Cloud Monitoring End of Service - Transition to Cloud Management - Configuration Source: Device
Cloud Monitoring End-of-Service Extended to March 31, 2026 : The end-of-service date for Cloud Monitoring has been extended by two months from January 31, 2026 to March 31, 2026, to allow customers additional time to complete their upgrade process. All other terms remain unchanged.
Required Actions for Switches Not Migrated by March 31
Switches not migrated to device configuration mode before March 31 (Cloud Monitoring decommission) will not have their configurations removed automatically as part of the offboarding process and will require manual cleanup of the cloud monitoring specific configuration. To avoid manual intervention, complete all steps outlined in the Required Actions for Switches Not Migrating to Configuration Source: Device Before March 31 section of this documentation.
Help us improve your experience. Complete this quick survey to share your feedback on Cloud Monitoring or Configuration Source: Device.
Overview
Cloud Montioring for Catalyst is transitioning to configuration source: device and all Cloud Monitoring switches must transition by March 31, 2026.
All new Catalyst switches must now be onboarded directly into configuration Source: device (17.15.3+) via the Dashboard; the onboarding application for Cloud Monitoring is no longer available.
After this date, cloud monitoring switches will gradually appear offline in the dashboard over the next few weeks, but device operations will continue without any impact.
End of Service Milestones
May 1, 2025 Starting this day, only dashboard organizations with existing Cloud Monitoring switches onboarded to Dashboard can onboard to Cloud Monitoring with the onboarding application.
New dashboard organizations must onboard Catalyst switches with configuration source: device (17.15.3+). Cloud Management with IOS XE
November 1, 2025 This is the last day any dashboard organization can onboard to cloud monitoring with the onboarding application. After this date, all Catalyst switches must be onboarded with configuration source: device (17.15.3+) via the Dashboard. Cloud Management with IOS XE
March 31, 2026 (Extended date) Last day Cloud Monitoring switching features will function. Cloud Monitoring switches that have not transitioned to configuration source: device (17.15.3+) will be marked disconnected in the dashboard. There will be no impact to device operations.
How to transition to Cloud Management - Configuration Source: Device
For a guided walkthrough on how to upgrade to device configuration mode, view this video tutorial.
Required Actions for Switches Not Migrating to Configuration Source: Device Before March 31st (Cloud Monitoring Decommission)
Switches not migrated to device configuration mode before March 31 will not have their configurations removed automatically as part of the offboarding process and will require manual cleanup of the cloud monitoring specific configuration. To avoid manual intervention, complete all steps outlined below before March 31:
  • Remove the desired switch(es) from Dashboard networks. Follow the steps below:
    • Manual Cleanup Required: Switches Not Migrated Before March 31
      Switches not migrated to device configuration mode before March 31 (Cloud Monitoring decommission) will not have their configurations removed automatically as part of the offboarding or removal process and will require manual cleanup of the cloud monitoring specific configuration.
      Standard Offboarding Process for Cloud Monitored Switches (Only applicable before March 31)
      To remove a switch from the dashboard and cloud monitoring, follow the standard process for removing a device from a Meraki network seen in the article, Adding and Removing Devices from Dashboard Networks.
      From the switches page, select the checkbox next to the desired switch(es) and then click Edit > Remove from network. You will be asked to confirm the removal of the selected switch(es). Once confirmed, this action will trigger an Embedded Event Manager (EEM) script on each affected switch. The script is designed to automatically clear all configurations previously applied for integration with the dashboard. This effectively severs any active tunnel connections to the cloud, ensuring that the switch(es) will no longer be managed by the Meraki Cloud.
      AAA configurations added specifically for Cloud Monitoring will not be automatically removed.
      After March 31, once Cloud Monitoring is decommissioned, clicking Remove from network in the dashboard will no longer trigger automatic configuration cleanup on the switch. Any remaining Cloud Monitoring configurations must be removed manually. See the Manual Cleanup Required: Switches Not Migrated Before March 31 section for instructions.
