Remote Access Deployment
Click 日本語 for Japanese
Remote Access Setup
Before you begin, first, you'll need to integrate your Cisco Meraki and Cisco Umbrella accounts together for a seamless experience and meet the prerequisites of remote access deployment. For further instructions, please check article Cisco Secure Connect Onboarding and Cisco Secure Connect - Remote Access.
Getting Started with Configure Remote VPN Access Service
1. Get started with navigate to Secure Connect -> Identities & Connections -> Remote Access to begin the setup process.
2. Once you are in the Remote Access page, a service wizard will guide you through Configure regions and DNS Servers. You will need to complete these two minimum requirements to get your Remote Access journey starts.
3. Configure regions will allow you to choose your locations under Asia Pacific, Europe and North America regions.
Select the Secure Connect data center Location where your client VPN tunnels will terminate. You can choose single or multiple regions based on your own architecture design.
A Location is added by entering an private IP address range in the Assigned IP pool field. Display Name is optional, if you are willing to use the default name, leave the space blank and the grey-out default name will be automatically populated once you click Save button.
There are a few things to be aware when configuring Locations.
- A minimum of two locations must be added per region.
- The IP address ranges must be in the private address space defined in RFC1918 in CIDR format.
- The largest and smallest supported IP range is x.x.x.x/16 and x.x.x.x/28.
- The IP address ranges you choose for your remote client must not be overlapped with any other address ranges in your internal network.
- Changing the Display Name is an optional step.
- Leave the Location space blank if you do not want to use that location.
4. Add the IP address(es) of the DNS Server(s). Secure Client will use these servers to resolve applications accessed through the tunnel.
Add a Default domain for DNS resolution and additional DNS Names (optional) in the respective fields and Click Save.
5. After complete and save your configurations. The new page will show you that your selected Remote Access locations has been successfully provisioned. To make any changes or verify configuration, select each tab or click Configure Regions to edit regions/locations head-end.
There are a few items to be noted:
- FQDN - The unique FQDN sitting on the top left corner is used for remote users connecting to remote access VPN through Cisco Secure Client, it will find the remote user's nearest geographical location from your provisioned list.
Once provisioning is complete, an auto-selecting URL is provided that will automatically select the closest data center to the remote endpoint. This URL is visible in the Secure Connect and Umbrella dashboard and follows the format; <system generated id>.sc.ciscoplus.com.
Alternately, location-specific FQDNs are provided with the following format: <system generated id>.location.sc.ciscoplus.com. Using the above example, the 4 FQDNs generated could be:
123d.pao1.sc.ciscoplus.com
123d.nyc1.sc.ciscoplus.com
123d.lax1.sc.ciscoplus.com
123d.ash1.sc.ciscoplus.com
The VPN profiles for each location, per the above example, will appear as "Palo Alto, CA", "New York, NY", etc.
Remote Access users may choose to connect to the auto-selecting URL or a specific location via the Secure Client dropdown. Note the drop downs will populate after first connecting to the service.
This may take up to five minutes to complete. It is ok to start the next section while waiting.
- Secure Client - Click Downloads button under Secure Client, you can download the latest version of Secure Client software in Windows, MacOS and Linus operating systems. You can also download XML file for your MDM solution.
When installing Secure Client there will be multiple modules available to install. Ones that are relevant to Secure connect solutions are:
- Core & AnyConnect VPN (VPN module)
- Umbrella: Roaming Module provides off-site DNS and Web policy support. It is also required for Remote Access DNS policy.
- Diagnostic And Reporting Tool (Troubleshooting Module)
Remote Access end device requires Umbrella Module to be active for DNS policy to take effect. Please check Deploy Umbrella module for configuration and installation steps. Roaming Secure Module Profile file can be downloaded from the same Downloads section under Remote Access Tab.
Root Certificate can be downloaded from the same page. It is required for DNS and Web policy. More details on how to Install the Cisco Umbrella Root Certificate.
- Task Wizard (Tasks to enable Remote Access) - You will see a task checklist wizard on the top of the Remote Access page.
- By default, it is collapsed
- You can always expand it to check what tasks left to be completed. As each task is completed, the progress bar advances.
Configure Identity Provider to Provision Users
Once you completed Configure remote access service, to complete the whole experience of Remote Access. You need to configure your remote users, which means integrate your IdP solution to Secure Connect. Please check Configure and provision users to complete deployments.
After you complete configurations on IdP integration, you will need to assign users to Remote Access. Navigate to Secure Connect > Remote Access page, click on User and Group Assignment tab, you can choose either assign by User Groups or by Users. Or you can simply turn on Enable remote access for all user groups (users) button, which means all future added user groups (users) will be automatically enabled with Remote Access when this option is enabled.
