Home > Enterprise Mobility Management > Device Enrollment > Apple DEP unable to connect
Table of contents
No headers
As part of new software releases (such as iOS 8), Apple often makes updates to their Terms and Conditions. Continuing to use Apple services requires acceptance of these new terms. For customers using Apple DEP (Device Enrollment Program), this can result in the error "Unable to connect to Apple's servers at this time" (or a similar message) on the MDM > DEP page.
To address this problem, login to deploy.apple.com and accept the new terms and conditions. All DEP administrators must accept the new terms to continue managing MDM servers and devices.
However, only the Agent can reactivate the service for an organization. The Agent is the Apple ID that originally setup the DEP account with Apple. Only the Agent will have an Admins tab after logging in. Once the Agent accepts the terms and conditions, DEP access will be restored and everything should behave normally.
Unfortunately, at this time there is no tool to determine who the Agent for an organization is. If this user is unknown or cannot be found, please contact Apple support.
For more information, please refer to the following Apple support article.
You must to post a comment.
Last modified
20:36, 2 Feb 2015
Tags
This page has no custom tags.
Classifications
Article ID
Contact Support
Open a Case
