Home > General Administration > Cross-Platform Content > Radio Settings > Manual Channel Selection and Transmit Power Adjustment
The ability to manually set the Radio Channel and Transmit Power on Meraki MR Access Points, MX64/65/67/68W Security Appliances and Z1/Z3 Teleworker Gateways gives you more granular control over the wireless coverage in your environment. You can successfully make these adjustments in the Cisco Meraki dashboard by following the steps below:
MR Access Points
  1. Log in to the dashboard.
  2. Navigate to Wireless > Configure > Radio settings.
  3. Using either the Map or List view, click on the AP you would like to adjust:
    516b9e60-e56b-478d-8036-598a8c0daf91
  4. In the section that appears to the right, use the Channel field to adjust the channel the indicated radio will operate on, and Power to indicate what power level to use:
    16d346f0-f83b-4adc-b099-0b6fa3c1706b
  5. Select the Save changes button. Please note that clients will be disconnected briefly when you change channels or power levels.
Note: The 2.4GHz radio on an MR access point can have its power set to "off." This will prevent this particular unit from serving clients with its 2.4GHz radio.
MX64/65/67/68W and Z1/Z3
  2. Navigate to Security & SD-WAN > Configure > Wireless settings (for the Z1/Z3 devices, Teleworker gateway > Configure > Wireless settings).
  3. Under Channel Settings, use the Channel field to adjust the channel the indicated radio will operate on, and Transmit power to indicate what power level to use.
    c10e291a-e97f-4ea5-888c-b57706c4723a
  4. Select the Save changes button. Please note that clients will be disconnected briefly when you change channels or power levels.
Best Practices
Manually setting the channel can improve roaming performance for clients who cannot seamlessly roam between APs on different channels. However, manual channel selection can also increase the amount of co-channel interference produced by nearby APs if using the same channel. Co-channel interference can also be improved by reducing the Transmit Power on nearby APs. When unsure if manual settings are needed, leave channel and power settings on Auto.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
