Home > General Administration > Licensing > Removing and Undoing License Claims
There are a number of licensing issues that are caused by misapplication of a single license key. If a license has been applied incorrectly, the undo license claim tool can be used to remove the license so it can be re-added correctly.
This article will explain how to remove licenses from organizations, using the undo license claim tool.
Use Cases
There are two common situations where a license application can cause problems on an organization:
  • License was applied to the wrong organization.
    A license may have accidentally been applied to the incorrect organization. The undo license claim tool will release the license so it can be applied to the correct organization.
  • License was incorrectly applied as a renewal or add devices.
    When a license key is applied to an organization, there are two options for the license type: Renewal or add devices. Applying a license as the incorrect type will have an undesired effect on the organization's licensing, and will likely take the organization out of compliance. The undo license claim tool can be used to remove the license, so it can be reapplied correctly.
    For more information on different ways to apply licenses, please refer to our documentation regarding Licensing Guidelines and Limitations.
Using the Undo License Tool
The undo license claim button will only be available within 7 days of the license application. For issues with older licenses, please follow these steps:
  1. Make sure you are a full organization administrator on both organizations. If not, this process will need to be followed by another admin.
  2. Contact support with the following information:
    • Your support passcodes for each organization.
    • The license key to be transferred.
    • (optional) If the license needs to be split, the device models and number of devices that need to be covered on the new organization.
The following steps explain how to undo a license application:
  1. In Dashboard, navigate to Organization > Configure > License info.
  2. Click the undo button next to the license in question:
  3. Review the confirmation window that pops up. If you are sure this is the correct license to remove, click Yes:
Upon confirming the change and closing the pop-up, the organization will be reverted to the previous licensing state. The original license will be invalidated, so a replacement key will be generated. The new license key can then be re-applied or added to another organization for the remaining license term. The new license key can also be found under Organization > Change log.
You must to post a comment.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
