How to Assign a Static IP Address on a Cisco Meraki Access Point
Overview
This article explains how to configure a static IP address on a Cisco Meraki access point (AP). Meraki APs connect to a network with either dynamic (DHCP) or static IP configuration. DHCP is recommended, but you can configure a static IP address on an AP in two ways:
- From dashboard: Use this method when the AP is online in dashboard.
- Locally on the device: Use this method from the AP's local status page.
Prerequisites
Before you configure a static IP address, confirm the following requirements:
For the Dashboard method: The AP must be an active gateway. It must be online in dashboard and have either an active DHCP lease or a functioning static IP address. Do not use this method for devices acting as repeaters.
For the local method: You need the AP's local login credentials. If you did not configure local credentials in dashboard, use the default credentials. The username is the device's serial number, and the password is blank.
For APs with multiple LAN ports: Configure the static IP on the primary Ethernet port only. The secondary port does not support static IP configuration.
Access points with multiple LAN ports
Some models connect to the network through more than one LAN port. Before you assign a static IP, identify the primary port and confirm which port the AP uses.
Identify the primary Ethernet port
On the MR57, use the port labeled 0 (on the left) as the primary uplink when link aggregation is not enabled.
For more information about static IP assignment on Meraki MR ports, refer to the MR installation guides.
Determine which port the AP uses
To confirm which port the AP uses, physically inspect the device and compare it with the diagram in Identify the primary Ethernet port.
If you are not near the device, check dashboard:
Navigate to Monitor > Access points, and select the AP.
Under Status, locate LAN IP #:
If # is 1, the AP connects through its primary port.
If # is 2, the AP connects through its secondary port.
Step-by-step instructions
Choose one of the following methods. Both methods use the same static IP settings. If you specify a VLAN in the static IP configuration, the AP sends management traffic with an 802.1q tag for that VLAN. Make sure return management traffic is tagged the same way.
Assign a static IP address from Dashboard
Log in to Dashboard.
Navigate to Wireless > Monitor > Access Points, and select the name of the AP you want to configure.
On the device status page, select the Edit icon to the right of the current IP information. The device configuration expands.
Enter the connection information, and select Save.
Assign a static IP address locally
Connect to the AP, and open the Local Status Page.
Select Configure.
Enter your login credentials when prompted:
If you configured local login credentials in dashboard, use those credentials.
Otherwise, enter the device's serial number as the username, and leave the password blank.
On the Configure page, enter the new static IP information.
Verify that you are still connected to the correct SSID and AP. If the AP is in a scanning mode, it can change its channel and interrupt your wireless connection.
Select Save.
Verification
After the AP updates its configuration to include the new static IP, it tries to use that IP on the network. To confirm which port the AP uses, check LAN IP # under Status on the AP's dashboard page. For details, go to Determine which port the AP uses.
Troubleshooting
The AP falls back to DHCP
If the AP cannot reach the configured default gateway with the static assignment, it falls back to DHCP. If this happens, check the static IP configuration and the VLAN configuration on the network.
NAT mode SSIDs use the updated management address
If you update the static IP configuration, any SSID that uses Meraki DHCP (NAT mode) uses the updated management address for client traffic. For more information, refer to NAT Mode with Meraki DHCP.
Additional resources
For more information about configuring a new MR Access Point, please check out our MR Quick Start article.
