Home > Enterprise Mobility Management > Profiles and Settings > Troubleshooting Apple MDM Push Certificate Renewal
If you have renewed your Apple Push Notification Service certificate and dashboard is reporting that your devices are out of compliance, this means that something went wrong with the renewal process and another certificate was generated rather than an actual renewal.  This article walks through recovering the APNS communications chain and reestablishing contact with these devices through APNS.
Identifying the Correct APNS Certificate
APNS certificates are generated uniquely, but all certs for a given certificate chain will share a common Subject which includes the Push Topic (generally a common identifier for the set of devices this push request can communicate with). Dashboard presents the current push topic under Organization > MDM > Apple MDM:
Before renewing, you can use this value to ensure you're renewing the appropriate certificate by checking this Topic against the values listed in Apple's Identity Portal:
Incorrect Certificate was Used/Renewed
Following an APNS Certificate renewal, if you see the following message under Systems Manager > MDM > Add Devices > iOS or OSX, you may have renewed with the wrong certificate:
If
If this is the case, there are two simple recovery options:
Upload the Old APNS Certificate to Dashboard
If you have access to the previous APNS certificate, you can put it back into Dashboard and reestablish communication using the following steps:
  1. Navigate to Organization > MDM.
  2. Click the Update/Renew button.
  3. Skip steps one and two, jumping immediately to step 3. Fill in the Apple ID used to generate the old APNS certificate.
  4. Upload the old APNS certificate to dashboard.
  5. Save Changes.
This will reestablish communication with your enrolled devices while you determine what went wrong with the previous renewal.
Renew the Correct APNS Certificate
If you don't have access to a copy of the old APNS Certificate, Meraki Support can provide you with a copy of the old APNS Topic which you can use to identify the correct APNS certificate for renewal by using the information above. You can then follow the normal process for renewing an APNS certificate.
You must to post a comment.
Last modified
15:59, 9 Sep 2016
Tags
This page has no custom tags.
Classifications
Article ID
Contact Support
Open a Case
