C8111-C-G2-MX, C8121-W-G2-MX, and C8121-CW-G2-MX Datasheet
Overview
The Cisco C8111-C-G2, C8121-W-G2 and C8121-CW-G2 are enterprise security appliances running MX OS which are designed for distributed deployments requiring remote administration across small to medium branch environments. It is ideal for network administrators who demand both ease of deployment and a state-of-the-art feature set.
The Cisco C8111-C-G2, C8121-W-G2, and C8121-CW-G2 are designed to securely extend the power of cloud-managed networking to almost any location by providing two dedicated WAN ports with one of those WAN ports able to provide PoE to power a cellular gateway. The C8111-C-G2 and C8121-CW-G2 can use their 5G cellular modem to provide downstream devices connectivity through an inserted SIM card or through an on-board eSIM.
These devices offer up to 10 LAN Gigabit ethernet ports, including up to 3 built-in LAN PoE-enabled ports for access points, cameras, VoIP phones, and other PoE powered devices. The C8121-W-G2 and C8121-CW-G2 include the ability for Wi-Fi devices to connect to the network.
Features
Software Features
Hardware Features
2 x 2.5 mGig RJ45 Ethernet ports dedicated for WAN uplinks
1 x 2.5 mGig RJ45 Ethernet ports with PoE+ capabilities
4 x 1 Gigabit RJ45 Ethernet LAN ports (C8111-C-G2)
1 x 1 Gigabit RJ45 Ethernet LAN ports with UPoE (45W) capabilities
3 x 1 Gigabit RJ45 Ethernet LAN ports
10 x 1 Gigabit RJ45 Ethernet LAN ports (C8121-CW-G2 and C8121-W-G2)
3 x 1 Gigabit RJ45 Ethernet LAN ports with UPoE (45W) capabilities
7 x 1 Gigabit RJ45 Ethernet LAN ports
Built-in Wi-Fi 6 Wireless Capabilities for C8121-CW-G2 and C8121-W-G2
Built-in 5G Cellular capabilities for C8121-CW-G2 and C8111-C-G2
Context and Comparisons
C8111-C-G2 |
C8121-W-G2 |
C8121-CW-G2 |
# of WAN Uplinks |
3 |
2 |
3 |
Cellular Uplink |
Yes |
No |
Yes |
Stateful Firewall Throughput |
2 Gbps |
2 Gbps
2 Gbps |
Maximum VPN Throughput |
1.2 Gbps |
1.2 Gbps |
1.2 Gbps |
Advanced Security Throughput |
1 Gbps |
1 Gbps |
1 Gbps |
PoE Capabilities |
Yes, 2.5 x MGig RJ45 WAN Ports (802.3at) 1x GbE RJ45 LAN Ports (802.3bt, 45W) |
Yes, 2.5 x MGig RJ45 WAN Ports (802.3at) 3x GbE RJ45 LAN Ports (802.3bt, 45W) |
Wi-Fi |
No |
Dual-band 2x2 Wi-Fi 6 |
Cellular Uplink |
Built-in 5G SA & CAT20 LTE Modem with 4 x External Antennas |
No |
Recommended use case |
Up to 200 devices |
Up to 200 devices |
Up to 200 devices |
Technical Breakdown
WAN Interfaces
C8111-C-G2 |
C8121-W-G2 |
C8121-CW-G2 |
2x Dedicated MGig RJ45 |
1x Built-in 5G SA & CAT20 LTE modem |
LAN Interface
C8111-C-G2 |
C8121-W-G2 |
C8121-CW-G2 |
4x Dedicated GbE RJ45 |
10x Dedicated GbE RJ45 |
Wireless Interfaces
C8111-C-G2 |
C8121-W-G2 |
C8121-CW-G2 |
Wi-Fi Radio Information |
N/A |
802.11a/b/g/n/ac/ax (2.4 or 5Ghz) 2x2 MU-MIMO
802.11a/b/g/n/ac/ax (2.4 or 5Ghz) 2x2 MU-MIMO |
Wi-Fi Antennas |
N/A |
Internal, 2 x 2 MU-MIMO with two spatial streams |
Maximum Data Rate |
N/A |
1.5 Gbps* |
1.5 Gbps* |
Cellular Radio Information |
N/A |
SIM Cards |
1x Nano (4FF) 1x Embedded eSIM (eUICC) |
N/A |
Cellular Antennas |
4x External removable antennas with SMA connector |
N/A |
* Refers to maximum over-the-air data frame rate capability of the radio chipset, and may exceed data rates allowed by IEEE 802.11ax operation.
