Home > Endpoint Management > Other Topics > Configuring EAP-TLS Wireless Authentication with Systems Manager Sentry Wifi
Systems Manager Sentry Wi-Fi security provides automatic certificate-based EAP-TLS configuration in just a few clicks, eliminating the need for the use of a certificate authority (CA) and the additional management required for each device and user.
This article outlines how to integrate SM Sentry with Cisco Meraki MR access points for EAP-TLS wireless authentication.
Use Case
Commonly, network administrators want to configure different settings for corporate owned devices, employee owned devices, and guests. Each group of users will likely have their own separate SSID, with an additional SSID for onboarding:
SSID
Use Case
Default SSID Policy
Corp
Corporate-owned devices only
Full access on Corporate VLAN
BYOD
Employee-owned devices
Limited Corporate access
Some apps optionally limited
Higher bandwidth than Guest
Guest
All others
Filtered Internet
Rate limit
No corporate devices
Corp-onboarding
Onboarding to Corp network only
Restricted to onboarding
Configuring EAP-TLS using Systems Manager Sentry WiFi Security
The following instructions explain how to apply EAP-TLS wireless access to corporate-owned devices tagged as "Corp" in our example Systems Manager network.
  1. In Dashboard, navigate to Wireless > Configure > SSID and enable/name each SSID.
    The example image below shows four SSIDs: SL-corp, SL-byod, SL-guest and SL-corp-onboarding:
  2. Navigate to Wireless > Configure > Access Control:
  3. Select the device tags to be associated with EAP-TLS. This automatically creates a Systems Manager profile for the SL-corp SSID to use EAP-TLS and installs a client certificate from the Dashboard for each client (this profile will not appear under Systems Manager > Manage > Settings). Note that wireless authentication settings should be provisioned from either the SSID side, as described in this article, or the MDM profile side in Systems Manager > Manage > Settings and not both.
Sentry Wifi security is not to be confused with Sentry enrollment, as shown in the splash page configuration below. Sentry enrollment is typically deployed as a separate SSID (SL-corp-onboarding in this article) to initially enroll devices into Systems Manager, while Sentry security grants secure wifi access to devices already enrolled.
  1. Click Save Changes. EAP-TLS is now configured for all devices tagged corp in Systems Manager.EAP4.png
Sentry WiFi Device Operating System Compatibility
Operating System Sentry WiFi Supported
iOS  Yes
macOS Yes
tvOS No
Windows 10
Yes1
Android
Yes2
Samsung Knox 3.0+
Yes3
Chrome OS No
1. Local user accounts only. In a multi-user environment on a single device the Sentry WiFi profile may need to be pushed for each user.
2. Android 6+ in BOYD mode or Device Owner mode. Android 5 does not work with Sentry WiFi.
3. A passcode is required on the device while in Knox mode.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
