Migration of a Cisco 9800 Wireless LAN Controller deployment to Cloud Managed – Design Best Practices
1. Overview
Recommendation: Review the Dashboard Cloud Architecture document to understand the basics of a Dashboard Organization and a Dashboard Network.
A Cisco Wireless 9800 deployment leverages the following configuration constructs: WLAN profiles, policy profiles, policy tags, site tags, and RF tags. Dashboard uses Organization, Networks, SSID Profiles, RF profiles, device tags, and per-SSID access policies.
Migrating from an On-Prem deployment with WLC to a Cloud Managed deployment with Dashboard is an IT operations change which includes adopting a different configuration model/paradigm; hence this migration cannot be taken as at a line-by-line configuration conversion. Rather, network engineers should look at the customer use-cases and requirements for the final deployment, classifying each existing SSID by traffic path, roaming scope, security policy, VLAN, and site coverage, before creating the target configuration in Dashboard.
The table below maps the On-Prem configuration constructs to the relevant cloud ones:
On-Prem Managed construct
Cloud Managed construct
WLAN profile
SSID or SSID Profile
Policy profile
Access control, VLAN, traffic shaping, and tunneling settings
Policy tag
SSID Profile assignment, network configuration, and AP tags
Site tag
There is no direct mapping as Dashboard will handle pushing the necessary AP configs
RF tag and RF profile
RF profile assignment
2. Migration Planning
Before you can plan a migration you need to answer some questions related to the current deployment in order to choose the right architecture to migrate to.
2.1. When should the network have a centralized or distributed data plane architecture?
To minimize the amount of risk and configuration changes needed for the underlying switching architecture and client VLAN design, it is recommended to maintain the existing network architecture when moving to cloud. This approach allows network engineers to upgrade or migrate to Cloud Managed devices, including access points (APs) and Cisco Campus Gateway, without having to redesign their networks.
The table below shows the mapping between the WLC deployment mode and the recommended Cloud Managed network architecture.
On-Prem Managed Access Point Deployment Mode
Recommended Cloud Managed Network Architecture
Local Mode with Central Switching
FlexConnnect Mode with Central Switching
Centralized with Campus Gateway
FlexConnect Mode with Local Switching
Distributed with Bridge Mode
After deciding on the network architecture, the 9800 WLC can be migrated to Campus Gateway operation, if supported. Otherwise, the WLC should be replaced with a Campus Gateway.
9800 to Meraki Flowchart
If you are unsure if you want to continue with the current network architecture, a few aspects of the network must be considered:
Question
Centralized indicator
Distributed indicator
Is seamless roaming required across all the APs in the network? If so, how many APs are deployed in the roaming domain?
Seamless roaming is required with more than 300 APs in the roaming domain. APs may cross Layer 3 boundaries.
Seamless roaming is required on less than 300 APs within the same client VLAN and subnet.
Should there be a single point of entry to the wired network?
Wireless client VLANs are only defined at the core or distribution switches where Campus Gateway connects.
Wireless client VLANs must be defined on all the switchports where the APs connect
Is scalable sharing of mDNS services across VLANs required?
The Campus Gateway will only allow configured mDNS service traffic and reply back on behalf of the mDNS service provider. Unconfigured mDNS services will be dropped. mDNS services are shared between wireless client VLANs. Location specific services is configured to ensure only nearby mDNS services are discovered.
All mDNS traffic will be allowed within the same wireless client VLAN with no option to filter mDNS traffic. APs can be configured to forward mDNS services between client VLANs. The mDNS service provider, not the AP, will reply back to mDNS service queries.
Is RADIUS proxy required?
RADIUS traffic is only between the Campus Gateway and RADIUS server. The APs will send all RADIUS traffic to the Campus Gateway, and the Campus Gateway will proxy the RADIUS traffic to the RADIUS server. Only the CG IP address will need to be added as the Network Access Server (NAS) in the RADIUS server.
