Cisco Meraki
Problem Connecting Through a Netcomm Smart Hub 4G
Meraki devices will not get a valid DHCP OFFER from a Telus Netcomm Smart Hub 4G (3G38WV-TS) when the hub is configured for MBB IP Forwarding (Transparent Bridge) mode. Specifically, the DHCP OFFER does not provide a valid default gateway IP address. In addition, the hub only allows one MAC address to connect at a time. To disable this mode and set the hub behave as a NAT device with configurable DHCP server, navigate to Internet>LAN and set the MBB IP Forwarding (Transparent Bridge) mode drop down to disable.
  • Was this article helpful?