Throughput and Capabilities
C8111-C-G2 |
C8121-W-G2 |
C8121-CW-G2 |
Recommended Use Case |
Up to 200 devices |
Up to 200 devices |
Up to 200 devices |
Max Stateful Firewall Throughput in NAT mode |
2 Gbps |
2 Gbps |
2 Gbps |
Max VPN Throughput |
1200 Mbps |
1200 Mbps |
1200 Mbps |
Physical
C8111-C-G2 |
C8121-W-G2 |
C8121-CW-G2 |
Mount Type |
Desktop / Wall Mount |
Dimensions (h x d x w) |
1.3 x 6.9 x 12.4 in / 34 x 176 x 316 mm |
1.3 x 8 x 13.7 in / 34 x 203 x 348 mm |
Weight |
3.2 lbs / 1.451 kg |
3.7 lbs / 1.696 kg |
3.9 lbs / 1.783 kg |
Power Supply |
150W DC |
250W DC |
250W DC |
Estimated System Power (idle/max) |
39 W / 45 W |
56 W / 64 W |
68 W / 87 W |
System + PoE Power Load (idle/max) |
39 W / 126 W |
56 / 221W |
68 W / 233W |
Operating Temperature |
32°F - 113°F 0°C - 45°C |
Storage and Transportation Temperature |
-4°F - 158°F -20°C - 70° C |
Humidity |
5% to 95% |
5% to 95% |
5% to 95% |
Product Category and Certifications
5G Category |
5G SA/NSA Sub 6GHz |
LTE Category |
CAT20 |
Bands and CA combos |
Certifications |
PTCRB (US), GCF (EU), IC (CA), FCC (US) |
Certified Carriers |
AT&T, T-Mobile |
Carriers leveraging GCF |
Carrier Certification in Progress |
Verizon |
Carrier compatibility is generally based on having compatible bands on the modem. In the open market, carriers may only require regulatory domain certifications and open market certifications, like the PTCRB and GCF, to be compatible for their network. Sometimes carriers will require additional testing before a device can be used on their network. The section Tested Carriers is based on Meraki device certifications being approved by those specific carriers. A carrier being listed above means that they have officially certified the Meraki product for their cellular network. There may be many unlisted carriers that could be functionally compatible with Meraki devices. The list of tested certified carriers is based on the carrier validating Meraki per their network parameter requirements. If a carrier you are looking to use is not listed above, it could be that they do not require additional compliance testing for their network.
Ordering Guide
Model SKU |
Description |
C8111-C-G2 |
Cisco C8111-C-G2 Cloud Managed Secure Router |
C8121-W-G2 |
Cisco C8121-W-G2 Cloud Managed Secure Router |
C8121-CW-G2 |
Cisco C8121-CW-G2 Cloud Managed Secure Router |
Accessories
Accessory |
Description |
MA-PWR-150WAC-ADP |
C8111-G2-MX Replacement Power Adapter (C8111-C-G2) (150 Watts AC) |
MA-PWR-250WAC-ADP |
C8121-G2-MX Replacement Power Adapter (C8121-W-G2 and C8121-CW-G2) (250 Watts AC) |
MA-PWR-CORD-US |
1x AC Power Cable, US plug |
MA-PWR-CORD-EU |
1x AC Power Cable, EU plug |
MA-PWR-CORD-UK |
1x AC Power Cable, UK plug |
MA-PWR-CORD-AU |
1x AC Power Cable, AU plug |
MA-WMNTBR-PWR-ADP |
1x Power adapter holder for external power adapter |
5G-ANT-C8111 |
Includes 4x cellular antennas for the C8111-C-G2 |
5G-ANT-C8121 |
Includes 4x cellular antennas for the C8121-CW-G2 |
Non-Meraki Antennas not supported
Note: Non-Cisco Secure Router antennas are not supported. The socket is SMA that is designed to function with the C8111-C-G2 and C8121-CW-G2. Usage of non- Cisco Secure Router accessories may damage the device and / or degrade performance. The Cisco Secure antennas are designed for the maximum allowable gain without exceeding the EIRP for local regulatory domains on their supported bands.
Configure your Dashboard Network
The following is a brief overview only of the steps required to add an C8111-C-G2, C8121-W-G2, or C8121-CW-G2 to your network. For detailed instructions about creating, configuring and managing Meraki networks, refer to our Managing Dashboard Networks document. Additional resources can also be found via: documentation.meraki.com.
Login to http://dashboard.meraki.com. If this is your first time, create a new account.
Find the network to which you plan to add your C8111-C-G2, C8121-W-G2 or C8121-CW-G2 or create a new network.
Add your C8111-C-G2, C8121-W-G2, or C8121-CW-G2 to your network. You will need your Meraki order number (found on your invoice) or the serial number of each C8111-C, C8121-W-G2, or C8121-CW-G2, which looks like Qxxx-xxxx-xxxx, and is found on the bottom of the unit. If a license key was purchased at the same time then you should have received it via email.
Go to the map / floor plan view and place each C8111-C-G2, C8121-W-G2, or C8121-CW-G2 on the map by clicking and dragging it to the location where you plan to mount it.
Troubleshooting
Common Event Log Messages
Common event logs exist for wired, Wi-Fi, and cellular events. As such, no specific C8111-C-G2, C8121-W-G2, or C8121-CW-G2 event log entries are required at this time.
For more general information about navigating the Event Log and the types of Events that could be expected, please check out our Event Log documentation.