Each AP will send RADIUS traffic directly to the RADIUS server. All AP subnets or each AP IP address will need to be added as a Network Access Server (NAS) in the RADIUS server.
3. Architecture
Dashboard provides per-SSID configuration for centralized and distributed wireless traffic. The forwarding model determines where client data is switched. When Centralized, the data will flow to the CG and be placed on ther user vlans there. When distributed, The AP will place the data on the user VLANs. Networks are not locked to one forwarding model. This is configured on a per-SSID basis.
Core decision: Choose the forwarding model per SSID. Use Campus Gateway for centralized campus traffic, bridge mode for distributed local switching, or both models on the same access points when requirements differ by SSID.
Design
Client data path
Best fit
Key Considerations
Centralized
AP to Campus Gateway over VXLAN, then to the upstream network
Large campuses, broad roaming domains (300 APs or more), and core-only client VLANs
AP to Campus Gateway reachability, latency, and upstream switch scale
Distributed
AP bridges traffic directly to its access switch
Branches, smaller sites, and local breakout
AP trunk VLANs, local DHCP and routing, and Layer 2 roaming scope
3.1 Centralized
Campus Gateway centralizes traffic from Cloud Managed access points. APs encapsulate tunneled SSID traffic in VXLAN tunnels and send it to Campus Gateway. Campus Gateway bridges the traffic to client VLANs on the upstream switch.
  • A Campus Gateway cluster
    • Terminates traffic from APs placed in different Dashboard Networks
    • Allows for scalable client fast roaming by serving as the Pairwise Master Key (PMK) cache
    • Provides mDNS gateway services for sharing mDNS services between client VLANs
    • Serves as the AAA proxy for all RADIUS traffic for centralized SSIDs
  • Campus Gateway hardware redundancy:
    • For no downtime, stateful failover, deploy two Campus Gateway chassis in an active-active cluster akin to HA SSO on WLC.
    • For stateless failover, a CG cluster can serve as the Disaster Recovery (DR) cluster for other CG Clusters akin to N+1 on WLC.
  • Networking Requirements
    • Provide routed IP reachability as well as a RTT of 20 ms between each AP and every Campus Gateway in the cluster.
    • Define the client VLANs only on the Campus Gateway and its upstream switch.
Availability dependency: A centrally tunneled SSID stops broadcasting when APs lose connectivity to the Campus Gateways configured to terminate that SSID. Locally bridged SSIDs on the same APs remain independent of that tunnel loss.
3.2 Distributed
In a distributed design, each AP bridges client traffic to its local switch. This model resembles local switching in a 9800 FlexConnect deployment.
  • Use bridge mode when client traffic does not need to be terminated centrally.
  • Configure the AP’s switch port as a trunk port and allow the AP management VLAN and every locally bridged client VLAN.
  • Keep the same client VLAN and subnet available across APs that require seamless Layer 2 roaming.
  • Limit the Layer 2 roaming domain and broadcast scope to the smallest practical area.
Note: A deployment can use both centralized and distributed forwarding on different SSIDs. For example:
  • Adopting Campus Gateway in a phased migration from a brownfield local bridged deployment. Each SSID is configured one at a time to tunnel to CG.
  • A branch office has a requirement for centralizing certain traffic (ex. a corporate SSID) that needs to tunnel to Campus Gateway while an operational or branch-local SSID bridges to the access switch.
3.3 Wireless Access Points
Starting with Wi-Fi 6E (with the exception of the C9136), all access points are able to be migrated from On-Prem managed by WLC and Cisco Catalyst Center to Cloud Managed by Dashboard and vice versa.
3.4 Site Tag to Dashboard Networks
FlexConnect Mode
In a FlexConnect Mode deployment on the Cisco 9800 WLC, a FlexConnect site is defined using the site tag. APs that are assigned the same Flex site tag are part of the same Flex site. The Flex site tag identifies the fast-roaming domain as client key caching and key distribution only happens within a single Flex site tag.
