Troubleshooting Duplex Mismatches Affecting Physical Link Speed
Overview
This document serves as a comprehensive guide to troubleshoot duplex mismatch issues that affect physical link speed between Ethernet peers. It provides step-by-step instructions to diagnose and resolve problems, aiming to minimize downtime and improve user experience.
When interconnecting two Ethernet peers, using auto-negotiation is recommended, which allows Ethernet peers to exchange link speed and duplex information.
This article covers troubleshooting procedures for:
  • Duplex mismatch issues between Ethernet peers
  • Physical link speed degradation caused by incorrect duplex configuration
  • Auto-negotiation configuration on Meraki Aps
Troubleshoot a duplex mismatch
Description: A duplex mismatch occurs when two interconnected Ethernet peers are operating with incompatible duplex settings. This results in packet loss due to collisions and degraded physical link speed.
Explanation:
Ethernet peers use electrical signals to determine when a link is established. These electrical pulses form a 16-bit word that defines the speed and duplex settings used during auto-negotiation.
When the speed and duplex settings of one Ethernet peer must be manually configured, it is important to configure the other peer with matching settings.
For example:
  • Peer 1 = 100 Full duplex, Peer 2 = 100 Full duplex
 or
  • Peer 1 = Auto-negotiation, Peer 2 = Auto-negotiation
Failing to configure interconnected Ethernet peers with matching duplex settings can result in a duplex mismatch. In a duplex mismatch condition, both peers may use the same wire pair to transmit data. Collisions can occur when both peers transmit electrical signals simultaneously.
These collisions can lead to:
  • Packet loss
  • Frame corruption
  • Reduced network performance
  • Reduced link speed
The following peer configuration combinations are known to cause this issue:
  • Scenario 1:
    • Peer 2 = Auto-negotiation
    • Result: Peer 2 will be able to detect the 100Mbps speed but defaults to half duplex, which will cause packet loss due to collisions.
  • Scenario 2:
    • Peer 2 = 100 Half duplex
    • Result: Peer 2 uses half duplex so collisions will occur.
Note: The Gigabit Ethernet standard requires auto-negotiation for both sides of a link. Gigabit peers should not be hardcoded to a particular speed or duplex.
Troubleshooting steps
  1. Enable auto-negotiation on both peers: When possible, configure both peers to use auto-negotiation. If Peer 1 = Auto-negotiation and Peer 2 = Auto-negotiation, the peers will successfully exchange link speed and duplex information.
  2. Verify Gigabit Ethernet compliance: If either peer is a Gigabit Ethernet device, ensure auto-negotiation is enabled on both sides. Do not hardcode speed or duplex on Gigabit peers.
  3. Configure auto-negotiation on Meraki APs: To set your Meraki APs to auto-negotiation, refer to Duplex negotiation on Meraki APs.
Expected outcome
After enabling auto-negotiation on both peers, the Ethernet link should successfully negotiate a matching speed and duplex setting. Packet loss due to collisions should cease, and physical link speed should return to expected performance levels.
Additional resources
For more information about duplex mismatch see:
http://en.wikipedia.org/wiki/Autonegotiation
http://en.wikipedia.org/wiki/Duplex_mismatch
For more information on how to set your Meraki APs to auto-negotiation see:
