CW9172H Datasheet
High-Performance Wi-Fi 7 Wireless
The Cisco® Wireless 9172 Series Wi-Fi 7 access points provide a seamless entry into next-generation wireless networking, delivering reliable, high-performance connectivity for environments like boutique hotels, student housing, retail stores, healthcare clinics, remote work hubs, and distributed business locations such as satellite offices, regional branches, and logistics hubs. With a compact, energy-efficient design and flexible management options, the 9172 Series helps ensure strong, future-ready connectivity without compromising affordability.
The Cisco Wireless 9172H is a tri-band, tri-radio, 2x2:2, Wi-Fi 7 wall plate access point with wired access ports, an integrated Bluetooth Low Energy (BLE) radio and scanning radio.
With tri-radio functionality across 2.4-GHz, 5-GHz, and 6-GHz bands, the 9172H access point provides reliable, high-speed connectivity (up to 9000 Mbps frame rate) for spaces with low to moderate device density. Flexible deployment options—cloud, on-premises, or hybrid—allow seamless integration into existing networks.
Cisco Meraki Cloud Management
Pairing the Cisco Wireless 9172 Series Access Points with the Meraki cloud platform gives organizations a unified IT experience for network monitoring and management. The Meraki dashboard provides an intuitive and interactive web interface connecting your network to the industry’s leading cloud IT platform.
Through the dashboard, Meraki provides sophisticated and scalable tools to automate network optimization, deploy policy and segmentation configurations across thousands of sites and devices, and manage a full-stack network from SD-WAN to Access to IoT technologies. The platform supports over 3.5 million active networks around the world.
Working together, the Cisco Wireless 9172 Series and Cisco Meraki offer such features as:
Cisco Spaces
Cisco Identity Services Engine
Wireless AIOps innovations
Meraki Vision, smart cameras, and sensors for network closet monitoring
Cisco Catalyst Center and Catalyst 9800 WLC support
Cisco Wireless 9172 Series Access Points can also be paired with Catalyst 9800 WLC and Cisco Catalyst Center to understand your network with real-time analytics, quickly detect and contain security threats, and easily provide network-wide consistency through automation and virtualization.
Working together, the Cisco Wireless 9172 Series and Cisco Catalyst Center offer such features as:
Cisco Spaces
Cisco Catalyst Center Analytics and Assurance along with Intelligence Capture (iCAP)
For information about Cisco Catalyst Center, refer to the Cisco Networking Solution Overview.
High-Performance 802.11be compatible wireless
The CW9172H is a cloud-managed 2x2:2 802.11be compatible access point that raises the bar for wireless performance and efficiency. Designed for next-generation deployments in offices, schools, hotels, hospitals, the CW9172H offers high throughput, enterprise-grade security, and simple management.
The CW9172H provides a maximum of 9 Gbps* aggregate frame rate with concurrent 2.4 GHz, 5 GHz, and 6 GHz radios. A dedicated fourth radio provides real-time WIDS/WIPS with automated RF optimization, and a fifth integrated IoT radio delivers Bluetooth scanning and beaconing.
With the combination of cloud management, high-performance hardware, multiple radios, and advanced software features, the CW9172H makes an outstanding platform for the most demanding of uses—including high-density deployments and bandwidth or performance-intensive applications like voice (Cisco WebEx) and high-definition video.
CW9172 and Meraki cloud management
Management of the CW9172H is through Dashboard with an intuitive browser-based interface that enables rapid deployment without time-consuming deployment complexity and time-consuming staging process. Since the CW9172H is self-configuring and managed over the web, it can be deployed at a remote location in a matter of minutes, even without on-site IT staff.
24x7 monitoring via the Meraki cloud delivers real-time alerts if the network encounters problems. Remote diagnostic tools enable immediate troubleshooting over the web so that distributed networks can be managed with a minimum of hassle.
The CW9172H’s firmware is automatically kept up to date via the cloud. New features, bug fixes, and enhancements are delivered seamlessly over the web. This means no manual software updates to download or missing security patches to worry about.
Product Highlights
Features
Tri–radio aggregate frame rate of up to 9 Gbps*
A 6 GHz 2x2:2, 5 GHz 2x2:2 and 2.4 GHz 2x2:2 radio offer a combined tri–radio aggregate frame rate of 9 Gbps*, with up to 5764 Mbps in 6 GHz band, 2882 Mbps in 5 GHz band and 344 Mbps in 2.4 GHz band. Technologies like transmit beamforming and enhanced receive sensitivity allow the CW9172H to support a higher client density than typical enterprise-class access points, resulting in better performance for more clients from each AP.
* Refers to maximum over-the-air data frame rate capability of the radio chipset, and may exceed data rates allowed by IEEE 802.11be operation.
Multi Link Operation (MLO)
With support for features of 802.11be, the CW9172H can operate in multiple bands simultaneously to achieve higher throughput and improved SLA. This increases the total network performance and improves the end-user experience.
Multi User Multiple Input Multiple Output (MU-MIMO)
With support for features of 802.11be, the CW9172H offers DL and UL MU-MIMO and OFDMA for more efficient transmission to multiple clients. Especially suited to environments with numerous mobile devices, MU-MIMO and OFDMA enable multiple clients to receive data simultaneously. This increases the total network performance and improves the end-user experience.
