MA-MNT-ANT-1 Installation Guide
Overview
The MA-MNT-ANT-1 is a standard-length mounting arm designed for the MA-ANT-3-E* and MA-ANT-3-F* wide patch and narrow patch antennas.
Package Contents
The MA-MNT-ANT-1 is designed with an articulating arm that allows for mounting the MA-ANT-3-E* and MA-ANT-3-F* patch antennas to wall and ceiling surfaces. The mount comes with 5° mounting marks for precise coverage angles.
Installation