When migrating to a Cloud Managed deployment, a Dashboard Network defines the fast-roaming domain. APs within the same Dashboard Network are able share and cache the client PMKs. Because of this, it is recommended to create a Dashboard Network for each Flex site tag. This allows network admins to maintain the same distinct fast roaming domain for each site and logically group the APs as they were on the WLC.
Local Mode
In a Local Mode deployment on the Cisco 9800 WLC, the site tag does not necessarily define the specific site or location of the APs assigned to it. While site tags can be used to represent building or locations, a single location may also be divided up into multiple site for the WNCd load balancing on the WLC. Regardless how the site tags were assigned, clients are able to fast roam between APs of different site tags. Thus, it is not so simple to map a Dashboard Network to a site tag.
When planning out how to add APs to Dashboard Networks, network admins should consider both the location of the devices as well as the roaming domain.
  • Location of the devices: It is recommended to place devices that are in the same location (ex. same building or floor) within the same Dashboard Network. There is no concept of WNCd load balancing in Cloud Managed deployments with Campus Gateways. APs do not have to be split up to account for the WNCd, so they can be placed within the same Dashboard Network.
  • Roaming Domain: If fast roaming is only required within a building, the APs simply need to be placed with Dashboard Networks per building. For locations, like a campus or group of buildings, consider where clients are expected to roam, all the APs can be placed in a single Dashboard Network (up to 5000 APs), or, if following the recommendation of a Dashboard Network per building, Network Group can be utilized. A Network Group when paired with a Campus Gateway, allows clients to roam between APs in different Dashboard Networks. Please refer to the Network Groups and SSID Profiles (for Centralized Wireless Deployments) section for more information.
4. Switching
4.1 Access Point Switch Ports
The AP switch port design depends on the forwarding model of the SSIDs broadcast by the AP. A distributed deployment usually requires a trunk port. A fully centralized deployment usually requires a access port for the AP management VLAN.
Distributed
Centralized
AP management
Native or tagged management VLAN with routed reachability to Dashboard
Management VLAN with routed reachability to Dashboard and Campus Gateway
Client VLANs on AP port
Allow every locally bridged client VLAN
Client VLANs on the AP switch port is not required
  • Set the AP port to trunk mode when the AP is in distributed mode and needs to carry multiple VLANs.
  • Set the native VLAN to the AP management VLAN when management traffic is untagged.
  • Allow only required VLANs and keep the native VLAN consistent through the wired path.
  • Provide the required PoE class and confirm multigigabit link support where the AP requires it.
  • Allow outbound dashboard traffic from the AP management network. Refer to the Upstream Firewall Rules for Cloud Connectivity.
4.2 Campus Gateway uplinks
Campus Gateway is a one-armed, wireless traffic concentrator that uses Layer 2 trunk to the upstream network. The logical uplink is an LACP port-channel. All the data ports on the chassis come up by default in a single port-channel.
  • Configure an LACP port-channel on the upstream switch ports connected the Campus Gateway.
  • Allow the management, control, client, and required service VLANs on the trunk.
  • Place client default gateways on the upstream core or distribution switching layer.
  • Choose a upstream switching topology that meets the required balance of chassis redundancy and throughput.
For more information, please refer to the Campus Gateway Deployment Guide.
4.3 Network Groups and SSID Profiles (for Centralized Wireless Deployments)
For customers that have a requirement to have fast and seamless roaming across their entire deployment, spanning across multiple Dashboard Networks, you can configure Network Groups and SSID Profiles in addition to deploying a Campus Gateway. Please refer to the Multi-Network Roaming Deployment Guide for more information.
It is recommended to create one Network Group per roaming domain. Typically, a roaming domain is a campus with several buildings, with one Dashboard Network per building. For example, an organization may have multiple campuses (ex. A west coast campus and an east coast campus), and each campus is a fast roaming domain. In this case, it is recommened to create one Network Group for each.
In addition to grouping all the required networks within a Network Group, fast and seamless roaming across Dashboard Networks also requires that the SSID is configured to be centrally switched SSID to a Campus Gateway and defined using an SSID Profile. This profile is applied to every corresponding Network in the Network Group.