  • Wait 10-15 minutes for the dashboard integration configurations to be automatically removed. This will remove any active tunnel connections to the Meraki Cloud.
Dashboard Configuration Clean Up EEM Script (Manual Removal)
The enhanced EEM scripts with step-by-step instructions will automatically remove all Cloud Monitoring configurations, including AAA.
The following Embedded Event Manager (EEM) scripts need to be configured and executed on Catalyst IOS XE switches manually to remove all Cloud Monitoring residual configurations. This script will remove all configurations including AAA configurations.
Scripts automatically discover and remove the cloud IP configuration. If the cloud IP cannot be confirmed, it must be removed manually. See the Manual Cleanup section for details.
The cleanup is split into two scripts that must be run sequentially. The first handles interface and global configuration, and the second addresses cloud IP routes and AAA settings. Both scripts log all configuration changes to syslog for audit purposes. Logging is automatically removed as part of each script’s self-cleanup, so it does not persist after execution. After both scripts are complete, manual verification is required to confirm all configurations have been successfully removed.
Scripts
Purpose
Runtime
Script 1: MERAKI-CLEANUP-PHASE1
All Meraki configurations except AAA and cloud/shard IP configs
2–15 minutes
Runtime depends on stack members and interfaces including Port-channel
Script 2: MERAKI-CLEANUP-PHASE2
Cloud IP discovery/removal and AAA method lists
30-60 seconds
Before You Begin
  1. Ensure you have console or SSH access at privilege 15 (do not use a Merak-managed VTY session).
  2. Take a configuration backup before proceeding (optional).
copy running-config flash:pre-cleanup-backup.cfg
Running the Scripts
The full scripts are included at the end.
  • Load Script 1
config terminal
! Paste the MERAKI-CLEANUP-PHASE1 applet (in chunks if terminal stalls)
end
show run | section event manager applet MERAKI-CLEANUP-PHASE1
  • Run Script 1
event manager run MERAKI-CLEANUP-PHASE1
  • After running the script, wait 2-5 minutes to confirm the switch is stable before proceeding.
  • Verify completion
show logging | include MERAKI-CLEANUP-PHASE1
  • Expected final log entry
MERAKI-CLEANUP-PHASE1: Completed. Run MERAKI-CLEANUP-PHASE2 to remove AAA and cloud configs.
  • Spot-check – only AAA method lists and any shard-related (logging host, snmp-server host, ip route) should remain.
show run | include MERAKI
  • Load Script 2
config terminal
! Paste the MERAKI-CLEANUP-PHASE2 applet
end
  • Run Script 2
event manager run MERAKI-CLEANUP-PHASE2
  • Verify completion
show logging | include MERAKI-CLEANUP-PHASE2
MERAKI-CLEANUP-PHASE2: Completed. Meraki cleanup finished.
  • Final verification – all Meraki references should be gone
show run | include ^aaa
show run | section line vty
show ip access-lists | include MERAKI
show run | section log config
Manual Cleanup (If Needed)
Script 2 automatically discovers and removes the cloud IP configuration. If it could not confirm the cloud IP, the following items must be removed manually.
Note: The steps below are only needed if the script fails to identify and clean the cloud IP configuration.
  • Verify Script 2 completed: show logging | include MERAKI-CLEANUP-PHASE2
  • If you do not see Cloud IP confirmed in the output, remove the following manually, replacing <shard_ip> with the actual IP.
SNMP host:
config terminal
no snmp-server host <shard_ip> version 2c public
end
write memory
Logging host:
config terminal
no logging host <shard_ip>
end
write memory
Static route to shard:
config terminal
no ip route <shard_ip> 255.255.255.255 Null0
end
write memory
IPv6 ND Cache:
(Optional to remove)
config terminal
no ipv6 nd cache expire refresh
end
write memory
If needed, identify the shard IP from show run | include snmp-server host or show run | section crypto tls-tunnel (before Script 1 removes the tunnel).
event manager applet MERAKI-CLEANUP-PHASE1 authorization bypass
 event none sync no maxrun 900
 action 0001 syslog msg "MERAKI-CLEANUP-PHASE1: Starting - Discovery"
 action 0002 cli command "enable"
 action 0010 cli command "show run | include ^interface|flow monitor MERAKI|device-tracking attach-policy MERAKI|description.*eraki"
 action 0011 set _intf_data "$_cli_result"
 action 0020 cli command "show run | include ^line vty|login authentication MERAKI"
 action 0021 set _vty_data "$_cli_result"
 action 0100 syslog msg "MERAKI-CLEANUP-PHASE1: Interface cleanup"
 action 0101 cli command "config terminal"
 action 0102 cli command "archive"
 action 0103 cli command "log config"
 action 0104 cli command "logging enable"
 action 0105 cli command "notify syslog contenttype plaintext"
 action 0106 cli command "exit"
 action 0107 cli command "exit"
 action 0108 set _current_intf ""
 action 0109 set _meraki_lb ""
 action 010A foreach _line "$_intf_data" "\n"
 action 010B  regexp "action [0-9]" "$_line"
 action 010C  if $_regexp_result ne "1"
 action 010D   regexp "^(interface [^ ]+)" "$_line" _match _intf
 action 010E   if $_regexp_result eq "1"
 action 010F    set _current_intf "$_intf"
 action 0110   end
 action 0111   regexp "^ *(ip[^ ]*) flow monitor ([^ ]*MERAKI[^ ]*) (input|output)" "$_line" _match _ipver _monitor _dir
 action 0112   if $_regexp_result eq "1"
 action 0113    cli command "$_current_intf"
 action 0114    cli command "no $_ipver flow monitor $_monitor $_dir"
 action 0115    cli command "exit"
 action 0116   end
 action 0117   regexp "device-tracking attach-policy (MERAKI[^ ]*)" "$_line" _match _dt_policy
 action 0118   if $_regexp_result eq "1"
 action 0119    cli command "$_current_intf"
 action 011A    cli command "no device-tracking attach-policy $_dt_policy"
 action 011B    cli command "exit"
 action 011C   end
 action 011D   regexp "description.*eraki" "$_line"
 action 011E   if $_regexp_result eq "1"
 action 011F    regexp "Loopback" "$_current_intf"
 action 0120    if $_regexp_result eq "1"
 action 0121     set _meraki_lb "$_current_intf"
 action 0122    end
 action 0123   end
 action 0124  end
 action 0125 end
 action 0200 syslog msg "MERAKI-CLEANUP-PHASE1: Global config cleanup"
 action 0210 cli command "no snmp-server enable traps smart-license"
 action 0211 cli command "no snmp-server enable traps config-copy"
 action 0212 cli command "no snmp-server enable traps config-ctid"
 action 0213 cli command "no snmp-server enable traps config"
 action 0220 cli command "no telemetry ietf subscription 1001"
 action 0221 cli command "no telemetry ietf subscription 1002"
