MG41 Internal Antenna Datasheet
NOTE:
Main 0 bands - B1, B2(B25), B3, B4(B66), B5(B26,B18,B19), B8, B12(B17), B13, B14, B20, B28, B29, B39, B71, B41 for 4x4 MIMO
Main 1 bands - B7, B30, B32, B38, B40, B41, B42, B43, B46, B48, B2(B25) for 4x4 MMO, B4(B66) for 4x4 MIMO
Div 0 bands - B1, B2(B25), B3, B4(B66), B5(B26,B18,B19), B8, B12(B17), B13, B14, B20, B28, B29, B39, B71, B41 for 4x4 MIMO
Div 1 bands - B7, B30, B32, B38, B40, B41, B42, B43, B46, B48, B2(B25) for 4x4 MMO, B4(B66) for 4x4 MIMO
The internal antenna on the MG41 are enclosed inside for a sleek look while maintaining excellent performance. When in use the internal antenna has a bias towards the front face. The dipole shape of coverage the antennas generally excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. A benefit of the internal antenna is the smaller footprint where it will be mounted. Internally, the MG41 has 2 main and 2 diversity antennas.
Specifications
| Category | Specifications |
| Electrical |
Antenna Type Planar Inverted F Antenna (PIFA) |
Main 0 Antenna Frequency Range
Peak Gain (per range)
Polarization Linear, vertical |
Main 1 Antenna Frequency Range
Div 0 Antenna Frequency Range
Div 1 Antenna Frequency Range
| Physical and Environmental |
MG41 Dimensions 168 x 168 x 35mm MG41 Operating Temperature -30°C to 50°C (-22°F to 122°F) Material of Radiator Sheet metal |
| Regulatory | Certified for use in the MG41 |
Radiation Patterns
Main 0 Antenna
Main 1 Antenna
Div 0 Antenna
Div 1 Antenna