  • Create the campus-wide Network Group before applying shared SSID Profiles. A single Network Group per campus site is recommended.
  • Add every required Dashboard Network to the Network Group. These will be Networks that corresponds to the seamless roaming domain where the APs are broadcasting a common, centralized SSID.
  • Create one SSID Profile for each centrally switched SSID. This is required for roaming across Dashboard Networks, and ensures that configurations critical for roaming, like SSID name and security method, are kept in sync.
  • Apply the SSID Profile to each Dashboard Network that corresponds to a 9800 site tag using that SSID.
4.4 Multicast and mDNS
Multicast and mDNS behavior and configurations do not map directly 1:1 from 9800 WLC to Dashboard. Please refer to the below table to see differences in behavior.
9800 Behavior
Dashboard Configuration
Multicast-to-unicast conversion over the air (AP to client)
This is enabled on all Dashboard APs by default on a Network-wide basis.
IP multicast traffic forwarding
Campus Gateway does not currently support forwarding multicast traffic other than mDNS. The Campus Gateway will drop all non-mDNS multicast traffic.
If this is required today in the deployment, a distributed design with locally bridging is recommended.
Broadcast traffic forwarding
Campus Gateway does not currently support forwarding broadcast traffic. The Campus Gateway will drop all broadcast traffic.
Broadcast or multicast rate limiting
Use SSID traffic shaping and broadcast suppression controls
mDNS gateway or service policy
mDNS Gateway functionality is only available on Campus Gateway deployments.
Distributed deployments only support mDNS bridging.
IGMP snooping
Configure IGMP snooping on the upstream switching infrastructure
5. High Availability
5.1 Cloud Management Resilience
Dashboard uses an out-of-band cloud management architecture. Client traffic does not pass through the Dashboard cloud. If cloud connectivity is lost, access points use a locally stored safe configuration and clients generally continue to use the WLAN. Please refer to the Troubleshooting Lost Connectivity to Cisco Meraki Cloud document for more information.
5.2 Campus Gateway high availability
A two-member Campus Gateway cluster uses an active-active design. APs are load balanced across the gateways and maintain tunnel state for failover. This design is different from an active-standby 9800 Stateful Switchover pair.
9800 Configuration
Migration Considerations
Active-standby SSO pair
For a stateful failover, a two-member active-active Campus Gateway cluster for centralized SSIDs.
Does not apply for a distributed deployment.
Since APs and clients are load balanced across the Campus Gateway cluster members, the AP and client scale remains the same for a cluster of two. However, the total cluster throughput will double with the additional Campus Gateway chassis.
The failover time will be less than a second.
N+1 controller redundancy
For a stateless failover, a Campus Gateway cluster can serve as the Disaster Recovery (DR) cluster for other Campus Gateway Clusters for centralized SSIDs.
Disaster Recovery cluster must be in the same Dashboard Network as the primary cluster and must support the same set of client VLANs.
The failover time will be 9 to 11 seconds.
6. RF parameters
Since the 9800 and Dashboard RF configurations do not map 1:1, map RF design outcomes rather than for every 9800 Radio Resource Management setting. Dashboard RF profiles have the same settings as the RF profiles in the WLC. The below table highlights the differences, if any.
9800 RF Configuration
Dashboard RF Configuration
RF profile assigned to one or more APs
Coverage hole detection
Enabled by default and cannot be disabled.
Beacon, DTIM, EDCA, and airtime fairness controls
No direct Dashboard mapping
7. Roaming
The client decides when to roam. The infrastructure can reduce scan and authentication time, but it cannot force every client to select the same AP at the same threshold.
Architecture
Roaming Scope
Design Recommendation
Centralized
Across AP Layer 3 underlay boundaries for a tunneled SSID
APs tunnel to the same Campus Gateway cluster and use the centralized client VLAN.
Distributed Layer 2
Across APs that bridge to the same client VLAN and same subnet
The VLAN, gateway, DHCP scope, and policy remain consistent across the roaming domain.