 action 0222 cli command "no telemetry ietf subscription 1003"
 action 0223 cli command "no telemetry ietf subscription 1004"
 action 0224 cli command "no telemetry ietf subscription 1007"
 action 0225 cli command "no telemetry ietf subscription 1011"
 action 0226 cli command "no telemetry ietf subscription 1012"
 action 0227 cli command "no telemetry ietf subscription 1013"
 action 0228 cli command "no telemetry ietf subscription 1014"
 action 0229 cli command "no telemetry ietf subscription 1015"
 action 022A cli command "no telemetry ietf subscription 1016"
 action 022B cli command "no telemetry ietf subscription 1017"
 action 022C cli command "no telemetry ietf subscription 1018"
 action 022D cli command "no telemetry ietf subscription 1020"
 action 022E cli command "no telemetry ietf subscription 1021"
 action 022F cli command "no telemetry ietf subscription 1024"
 action 0230 cli command "no telemetry ietf subscription 1030"
 action 0231 cli command "no telemetry ietf subscription 1031"
 action 0232 cli command "no telemetry ietf subscription 2002"
 action 0240 cli command "no telemetry transform MERAKI_INTF_STATS_DELTA"
 action 0241 cli command "no telemetry transform MERAKI_PORTCHANNEL_STATS_DELTA"
 action 0250 cli command "no device-tracking policy MERAKI_POLICY"
 action 0260 cli command "no flow monitor MERAKI_AVC_IPV4"
 action 0261 cli command "no flow monitor MERAKI_AVC_IPV6"
 action 0270 cli command "no flow record MERAKI_AVC_HTTP_SSL_IPV4"
 action 0271 cli command "no flow record MERAKI_AVC_HTTP_SSL_IPV6"
 action 0280 cli command "no flow exporter MERAKI_AVC"
 action 0281 cli command "no flow file-export default"
 action 02A0 cli command "no crypto tls-tunnel MERAKI-PRIMARY"
 action 02B0 cli command "no crypto pki trustpoint MERAKI_TLSGW_CA" pattern "yes/no|#"
 action 02B1 regexp "yes" "$_cli_result"
 action 02B2 if $_regexp_result eq "1"
 action 02B3  cli command "yes" pattern "#"
 action 02B4 end
 action 02C0 if $_meraki_lb ne ""
 action 02C1  syslog msg "MERAKI-CLEANUP-PHASE1: Removing loopback: $_meraki_lb"
 action 02C2  cli command "no $_meraki_lb"
 action 02C3 end
 action 0300 syslog msg "MERAKI-CLEANUP-PHASE1: VTY cleanup"
 action 0301 set _meraki_vty ""
 action 0302 set _vty_start ""
 action 0303 set _vty_end ""
 action 0304 set _candidate ""
 action 0305 set _cand_start ""
 action 0306 set _cand_end ""
 action 0307 foreach _line "$_vty_data" "\n"
 action 0308  regexp "^(line vty ([0-9]+) *([0-9]*))" "$_line" _match _hdr _s _e
 action 0309  if $_regexp_result eq "1"
 action 030A   set _candidate "$_hdr"
 action 030B   set _cand_start "$_s"
 action 030C   set _cand_end "$_e"
 action 030D  end
 action 030E  regexp "login authentication MERAKI" "$_line"
 action 030F  if $_regexp_result eq "1"
 action 0310   regexp "action [0-9]" "$_line"
 action 0311   if $_regexp_result ne "1"
 action 0312    set _meraki_vty "$_candidate"
 action 0313    set _vty_start "$_cand_start"
 action 0314    set _vty_end "$_cand_end"
 action 0315   end
 action 0316  end
 action 0317 end
 action 0320 if $_meraki_vty ne ""
 action 0321  syslog msg "MERAKI-CLEANUP-PHASE1: Found VTY: $_meraki_vty"
