Cisco Meraki
Finding the MAC Address on Popular Gaming Consoles
Sometimes it is necessary to add a gaming console to an explicit allow list because they are unable to interact with a splash page.
Please use the steps below to find the MAC address of popular gaming consoles. A MAC address is a unique alphanumeric identifier (can contain numbers 0-9 or letters A through F). MAC addresses are often broken up into pairs using colons or dashes (e.g.12:34:56:4a:5b:6c)
Note: It is critical to write down the MAC address correctly because every character is important.
Microsoft
Xbox
  1. Power on your Xbox without a disc in the system.
  2. Select Settings in the Xbox dashboard, then select Network Settings
  3. The MAC address of the system is located in the bottom right-hand corner of the Network Settings screen (It usually has “MAC=” in front of it).
Xbox 360
  1. Power on your XBOX 360 without a disc in the system.
  2. Scroll (if necessary) to My Xbox.
  3. On the right, select System Settings.
  4. On the next screen, select Network Settings.
  5. Select Configure Network.
  6. Select the Additional Settings tab.
  7. Select Advanced Settings.
  8. Toward the bottom of the screen you should see Wired MAC Address. The MAC Address consists of the characters below this.
Xbox One
  1. Go to My Xbox in the Xbox dashboard and select Settings.
  2. In the Settings pane, select Network.
  3. Select Advanced Settings from the Network Settings tab.
  4. At the bottom of this screen, you'll see a heading for Wired MAC and Wireless MAC
Xbox Series X or Series S
  1. Navigate to the Settings page.
  2. Select Network.
  3. Select Advanced Settings.
  4. Under IP settings, the MAC address will be listed next to Wired MAC and Wireless MAC on the right-hand side of the screen (this is also where the IP address and other information is located).
Sony
PlayStation 2
  1. Power on your PlayStation 2 with the Network Adaptor start-up disc
  2. Once the disc is loaded, select ISP Setup and then agree to the license agreement that is presented.
  3. When prompted for a network type, select Local Area Network (LAN)
  4. Next select Automatic Configuration
  5. At the Connection Test screen, select Advanced
  6. On the next screen you should see the MAC address of the system.
PlayStation 3
  1. Navigate to Settings.
  2. Select System Settings.
  3. Select System Information.
  4. View information on the PS3 system. The MAC address is shown there.
PS4
  1. Power on the PS4 without a disc in the system.
  2. In the PS4 menu, arrow up and select Settings.
  3. Scroll down to Network.
  4. Scroll down to View Connection Status.
  5. The MAC Address will be listed next to MAC Address (LAN) and MAC Address (Wi-Fi).
PS5
  1. Power on the PS5 without a disc in the system.
  2. In the PS5 menu, arrow up and select Settings.
Nintendo
Wii
  1. From the Wii Channel screen, select the Wii button, then go into Wii Settings
  2. On the second page, find the option Internet, then go to Console Information
  3. This screen should have a line with USB Ethernet Adapter MAC Address or LAN Adapter MAC Address or similar.
GameCube
  1. Remove the GameCube’s broadband adapter from the console.
  2. Printed on the underside of the adaptor is the MAC address.
DS
  1. From the menu, navigate to Nintendo Wi-Fi Connection Setup.
  2. Select Options, then System Information. The MAC address is on the top line.
3DS
  1. From the HOME menu, highlight and select System Settings.
  2. Select Internet Settings.
  3. Tap Other Information.
  4. Tap Confirm MAC Address. Your system's MAC Address will be displayed on the screen.
Wii U
  1. From the Wii U menu, select System Settings.
  2. Using the left stick, select the Internet icon and press the A button.
  3. Select View MAC Address and wait for the MAC Address to be displayed.
Nintendo Switch
  1. Select System Settings from the HOME menu.
  2. Scroll down and select Internet.
  3. The Nintendo Switch console's MAC address will be listed under System MAC Address.
Streaming Devices
Apple TV
  1. With your Apple TV remote, navigate to and select the Settings icon.
  2. From the Settings menu, select General.
  3. Under General, select Network.
  4. Your MAC Address will be next to either Wi-Fi Address or Ethernet Address, depending on how you are connected to the internet.
Roku/Roku Express
  1. On the back of your Roku there are six 2-digit pairs of numbers/letters separated by colons, e.g. 00:0D:0A:1H:3G:5C. One set is for Ethernet and the other set is for the wireless.
  2. Alternatively, from the Roku home screen, select Settings > Network and locate the value next to Wireless MAC Address.
  • Was this article helpful?
