Production Ready Workflows
A production-ready workflow is a locked workflow that meets a set of quality requirements and is approved for general use. Cisco Workflows makes production-ready workflows discoverable to other users, to the AI Assistant, and to the AI Agent activity.
Workflow lock states
Every workflow has a lock state that controls whether the workflow can be edited and how widely it is shared. The following table describes each state.
State |
Meaning |
Unlocked |
The workflow is open for editing. Anyone with edit access can change it. |
Locked |
The workflow is protected from edits. A user must unlock the workflow before making changes. |
Production Ready |
The workflow is locked and meets all production requirements. The workflow is approved for general use and is discoverable to other consumers. |
A workflow becomes production ready only after a user locks it and selects Production Ready. The option stays disabled until the workflow meets every requirement.
Requirements for production ready
A workflow must satisfy all of the following requirements before it can be marked production ready. The lock dialog lists each requirement and shows which ones still need attention.
Requirement |
Description |
Locked |
The workflow is locked. |
Valid |
The workflow passes validation with no errors. |
Description |
The workflow has a description. |
Variable descriptions |
Every input and output variable has a description. |
What changes when a workflow is production ready
Marking a workflow production ready signals that the workflow is stable and safe for others to run. The status has the following effects:
The workflow appears as a selectable tool in the AI Agent activity. Only production-ready workflows appear in the Specific workflows to include list.
Because other consumers can depend on a production-ready workflow, changing its status or contents can affect live operations.
Edit a production-ready workflow safely
A production-ready workflow is locked, so editing requires a deliberate step. Choose one of the following approaches:
Unlock the workflow to edit it. Unlocking clears the production-ready status, and other consumers stop seeing the workflow until it is marked production ready again.
Duplicate the workflow and edit the copy. Editing a copy avoids any impact on the workflows, automation rules, and agents that use the original.
The platform shows a warning before editing a production-ready workflow, because other users, the AI Assistant, automation rules, and parent workflows may actively use it.
Next steps
To let an AI agent run production-ready workflows as tools, see AI Agent Activity.
Add a clear description to the workflow and to each input and output variable so the workflow meets the production requirements.