 action 0322  if $_vty_end ne ""
 action 0323   set _vty_stop "$_vty_end"
 action 0324  else
 action 0325   set _vty_stop "$_vty_start"
 action 0326  end
 action 0327  set _vty_cur "$_vty_start"
 action 0328  while $_vty_cur le $_vty_stop
 action 0329   cli command "do-exec clear line vty $_vty_cur" pattern "confirm|#"
 action 032A   regexp "confirm" "$_cli_result"
 action 032B   if $_regexp_result eq "1"
 action 032C    cli command "y" pattern "#"
 action 032D   end
 action 032E   increment _vty_cur
 action 032F  end
 action 0330  cli command "$_meraki_vty"
 action 0331  cli command "no rotary 50"
 action 0332  cli command "no access-class MERAKI_VTY_IN in"
 action 0333  cli command "no access-class MERAKI_VTY_OUT out"
 action 0334  cli command "no authorization exec MERAKI"
 action 0335  cli command "no authorization exec MERAKI_VTY_AUTH_Z"
 action 0336  cli command "no login authentication MERAKI"
 action 0337  cli command "no login authentication MERAKI_VTY_AUTH_N"
 action 0338  cli command "no transport input ssh"
 action 0340  cli command "no authorization commands 0 MERAKI"
 action 0341  cli command "no authorization commands 1 MERAKI"
 action 0342  cli command "no authorization commands 2 MERAKI"
 action 0343  cli command "no authorization commands 3 MERAKI"
 action 0344  cli command "no authorization commands 4 MERAKI"
 action 0345  cli command "no authorization commands 5 MERAKI"
 action 0346  cli command "no authorization commands 6 MERAKI"
 action 0347  cli command "no authorization commands 7 MERAKI"
 action 0348  cli command "no authorization commands 8 MERAKI"
 action 0349  cli command "no authorization commands 9 MERAKI"
 action 034A  cli command "no authorization commands 10 MERAKI"
 action 034B  cli command "no authorization commands 11 MERAKI"
 action 034C  cli command "no authorization commands 12 MERAKI"
 action 034D  cli command "no authorization commands 13 MERAKI"
 action 034E  cli command "no authorization commands 14 MERAKI"
 action 034F  cli command "no authorization commands 15 MERAKI"
 action 0350  cli command "exit"
 action 0351 end
 action 0400 syslog msg "MERAKI-CLEANUP-PHASE1: ACLs, SSH, users"
 action 0410 cli command "ip ssh pubkey-chain"
 action 0411 cli command "no username meraki-user"
 action 0412 cli command "exit"
 action 0420 cli command "no ip access-list extended MERAKI_VTY_IN"
 action 0421 cli command "no ip access-list extended MERAKI_VTY_OUT"
 action 0430 cli command "no ip ssh port 2222 rotary 50"
 action 0440 cli command "no username meraki-user" pattern "confirm|#"
 action 0441 regexp "confirm" "$_cli_result"
 action 0442 if $_regexp_result eq "1"
 action 0443  cli command "y" pattern "#"
 action 0444 end
 action 04F0 cli command "archive"
 action 04F1 cli command "log config"
 action 04F2 cli command "no logging enable"
 action 04F3 cli command "exit"
 action 04F4 cli command "exit"
 action 0500 cli command "no event manager applet MERAKI-CLEANUP-PHASE1"
 action 0501 cli command "end"
 action 0502 cli command "write memory"
 action 0503 syslog msg "MERAKI-CLEANUP-PHASE1: Completed. Run MERAKI-CLEANUP-PHASE2 to remove AAA and cloud configs."
