Cisco Meraki MR78 SES ESL Specifications
Overview
The Cisco Meraki MR78 is a Dual-band, 802.11ax, 2x2:2, cloud-managed entry-level outdoor Access Point. Designed for basic, medium-density deployments, the MR78 provides enterprise-grade security and simple management in a ruggedized IP67-rated form factor.
Please refer to the MR78 datasheet for detailed wireless-specific information.
MR78 supports SES-imagotag Electronic Shelf Labels (ESL) native integration. Please refer to our documentation for more information.
Note: All specified values are subject to change by SES-imagotag
MR Model |
MR78 |
| Integration Variant | VUSION Gate N |
| Product code (Vusion Cloud SKU) | CE: 11663 | FCC/IC: 11663 |
| V:IoT Radio | 2.4 GHz |
| V:IoT Radio Protocol | Proprietary |
| V:IoT Radio Antenna | Integrated |
| V:IoT Radio Channel Auto-Selection | Yes |
| V:IoT Radio Encryption | 128-bit Advanced Encryption Standard (AES) with secure key exchange |
| V:IoT Transmission Range | Up to 20 meters in open-field deployments (about 1250 m² or 13,400 sq ft area) |
| Coexistence Feature Support (V:IoT radio + Wi-Fi) | Smart Coexistence |
| Number of Labels Supported | Up to 10,000 labels per access point |
| Supported SES solution | VUSION Cloud |
| Connection Mode | Token-Based |
