional period begins when the device is subsequently activated. During the 30 day provisional period the lock screen and setup assistant on the device(s) indicate that it is provisionally enrolled. End users can remove the device(s) from ADE during this provisional period (which also factory erases the device). However, after the 30 days provisional period expires, end users can no longer remove the device(s) from ADE.
Devices are now ready to go through the Automatic Enrollment steps detailed in the "Apple Configurator 2.5+ Automatic Enrollment" section above. Our video "Systems Manager Tutorial: Assigning Settings in DEP" can be used at this stage, note some terminology and UI may vary. For more information on over-the-air ADE enrollment, reference the "Assigning Settings" section of our "Apple Automated Device Enrollment (ADE)" document.
Now that you have added the Organization's supervision identity and MDM server URL, you are ready to being the manual enrollment process. If you want to simply supervise and enroll devices with Apple Configurator, you can easily do this without access to an Apple Automated Device Enrollment account.
Plug your iOS devices to the Mac running Apple Configurator 2.5+. Highlight the device you would like to enroll and go to the menu bar and choose Actions > Prepare...
The 'Allow devices to pair with other computers' option will allow these iOS devices to connect to other computers via USB cable. If you do not allow pairing here, they will be undetectable to other computers via iTunes, Apple Configurator, or any USB data detection.
Click Next.
Click Next.
- Choose the Organization that you want to have Supervision of these devices.
Click Next.
Click Prepare.
- Apple Configurator will now download the latest iOS version from Apple and install it on the connected devices. Be patient while the latest iOS version downloads and installs. All devices will now be prepared with these settings, which requires a device factory reset. All data saved on the device will be lost.
- Now, your devices will be at their iOS initial setup assistant "Hello" screen. You will need to configure each iOS device from here one by one, just so it can connect to WiFi and receive the enrollment profile. Slide to set up.
- Choose a WiFi network in range for device to connect to.
- The iOS device will now show a Remote Management page during the iOS Setup Assistant. Apply configuration here and you will be enrolled in Systems Manager.
Troubleshooting Provisional Enrollment Failed Errors
This guide provides step-by-step instructions for manually enrolling an iOS/iPadOS device into ADE using Apple Configurator. The steps below addresses the "Provisional Enrollment Failed [MCCloudConfigErrorDomain - 0X80EF (33007)]" error faced during the manual enrollment process.
Step 1: Set Up the MDM Server and Organization
Follow the instructions in this document under 'Create Organization and Supervision Identity' to set up your MDM server and Organization within Apple Configurator.
Use the Apple Configurator 2.5+ Enrollment URL when setting up your MDM server. This enrollment URL can be found under Systems Manager > Add Devices > iOS.
Step 2: Release the Device in ABM/ASM Portal
Log in to the Apple Business Manager (ABM) or Apple School Manager (ASM) portal.
Release the device from the portal. This action will also remove the device from Systems Manager > ADE.
Step 3: Restore the Device to Factory Settings
Use Apple Configurator to restore the device to its factory settings. This step ensures the device is completely reset and ready for enrollment.
Step 4: Navigate Wi-Fi Setup on the Device
On the device, go through the Setup Assistant until you reach the WiFi page.
Connect to your WiFi network but do not proceed further. If the device automatically advances to another screen, simply navigate back to the Wi-Fi page.
Step 5: Prepare the iOS Device Using Apple Configurator
Use Apple Configurator to prepare the iOS device. During this process:
Select Manual Enrollment.
Check Add to Apple School Manager (ASM) or Apple Business Manager (ABM).
Uncheck Activate and complete enrollment.
Check Allow devices to pair with other computers.
This will wipe the device once more to ensure it is properly prepared for ADE.
Step 6: Assign MDM Server in ABM/ASM Portal
Go back to the ABM/ASM portal and assign the MDM server to the iOS/iPadOS device.
Step 7: Perform Full Sync and Assign ADE Settings
Navigate to Systems Manager > ADE in your Meraki dashboard.
Perform a Full Sync to update device information.
Assign your ADE settings to the iOS/iPadOS device. After this, the device status under Systems Manager > ADE should update from Empty to Assigned.
Step 8: Connect to the Internet
Continue through the Setup Assistant on the device and ensure it is connected to the Internet.
Step 9: Remote Management Screen
After the device connects to the Internet for activation, it should display a Remote Management screen during the setup process.
You should not encounter the "Invalid Profile" error during this step.
Step 10: Verification
Verify that the device status under Systems Manager > ADE has changed from Assigned to Pushed.
