MG51 Internal Antenna Datasheet
MG51 also has a GPS antenna but the GPS functionality is not supported yet.
The internal antenna on the MG51 are enclosed inside for a sleek look while maintaining excellent performance. When in use the internal antenna has a bias towards the front face. The dipole shape of coverage the antennas generally excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. A benefit of the internal antenna is the smaller footprint where it will be mounted. Internally, the MG51 has 2 main and 2 diversity antennas.
Specifications
| Category | Specifications |
| Electrical |
Antenna Type Planar Inverted F Antenna (PIFA) |
Main 0 Antenna Frequency Range
Peak Gain (per range)
Polarization Linear, vertical |
Main 1 Antenna Frequency Range
Div 0 Antenna Frequency Range
Div 1 Antenna Frequency Range
| Physical and Environmental |
MG51 Dimensions 173 x 173 x 36.5mm MG51 Operating Temperature -40°C to 50°C (-40°F to 122°F) Material of Radiator Sheet metal |
| Regulatory | Certified for use in the MG51 |
Radiation Patterns
Div 0 Antenna
Main 0 Antenna
Div 1 Antenna
Main 1 Antenna