If the IdP configuration (Meraki Cloud Auth) was configured prior to Remote Access, we would need to go to User and Group Assignment tab to add users to Remote Access.
In Secure Connect dashboard navigate to Secure Connect > Remote Access, click on User and Group Assignment tab.
Select users or AD groups that will be allowed to use remote VPN access to connect to the network. For Meraki Auth IdP make sure RemoteAccess group is selected.
High Availability & Multi-Region Location Pairing
When provisioning Remote Access VPN (RAVPN) headends in Cisco Secure Connect, selecting geographically diverse locations ensures both low-latency local performance and comprehensive disaster recovery.
Multi-Tier Resiliency Strategy: Deploying multiple headends within the same geographic region (e.g., Frankfurt + Amsterdam) provides local load sharing, minimum latency, and maintenance failover. To ensure continuous availability during broad regional infrastructure events, pair intra-region deployments with an independent cross-region destination (e.g., adding London).
Global Location Pairing Matrix
Use the matrix below to design primary, intra-region, and cross-region failover pairings for Remote Access VPN headends:
| Primary Region | Intra-Region Multi-Site (Local / Latency Redundancy) |
Cross-Region Failover (Disaster Recovery) |
Architectural Guidance |
| Central Europe | Frankfurt, Amsterdam, Milan, Stockholm | Western Europe: London, Paris, Copenhagen, Madrid (Recommended: London) |
Pairing Frankfurt + Amsterdam provides local HA; pair with London for cross-region disaster recovery. |
| Western Europe | London, Paris, Copenhagen, Madrid | Central Europe: Frankfurt, Amsterdam, Milan, Stockholm (Recommended: Frankfurt) |
Pairing London + Paris provides local HA; pair with Frankfurt for cross-region disaster recovery. |
| US East & Canada | New York, Ashburn, Chicago, Atlanta, Dallas, Miami, Minneapolis, Toronto | US West / Canada West: Los Angeles, Denver, Seattle, Palo Alto, Vancouver |
Deploying across East Coast sites handles local capacity; pair with US West for cross-region disaster recovery. |
| US West & Canada | Los Angeles, Denver, Seattle, Palo Alto, Vancouver | US East / Canada East: Chicago, Dallas, Ashburn, New York, Atlanta |
Intra-West pairings optimize Pacific latency; pair with US East for cross-region disaster recovery. |
| Asia Pacific | Tokyo (North), Singapore (South) | Cross-Region Pair: Tokyo ↔ Singapore or US West (Los Angeles / Seattle) |
Pairing Tokyo with Singapore provides robust, geographically isolated cross-regional failover. |
| ANZ | Sydney, Melbourne | Asia / US West: Singapore, Tokyo, or US West |
Sydney + Melbourne provides local diversity; pair with Singapore or US West for full disaster recovery. |
| Latin America | São Paulo, Rio de Janeiro | North America: Miami, Dallas, Atlanta |
São Paulo + Rio offers in-country resilience; pair with North America (Miami/Dallas) for DR. |
| India & Africa | Mumbai, Chennai, Johannesburg, Cape Town | Europe: Frankfurt, London, Paris |
Local pairings handle regional routing; pair with Europe (Frankfurt/London) for cross-region DR. |
Recommended Deployment Topologies
(1) The 3-Site Resiliency Model (Active/Active Local + Remote DR)
- Deploy two locations within the same region (e.g., Frankfurt + Amsterdam) for active capacity sharing and optimal user latency.
- Configure a third cross-region location (e.g., London) as the automated disaster recovery target.
(2) The 2-Site Streamlined Model (Direct Cross-Region)
- Pair directly across two independent regional scopes (e.g., Frankfurt (Primary) + London (Failover)).
- Delivers complete disaster recovery and infrastructure isolation with a simplified two-site operational footprint.
Configuration Best Practice: Ensure secondary headends and automated DNS/GeoLB steering configurations are provisioned and verified in the Cisco Secure Connect portal prior to an incident to enable automated, zero-touch failover.
Deploy Cisco Secure Client
Cisco Secure client allows remote users to access private applications from anywhere through its Anyconnect VPN module. Before downloading Cisco Secure Client, you may want to check for system requirements.
There are two parts in the Cisco Secure Client downloads section. The first is the is the software itself. The second is an XML file that contains the features and attribute values created during the setup process. Customers can use their own MDM solution to build up a unique Cisco Secure Client software with their XML file bundled.
Navigate to Secure Connect > Remote Access and click Downloads under Secure Client.
Download the Secure Client and Secure Client XML file (optional) via the provided links in the pop up window.
Once Secure Client is installed, you will use AnyConnect VPN module for Remote Access.
More information on deploying Cisco Secure Client can be found here.
Next Step
Now, you have finished the basic deployment of Remote Access. Please refer to below articles if you plan to deploy more granular enforcements:
