Cisco Meraki US Government Region Cloud Support for Cloud-Managed IOS XE Switches
Overview
Cisco Meraki US Government Region supports eligible Cisco C9000 Series and MS390 switches, enabling customers to onboard and manage supported switches running IOS XE in the Cisco Meraki US Government region, which has a FedRAMP Class C (Moderate) ATO. Full support is available for configuration source: cloud and configuration source: device. See the currently supported platform families.
Always verify the model before deployment. For minimum software requirements, see Cloud Management with IOS XE – Supported Models With Minimum Required Software Versions. See below for Cisco Meraki US Government Region supported models.
Supported Platforms
Product family Supported models Cloud Config Device Config
MS390 MS390-24, MS390-24P, MS390-24U, MS390-24UX, MS390-48, MS390-48P, MS390-48U, MS390-48UX, MS390-48UX2 Yes No
Catalyst 9200 / 9200L C9200-24T, C9200-24P, C9200-24PB, C9200-24PXG, C9200-48T, C9200-48P, C9200-48PL, C9200-48PB, C9200-48PXG; C9200L-24T-4X, C9200L-24P-4X, C9200L-48T-4X, C9200L-48P-4X, C9200L-48PL-4X, C9200L-24PXG-4X, C9200L-48PXG-4X, C9200L-24PXG-2Y, C9200L-48PXG-2Y, C9200L-24T-4G, C9200L-24P-4G, C9200L-48T-4G, C9200L-48P-4G, C9200L-48PL-4G
Yes Yes
Catalyst 9300 family
C9300-24T, C9300-24P, C9300-24U , C9300-24UX , C9300-48T , C9300-48P, C9300-48U , C9300-48UXM, C9300-48UN, C9300-24S, C9300-48S , C9300X-12Y, C9300X-24Y, C9300X-48HXN, C9300X-24HX, C9300X-48HX, C9300X-48TX, C9300L-24P-4X, C9300L-24T-4X, C9300L-24UXG-4X, C9300L-48P-4X, C9300L-48PF-4X, C9300L-48T-4X, C9300L-48UXG-4X, C9300-24UB, C9300-24UXB, C9300-48UB, C9300-24H, C9300-48H, C9300L-24T-4G, C9300L-48T-4G, C9300L-24P-4G, C9300L-48P-4G, C9300L-48PF-4G, C9300L-24UXG-2Q, C9300L-48UXG-2Q, C9300LM-48UX-4Y, C9300LM-48U-4Y, C9300LM-24U-4Y, C9300LM-48T-4Y
Yes Yes
Catalyst 9350
C9350-24T, C9350-48T, C9350-48TX, C9350-48HX, C9350-24P, C9350-48P, C9350-24U, C9350-48U
C9350-24HX, C9350-48HXN
Yes Yes
Catalyst 9500 high-performance C9500-48Y4C, C9500-24Y4C, C9500-32C, C9500-32QC Yes Yes
Catalyst 9500 C9500-12Q, C9500-16X, C9500-24Q, C9500-40X No Yes
Supported software
IOS XE 17.18.4.1 is currently the latest recommended release available in the Meraki US Government Region cloud. Additional releases will be added as they are qualified for Meraki US Government Region Cloud.
Before you deploy
  • Confirm your exact switch model is supported in the current Meraki US Government Region compatibility information.
  • Review the Known Limitations before production deployment.
When migrating a switch from the commercial Meraki Dashboard to Cisco Meraki US Government Region Cloud, a reload of the IOS XE switch is recommended before onboarding to help provide a smoother migration experience. Plan for the associated maintenance window and service interruption.
Known Limitations
  • Intelligent Packet Capture: Packet capture capabilities including Intelligent Packet Capture are not currently supported in Cisco Meraki US Government Region. Support is planned for a subsequent release.
  • Event Logging in Cloud Mode: Event Logs in Cloud Mode are supported only on IOS XE 17.18.4.1 and later. Switches running an earlier supported IOS XE version can still be onboarded to Meraki US Government Region - Cloud Mode; however, Event Logs will remain unavailable until the switch is upgraded to IOS XE 17.18.4.1.
  • Device mode: Firmware Upgrades not available at launch. Support is planned as a fast follow.
IOS XE 17.18.4.1 is the recommended release and the network default version for Cisco Meraki for US Government. Eligible switches running a lower version will be upgraded to the network default through the standard firmware upgrade process, which may require a maintenance window and switch reboot.
To learn more about Cisco Meraki for US Government, see Cisco Meraki US Government Region.
