Home > Enterprise Mobility Management > Monitoring and Reporting > Issuing Ctrl-Alt-Del in System Manager Remote Desktop
Table of contents
No headers
Remote administrators may need to remotely issue a Ctrl-Alt-Del command over a remote desktop connection. The following instructions detail how to issue a Ctrl-Alt-Del command over a Systems Manager remote desktop session:
  1. Navigate to Monitor > Remote Desktops.
  2. Select the check box "Launch in External Window"
  3. Click the Name of the remote desktop you wish to launch.
  4. This will launch the Java VNC pop-up.
  5. Click the button "Send Ctrl-Alt-Del" at the top of the Java VNC pop-up.
You must to post a comment.
Last modified
13:14, 5 Feb 2015
Tags
This page has no custom tags.
Classifications
Article ID
Contact Support
Open a Case