Mesh
Across APs and mesh paths in the same network
Validate gateway AP selection, backhaul changes, and session continuity.
7.1 Fast Roaming Recommendations
  • 802.11k and 802.11v are enabled by default and provides neighbor information to supported clients.
  • Enable 802.11r to enable fast roaming.
    • When enabled, both the Fast Transition (FT) AKM and non-FT AKM will be configured. This allows devices that support FT to leverage Fast Transition while allowing legacy devices to connect with non-FT.
    • However, some legacy clients may see issues with seeing the Fast Transition AKMs enabled.
  • 802.11r is not supported in every AP traffic mode. It is only supported in:
    • Distributed: Bridge mode
      Note: 802.11r is not supported at scale for Distributed Layer 3 Roaming.
    • Centralized: Tunneling to Campus Gateway
  • It is not recommended to configure 802.11r in Adaptive 802.11r feature when supported clients need fast transition. If the network will have a mix of client types and capabilities, some non-FT capable clients may experience issues in connecting to a WLAN with Adaptive FT. Therefore, the recommendation will be to set 802.11r to Enabled if fast roaming is required.
  • Preserve SSID name, security method, VLAN, and policy consistency across the intended roam domain.
Migration Best Practices
  1. When planning the network migration, it is recommended to do a phased migration. Choose a pilot part of the network to migrate. Identify an area that is a dedicated roaming domain. Mixing On-Prem managed and Cloud Managed APs in the same roaming domain is not recommended as there will be a hard roam between these two. Slowly expand the migration as you validate the solution.
  2. For the migration sites, these APs are compatible with Cloud Managed Mode. All Wi-Fi 6E and Wi-Fi 7 APs and later, except the Cisco Catalyst 9136, are capable of migrating to Cloud Managed mode.
  3. Determine the deployment model for the wireless network.
    1. If a centralized deployment is required, deploy a Cisco Campus Gateway. The Campus Gateway should have the same client VLANs available as the WLC deployment. Depending on the migration strategy, existing CW9800H1 and CW9800L WLCs can be converted to Campus Gateway operation.
    2. If migrating from a distributed FlexConnect deployment, the Campus Gateway is not required. The APs will need to be configured with their SSIDs in bridge mode to allow for local switching at the switch port.
  4. During the migration period:
    1. Please disable DHCP Required on the WLC as well as Mandatory DHCP on Dashboard. In the case of roaming between the On-Prem APs and Cloud Managed APs, there will be a hard roam, but the client will maintain the same IP address, given the same VLAN availability, not re-DHCP. This will prevent issues with the client joining and passing traffic.
      Note: Please be aware that disabling DHCP Required will also disable IP Source Guard and Dynamic ARP Inspection on the Cloud Managed deployment. These features help in protecting the network from certain “man-in-the-middle” attacks and IP spoofing, respectively.
    2. Please disable ARP Proxy on the WLC to prevent MAC flapping issues on the switch.
      Note: If the client roams from the On-Prem managed deployment to the Cloud Managed deployment, the WLC will still see the client as joined until the idle timeout has passed. During this time, if ARP Proxy is enabled, both the WLC and Cloud Managed wireless devices will reply back to ARP requests, resulting in MAC flapping issues.
  5. There is no concept of RF grouping between a WLC and Dashboard, so to prevent the APs being detected as Rogue APs:
    1. On WLC, classify the Cloud Managed APs as friendly. Please refer to the guide here: https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/26-1/configuration-guide/wl-26-1-cg/g_classify_rogue_ap/information-about-classifying-rogue-access-points.html
    2. On Dashboard, add the broadcasted SSID or the On-Prem Managed APs to the SSID Allow List. Please refer to the guide here: https://documentation.meraki.com/Wireless/Operate_and_Maintain/User_Guides/Monitoring_and_Reporting/Air_Marshal#SSID_Allow_List
8. Additional resources
  • Was this article helpful?
