Cisco Meraki
MG41 Internal Antenna Datasheet
NOTE:
Main 0 bandsB1, B2(B25), B3, B4(B66), B5(B26,B18,B19), B8, B12(B17), B13, B14, B20, B28, B29, B39, B71, B41 for 4x4 MIMO
Main 1 bandsB7, B30, B32, B38, B40, B41, B42, B43, B46, B48, B2(B25) for 4x4 MMO, B4(B66) for 4x4 MIMO
Div 0 bands - B1, B2(B25), B3, B4(B66), B5(B26,B18,B19), B8, B12(B17), B13, B14, B20, B28, B29, B39, B71, B41 for 4x4 MIMO
Div 1 bands - B7, B30, B32, B38, B40, B41, B42, B43, B46, B48, B2(B25) for 4x4 MMO, B4(B66) for 4x4 MIMO
The internal antenna on the MG41 are enclosed inside for a sleek look while maintaining excellent performance. When in use the internal antenna has a bias towards the front face. The dipole shape of coverage the antennas generally excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. A benefit of the internal antenna is the smaller footprint where it will be mounted. Internally, the MG41 has 2 main and 2 diversity antennas.
Specifications
Category Specifications
Electrical
Antenna Type
Planar Inverted F Antenna (PIFA)
Main 0 Antenna
Frequency Range
  • 789 (617 - 960) MHz
  • 1955 (1710 - 2200) MHz
  • 2500 (2300 - 2700) MHz
Peak Gain (per range)
  • 789 @ 2.7dBi
  • 1955 @ 2.92dBi
  • 2495 @ 2.61dBi
Polarization
Linear, vertical
Main 1 Antenna
Frequency Range
  • 1826 (1452 - 2200) MHz
  • 4663 (3400 - 5925) MHz
  • 789 @ 2.96dBi
  • 1955 @ 2.67dBi
  • 2495 @ 2.92dBi
Polarization
Linear, vertical
Div 0 Antenna
Frequency Range
  • 829 @ 1.3dBi
  • 1940 @ 2.86dBi
  • 2495 @ 2.85dBi
Polarization
Linear, vertical
Div 1 Antenna
Frequency Range
  • 789 @ 2.99dBi
  • 1955 @ 2.74dBi
  • 2495 @ 4.59dBi
Polarization
Linear, vertical
Physical and Environmental
MG41 Dimensions
168 x 168 x 35mm
MG41 Operating Temperature
-30°C to 50°C (-22°F to 122°F)
Material of Radiator
Sheet metal
Regulatory Certified for use in the MG41
Radiation Patterns
Main 0 Antenna
clipboard_e8c85cdec651a21125e372b26832796ff.pngclipboard_e7ce79fdfd5c05d65261ddda1f7d95eda.png
Main 1 Antenna
clipboard_e92a0c20cee6d4b09e82ba4eb5f947e98.pngclipboard_e7ce79fdfd5c05d65261ddda1f7d95eda.png
Div 0 Antenna
clipboard_e9825f94bf8e2fb1380aa2fdb7b4ad2e6.pngclipboard_e7ce79fdfd5c05d65261ddda1f7d95eda.png
Div 1 Antenna
clipboard_e1231e454790e53eb2bf8931bf0e27d13.pngclipboard_e7ce79fdfd5c05d65261ddda1f7d95eda.png
  • Was this article helpful?