event manager applet MERAKI-CLEANUP-PHASE2 authorization bypass
 event none sync no maxrun 180
 action 0001 syslog msg "MERAKI-CLEANUP-PHASE2: Starting - Cloud IP discovery"
 action 0003 set _cloud_ip ""
 action 0004 set _route_ip ""
 action 0010 cli command "show run | include ^snmp-server host"
 action 0011 set _snmp_data "$_cli_result"
 action 0012 cli command "show run | include ^logging host"
 action 0013 set _log_data "$_cli_result"
 action 0014 cli command "show run | include ^ip route.*Null0"
 action 0015 set _route_data "$_cli_result"
 action 0016 regexp "ip route ([0-9]+[.][0-9]+[.][0-9]+[.][0-9]+) 255.255.255.255 Null0" "$_route_data" _match _route_ip
 action 0017 if $_route_ip ne ""
 action 0018  string match "*$_route_ip*" "$_snmp_data"
 action 0019  if $_string_result eq "1"
 action 001A   string match "*$_route_ip*" "$_log_data"
 action 001B   if $_string_result eq "1"
 action 001C    set _cloud_ip "$_route_ip"
 action 001D    syslog msg "MERAKI-CLEANUP-PHASE2: Cloud IP confirmed: $_cloud_ip"
 action 001E   end
 action 001F  end
 action 0020 end
 action 0030 cli command "config terminal"
 action 0031 cli command "archive"
 action 0032 cli command "log config"
 action 0033 cli command "logging enable"
 action 0034 cli command "notify syslog contenttype plaintext"
 action 0035 cli command "exit"
 action 0036 cli command "exit"
 action 0037 if $_cloud_ip ne ""
 action 0038  syslog msg "MERAKI-CLEANUP-PHASE2: Removing cloud IP configs: $_cloud_ip"
 action 0039  cli command "no snmp-server host $_cloud_ip version 2c public"
 action 003A  cli command "no logging host $_cloud_ip"
 action 003B  cli command "no ip route $_cloud_ip 255.255.255.255 Null0"
 action 003C end
 action 0040 syslog msg "MERAKI-CLEANUP-PHASE2: AAA cleanup"
 action 0041 cli command "no aaa authentication login MERAKI local"
 action 0042 cli command "no aaa authentication login MERAKI_VTY_AUTH_N local"
 action 0043 cli command "no aaa authorization exec MERAKI local"
 action 0044 cli command "no aaa authorization exec MERAKI_VTY_AUTH_Z local"
 action 0050 cli command "no aaa authorization commands 0 MERAKI local"
 action 0051 cli command "no aaa authorization commands 1 MERAKI local"
 action 0052 cli command "no aaa authorization commands 2 MERAKI local"
 action 0053 cli command "no aaa authorization commands 3 MERAKI local"
 action 0054 cli command "no aaa authorization commands 4 MERAKI local"
 action 0055 cli command "no aaa authorization commands 5 MERAKI local"
 action 0056 cli command "no aaa authorization commands 6 MERAKI local"
 action 0057 cli command "no aaa authorization commands 7 MERAKI local"
 action 0058 cli command "no aaa authorization commands 8 MERAKI local"
 action 0059 cli command "no aaa authorization commands 9 MERAKI local"
 action 005A cli command "no aaa authorization commands 10 MERAKI local"
 action 005B cli command "no aaa authorization commands 11 MERAKI local"
 action 005C cli command "no aaa authorization commands 12 MERAKI local"
 action 005D cli command "no aaa authorization commands 13 MERAKI local"
 action 005E cli command "no aaa authorization commands 14 MERAKI local"
 action 005F cli command "no aaa authorization commands 15 MERAKI local"
 action 0060 syslog msg "MERAKI-CLEANUP-PHASE2: MGMT ACLs"
 action 0061 cli command "no ip access-list extended MERAKI_MGMT_IP_IN"
 action 0062 cli command "no ip access-list extended MERAKI_MGMT_IP_OUT"
 action 0063 cli command "no ipv6 access-list MERAKI_MGMT_IPV6_IN"
 action 0064 cli command "no ipv6 access-list MERAKI_MGMT_IPV6_OUT"
 action 0070 cli command "archive"
 action 0071 cli command "log config"
 action 0072 cli command "no logging enable"
 action 0073 cli command "exit"
 action 0074 cli command "exit"
 action 0080 cli command "no event manager applet MERAKI-CLEANUP-PHASE2"
 action 0081 cli command "end"
 action 0082 cli command "write memory"
 action 0083 syslog msg "MERAKI-CLEANUP-PHASE2: Completed. Meraki cleanup finished."
Important Notes
  • Pasting large scripts: If the terminal stalls during paste, split the script into smaller chunks and wait for the prompt between chunks.
  • Self-cleanup: Each script removes its own applet and the log config section after execution.
 If you have any questions or need additional assistance, please reach out to Support for further guidance.
  • Was this article helpful?
