Cisco C8235-G2-MX Datasheet
Overview
The Meraki C8235-G2-MX is a Cisco Secure Router that provides Security and SD-WAN, next-generation firewall services, and high-speed branch connectivity for medium sized branch environments. It is designed for distributed networks that require remote administration and supports simple deployment through the Meraki dashboard with minimal pre-configuration required in most locations. It is ideal for network administrators who demand both ease of deployment and a state-of-the-art feature set. By consolidating Unified Threat Management (UTM) and intelligent routing into a single platform, it addresses the need for robust perimeter security without the administrative overhead typical of legacy hardware.
Key Features
Designed for medium-sized branch deployments, the Cisco 8200 Series Secure Routers combine robust security, advanced performance engineering, and flexible management options. These routers offer seamless connectivity, dynamic path selection, and unified security enforcement, helping ensure resilient operations and simplified IT overhead as your network grows. With integrated security and support for high-speed 10Gigabit Ethernet (GE) interfaces, these platforms deliver scalable and reliable performance for modern WAN edge deployments.
The Meraki MX portfolio is designed to unify enterprise-grade security, SD-WAN routing, and network visibility into a single, cloud-managed platform. Below is a concise overview of the core capabilities and features.
SD-WAN and Intelligent Routing
The MX portfolio utilizes dynamic path selection to optimize traffic based on real-time link performance. By monitoring latency, jitter, and packet loss, the appliance automatically steers business-critical traffic over the best-performing path—whether it is MPLS, broadband, or cellular—ensuring high availability for cloud applications and branch connectivity.
The MX integrates a robust suite of security services, including stateful inspection firewalls, Intrusion Detection and Prevention (IDS/IPS), and malware protection. By centralizing these functions, the platform provides comprehensive perimeter defense that automatically updates via the cloud to protect against emerging threats without manual intervention.
Content Filtering
To enforce organizational compliance and mitigate web-borne risks, the MX provides granular content filtering. It uses real-time URL categorization and reputation-based filtering to block access to malicious or inappropriate domains, allowing administrators to maintain a secure and productive digital environment across all branch locations.
XDR and Network Visibility
The MX platform serves as a critical telemetry source for Extended Detection and Response (XDR) ecosystems. By exporting detailed traffic logs and security events, it enables correlation across endpoints and cloud environments. This visibility allows security teams to identify anomalies, perform proactive threat hunting, and accelerate incident response times.
Secure Access (SASE/ZTNA)
The portfolio supports modern Secure Access Service Edge (SASE) architectures by integrating identity-aware security policies. This allows organizations to move toward a Zero Trust Network Access (ZTNA) model, ensuring that users are authenticated and authorized based on their identity and device posture, regardless of where they connect to the network.
VPN Concentrator
The MX is engineered to handle large-scale VPN topologies, providing high-throughput encryption for site-to-site and client-based VPNs. Its ability to manage complex tunnel configurations simplifies the deployment of secure remote access for distributed workforces while maintaining high performance for encrypted data transit.
Models
Model Number |
Ports and Interfaces |
PoE/PoE+ Capabilities |
Other Features |
C8235-G2-MX |
2x 10 GE SFP/SFP+ ports 8x 2.5 GE Multigigabit RJ-45 ports Up to 3 with LAN/WAN Conversion (Multi-WAN mode) |
2x 2.5 GE mGig RJ-45 UPoE+ PoE budget – 120 W |
Fanless model for medium sized branches Dedicated secure networking processor for fast cryptography and deep packet inspection Hardware acceleration that helps ensure high throughput with robust threat protection 1x RJ45 Console Port 1x RJ45 Management Interface |
Technical Specifications
Performance Specifications
C8235-G2-MX |
Maximum Firewall Throughput |
6 Gbps |
Maximum Site-to-Site VPN Throughput |
4 Gbps |
Advanced Security Throughput |
3 Gbps |
Recommended Device Count |
1,000 |
Maximum Recommended Tunnels |
750 |
Recommended Use Case |
Large branch secure routing and SD-WAN |
Power Specifications
Power supplies included by default |
1x 66W AC power supplies |
Optional power upgrade |
230W AC + PoE (120W PoE budget. PoE Available on ports 6 & 7) |
Typical power consumption |
45W (Not including PoE) |
Physical and Environmental Specifications
Attribute |
Value |
Mount Type |
Rack mount (19" included) |
Dimensions (H x W x D) |
1.65 x 8.9 x 12.7 in. (4.19 x 22.60 x 32.26 cm) 2.835 x 12 x 17.56 in. (7.20 x 30.48 x 44.60 cm) with rack-mount tray holding power supply |
Rack Units |
1 RU |
Weight |
7 lbs (3.17 kg) |
Input operating voltage |
85 to 264 Vac |
Operating temperature |
32° to 104°F (0° to 40°C), sea level |
Storage temperature |
-40° to 158°F (-40° to 70°C) |
Relative humidity |
Operating 5 to 85% non-condensing; storage 5 to 95% non-condensing |
SFP Specifications
The following SFP modules are supported on the C8235-G2-MX:
SFP+/ SFP Module |
10Gbps ports |
1Gbps ports |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Regulatory and Certifications
Ordering Information
Table 1: Router ordering information
Product ID |
Product Description |
C8235-G2-MX |
Cisco 8235 MX Secure WAN Platform for Meraki |
LIC- |
Cisco Sec 8000 MX Router Medium Essentials Sub LIC & Support |
LIC- |
Cisco Sec 8000 MX Router Medium Advantage Sub LIC & Support |
LIC-C8235-ENT-<XY> |
Cisco Secure 8235 MX Enterprise Lic & Support, (XY = 1Y, 3Y, 5Y, 7Y) |
LIC-C8235-SEC-<XY> |
Cisco Secure 8235 MX Adv Sec Lic & Support, (XY = 1Y, 3Y, 5Y, 7Y) |
LIC-C8235-SDW-<XY> |
Cisco Secure 8235 MX SDWAN Lic & Support, (XY = 1Y, 3Y, 5Y, 7Y) |
Warranty
MX Warranty coverage periods are as follows:
Product |
Warranty Period |
Warranty Information |
C8235-G2-MX |
2 Year |
Cisco 8200 Series Secure Routers come standard with a Cisco Limited 2-Year Return To Factory Hardware Warranty. |
Additional warranty information can be found on the Cisco Limited Hardware Warranty Terms page of the Cisco website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
To start a hardware replacement for non-functioning equipment under warranty, use the original packaging the hardware came in. The original packaging contains the device serial number and order details, which may be needed for return shipping.
Package Contents
All C8235 will be shipped with 1 x Power Cord (C13) with 1 x 66W Power Supply
Where ordered (as a spare), PoE Power Supplies will be shipped with 1 x Power Cord (C13) with 1 x 230W Power Supply
Accessories
Accessory |
Description |
MA-PWR-CORD-US |
1x AC power cable, U.S. plug (C13) |
MA-PWR-CORD-EU |
1x AC power cable, EU plug (C13) |
MA-PWR-CORD-UK |
1x AC power cable, UK plug (C13) |
MA-PWR-CORD-AU |
1x AC power cable, AU plug (C13) |
MA-PWR-CORD-BR |
1X AC power cable, BR plug (C13) |
Additional Resources
Cisco 8000 Series Secure Routers Frequently Asked Questions (FAQ)
