Co-Term License Problem - Out of Compliance
Overview
This article explains the behavior of a co-termination Dashboard Organization when the licensing is out of compliance, along with procedures to make it compliant and the best practices to avoid an organization shutdown.
What Does It Mean to Be out of Compliance?
Meraki Licensing has a 1:1 device to license policy where each device claimed into the Organization must have an active license. When this criteria is not met, the organization will fall out of compliance. Any dashboard organization that has a device without an active license, will be considered as out of compliance.
Refer to  Meraki Licensing Guidelines and Limitations for more information.
Why Does an Organization Go out of Compliance?
An organization becomes non-compliant when it either:
  • Under-licensed (has insufficient licenses to support the devices in the Organization).
Or
When either of these events occurs, the organization will fall out of compliance and will automatically enter a 30-day grace period.
What Happens During the 30-Day Grace Period?
The 30-day grace period allows the organization to continue to operate normally for a period of 30 days after the organization falls out of compliance. During this time, the organization will continue to function as usual. The grace period remaining day is not visible to the administrator.
Organization administrators will receive weekly email reminders during the 30-day grace period. Refer to Organization setting to configure the license email notification recipient.
How to Regain Licensing Compliance?
In order to return to licensing compliance, you will need to do the following:
  • Adding new license(s) from Organization > Configure > License Info page. This page will highlight the missing licenses in red color. Adding the necessary licenses will automatically return your organization to a compliant state.
  • If you are no longer using unlicensed device(s), you may remove the device(s) from the dashboard network.
  • If you have further questions, contact your Meraki Sales representative or reseller.
If you do not take action to return the organization to licensing compliance state within the 30-day grace period, your organization will be shut down.
What if I need more time to finalize my Licensing?
If you require additional time to finalize your licensing, you may be eligible for a one-time grace period extension. Navigate to the License Info page (Organization > Configure > License Info) and click the Request grace period reset button after your license has expired.
The grace period reset is a one-time courtesy provided to allow for immediate operational continuity. Once this reset has been utilized, you must ensure that the required licenses are purchased and applied to avoid organization shutdown.
If you do not take action to return to a compliant state within the grace period, your organization will be shut down.
What Happens When an Organization Is Shut Down?
When an organization is shut down for non-compliance, the devices in the organization will be non-operational. The devices will cease to pass client traffic, but will continue to pass Meraki management traffic to check when the organization regains compliance. When an organization is out of compliance, you may see a splash page with "This network is misconfigured."
The Dashboard Organization Administrators will only be able to access the License Info page and the Device Status pages. This will allow the administrators to add new licenses, or remove devices, if necessary. The administrators will not be able to access any other sections of the dashboard organization to make other configuration changes until the organization has returned to compliance.
