Home > Endpoint Management > Apps and Software > Removing Profiles and Apps from Managed Devices
Both profiles and managed apps can be removed from Systems Manager client devices remotely via dashboard. This article will cover multiple methods for removing both.
Remove Profiles/Apps from All Devices
If an app or profile must be removed from ALL managed devices, there are two possible approaches, dependent on whether the profile/app will be needed again in the future.
Permanent Removal
If the app/profile will not be needed in the future, it can be deleted from Systems Manager. Once deleted, it will be removed from all devices on which it was previously applied. To delete a profile/app:
  1. Navigate to the appropriate management page.
    • For apps:  Systems Manager > MDM > Apps
    • For profiles: Systems Manager > MDM > Profiles
  2. Click the checkbox next to the profile(s)/app(s) to be deleted.
  3. Click Delete.
  4. Confirm deletion by clicking the checkbox.
  5. Click Delete # checked profile(s).
    0552832f-c46d-4bd6-b227-532917c7d99a
Temporary Removal
If a profile/app should be be removed from all devices, but may need to be reapplied at a later date, the scope can be modified to not include any devices. To do this:
  3. Add a tag that is not applied to any devices (creating a new tag if needed).
    ex. Create and add a tag called "donotpush".
  4. Update the scope to "with ALL of the following tags".
    Note: This allows existing tags to be preserved. To revert, simply change the scope to its previous setting and remove the tag added above (i.e. "donotpush")
Remove Profiles/Apps from a Group of Devices
When one or more profiles/apps must be removed from multiple devices, there are several possible methods:
  • Modify the scope of the profile(s)/app(s) to no longer include the devices
    Note: Once a device is out of scope, it will no longer appear under the Clients in scope section of the profile/app page
  • Modify tags on devices to remove them from the scope of the profile(s)/app(s)
  • Force uninstallation of app from select devices (does not apply to profiles)
    1. From the Systems Manager > MDM > Apps page, select the app to be removed.
    2. Under the Clients in scope section, click the checkbox next to any devices that should have the app removed.
    3. Click Systems Manager > Manage > Uninstall
      Note: For app removal from the device to be permanent, it may be necessary to remove the device from scope as well. Otherwise, the app may be reinstalled later.
Remove Profiles/Apps from a Single Device
When one or more profile(s)/app(s) need to be removed from a single device, it is best to modify the tags associated with that device to remove it from the scope of the profile(s)/app(s).
Alternatively, specific apps can be manually removed:
  1. Navigate to Systems Manager > Monitor > Clients and select the device in question.
  2. Under Apps, find the row for the app to be removed.
  3. Click Remove.
Remove All Profiles/Apps from Devices
In the event all profiles and apps must be removed from one or more devices, it is possible to perform a selective wipe and place the device(s) into quarantine. When this is done, all managed profiles and apps will be removed from the device as soon as possible (see client behavior section below) and no additional profiles/apps will be deployed. This will remain in effect, regardless of any tags applied, until the device(s) is/are removed from quarantine and authorized. This is useful when a device should have no managed content/settings, but should still be tracked and controlled in Systems Manager.
To perform a selective wipe:
  1. Navigate to Systems Manager > Monitor > Clients.
  2. Click the checkbox next to the device(s) to have all profiles/apps removed.
  3. Click Quarantine > Selective wipe.
  4. If a specific device is then browsed to, a warning will be displayed indicating that the device is in quarantine.
    7f41fac8-31c0-4096-96c5-c10a74c9e885
For more details, refer to the knowledge base article on selective wipe.
Client Behavior on Removal
Once a managed app or profile has been queued for uninstallation, the client device will process that once the command has been received. The time this takes can vary by device and various other factors. Ensure that the client device is unlocked, powered on, and connected to a wireless network or mobile data in order to receive the command.  If Wifi settings are removed, and no other auto-join networks are configured or mobile data enabled, the device will not be able to communicate to systems manager or the internet following removal until the device is manually reconnected.
Note: Only managed apps can be be removed. If the app was installed manually, or via another means, it will not be possible to remove it remotely from systems manager.
iOS Devices
Apps/profiles and associated settings will be removed in the background once unlocked. The user will not be prompted.
Android Devices
User will be prompted to remove apps via a notification. Once confirmed, the app will be uninstalled. Profiles and associated settings will be removed silently in the background.
Disable Auto-Install Option
Apps can be configured to not auto-install or auto-remove. This disable auto-install option is available on the app details page beneath Scope. When this option is checked, apps will NOT automatically be removed when a client device is no longer in scope. The app will need to be manually uninstalled by the user or using the Systems Manager > Manage > Uninstall option under the Clients in scope section.
Confirming Removal
Once an a app or provide has been removed from a device it can be confirmed from the client details page. From the Systems Manager > Monitor > Clients page, select the client to check.
Profiles
Once a profile has been removed, it will no longer appear under the Profiles section of the client details page.
Apps
Once an app has been removed, it will no longer appear under the Apps section of the clients details page. There will also be an entry in the Activity log showing that the app was removed or if removal is pending.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
