How to Shape Traffic of a Local Subnet or Host
Introduction
This article explains how to configure traffic shaping rules for a local subnet or individual host on the Local Area Network (LAN) side of a Meraki MX Security Appliance or MR Access Point. Use a Custom expression in the rule definition to target Request for Comments 1918 (RFC 1918) private address ranges.
Use this guide to:
  • Cap or remove bandwidth limits for individual hosts
  • Apply traffic shaping rules to an entire private subnet
Prerequisites
  • Familiarity with Classless Inter-Domain Routing (CIDR) notation (e.g., /16 for a subnet, /32 for a single host)
Step-by-step instructions
MX security appliance
1. Navigate to Security & SD-WAN > Configure SD-WAN & Traffic Shaping
2. Select Create a new rule, or if rules already exist, select Add a new shaping rule
3. In the Definition field, select Add +
4. In the Custom expressions field, enter the local subnet:
  • For a subnet: localnet:172.16.0.0/16 where 172.16.0.0/16 is your private subnet range
  • For a single host: localnet:192.168.1.50/32 where /32 is the CIDR notation for a single host
5. Select Add + again to confirm the expression
6. Configure the following settings as required:
  • Bandwidth limit
  • Priority
  • Differentiated Services Code Point (DSCP) tagging value
7. Select Save changes
MR access point
1. Navigate to Wireless > Configure > Firewall & Traffic Shaping
2. Select your network from the SSID drop-down menu at the top of the screen
3. Next to Shape traffic, select the drop-down menu and choose Shape traffic on this SSID
4. Select Create a new rule
5. In the Definition field, select Add +
6. In the Custom expressions field, enter the local subnet:
7. Select Add + again to confirm the expression
8. Configure the following settings as required:
  • Per-device bandwidth limit
  • Priority Code Point (PCP) / DSCP tagging values
9. Select Save changes
Verification
After saving, confirm the rule has been applied correctly:
  • Return to Security & SD-WAN Configure > SD-WAN & Traffic Shaping and verify the new rule appears in the list with the correct Bandwidth limitPriority, and DSCP tagging settings.
MR access points
  • Return to Wireless Configure Firewall & Traffic Shaping, select your Service Set Identifier (SSID), and verify the new rule appears with the correct Per-device bandwidth limit and PCP / DSCP tagging values.