Bluetooth Low Energy Beacon and Scanning Radio
An integrated Bluetooth radio provides seamless deployment of BLE Beacon functionality and effortless visibility of Bluetooth devices. The CW9172H enables the next generation of location-aware applications while future-proofing deployments, ensuring it’s ready for any new customer engagement strategies.
Automatic Cloud-Based RF Optimization
The RF data collected by the dedicated fourth radio is continuously fed back to the Meraki cloud. This data is then used to automatically tune the channel selection, transmit power, and client connection settings for optimal performance under even the most challenging RF conditions.
Integrated Enterprise Security and Guest Access
The CW9172H features integrated, easy-to-use security technologies to provide secure connectivity for employees and guests alike. Advanced security features such as AES hardware-based encryption and Enterprise authentication with 802.1X and Active Directory integration provide wired-like security while still being easy to configure. CW9172H will also support 192-bit encryption along with WPA3 support for added security of the wireless network. One-click guest isolation provides secure, Internet-only access for visitors. PCI compliance reports check network settings against PCI requirements to simplify secure retail deployments.
Dedicated Scanning Radio Delivers 24x7 Meraki Air Marshal and RF analytics
The CW9172H’s dedicated tri-band scanning and security radio continually assesses the environment, characterizing RF interference and containing (in 2.4GHz and 5GHz only, since 6GHz mandates PMF) wireless threats like rogue access points. There’s no need to choose between wireless security (Air Marshal), advanced RF analysis, and serving client data - a dedicated fourth radio means that all functions occur in real-time, without any impact on client traffic or AP throughput.
Enterprise Mobility Management (EMM) & Mobile Device Management (MDM) Integration
Meraki Systems Manager natively integrates with the CW917H to offer automatic, context-aware security. Meraki Systems Manager’s self-service enrollment helps to rapidly deploy MDM without installing additional equipment, and then dynamically tie firewall and traffic shaping policies to client posture.
Application-Aware Traffic Shaping
The CW9172H includes an integrated layer 7 packet inspection, classification, and control engine, enabling the configuration of QoS policies based on traffic type, helping to prioritize mission-critical applications while setting limits on recreational traffic like peer-to-peer and video streaming. Policies can be implemented per network, per SSID, per user group, or per individual user for maximum flexibility and control.
Voice and Video Optimizations
Industry-standard QoS features are built-in and easy to configure. Wireless Multimedia (WMM) access categories, 802.1p, and DSCP standards support, all ensure important applications get prioritized correctly, not only on the CW9172H but on other devices in the network. Unscheduled Automatic Power Save Delivery (U-APSD) and the Target Wait Time feature in 802.11ax clients ensure minimal battery drain on wireless VoIP phones.
Self-configuring, Self-Maintaining, Always Up-to-Date
When plugged in, the CW9172H automatically connects to the Meraki cloud, downloads its configuration, and joins the appropriate network. Administrators can schedule automatic firmware upgrades for their dashboard network seamlessly. This ensures the network is kept up-to-date with bug fixes, security updates, and new features.
Meraki Health
CW9172H will support all the latest and greatest analytics to provide machine learning-based anomaly detection, server root cause analysis, wireless client scoring based on performance and connectivity metrics and network benchmarking for networks of similar size and vertical. Along with these features, CW9172H will provide advanced location analytics via API and graphs in the dashboard to provide a clear picture of client density and their movement across the floor plan.
Choice of Mode
Cisco Wireless 9172H Series Access Points can be managed either on-premises with Catalyst 9800 Wireless Lan Controllers (WLC) or cloud-managed through the Meraki dashboard. Customers have the flexibility to deploy these access points in one mode and migrate to the other mode in the future.
Specifications
Category |
Specifications |
Radios |
Antenna |
802.11ax, 802.11ac Wave 2 and 802.11n Capabilities |
Note: *40MHz and 80 MHz channels are supported only in the 5GHz and 6 GHz band. 802.11ax supported only in 6 GHz band. **802.11ax capability |
802.11be Capabilities |
Power |
Note: Actual power consumption may vary depending on the AP usage. |
Interfaces |
Mounting |
Physical Security |
Environment |
Reliability |
Physical Dimensions |
Security |
Quality of Service |
Mobility |
Analytics |
LED Indicators |
Regulatory |
Warranty |
Ordering Information |
Power cord - MA-PWR-CORD-XX (XX Country Code) should be ordered separately for the Ethernet injector
Compliance and Standards
Category |
Standard |
IEEE Standards |
Certifications |
● Wi-Fi Alliance: Wi-Fi 7 (R1), Wi-Fi 6 (R2), Wi-Fi 6E, WPA3-R3, WPA3-Suite B, Enhanced Open Security ● Bluetooth SIG: Bluetooth Low Energy |
Safety Approvals |
Radio Approvals |
For additional country-specific regulatory information, please contact Meraki sales
EMI Approvals (Class B) |
Exposure Approvals |
Context and Comparisons
802.11be, 802.11ax, 802.11ac Wave 2 and 802.11n Capabilities
MR36H |
MR44 |
CW9162 |
CW9172H |
DL-OFDMA, UL-OFDMA, TWT support**, BSS coloring** |
DL-OFDMA, UL-OFDMA, TWT support**, BSS coloring** MLO |
2.4 GHz: 2 x 2 multiple input, multiple output (MIMO) with two spatial streams 5 GHz: 2x2 multiple input, multiple output (MIMO) with two spatial streams |
2:4GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams 5 GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams |
2.4 GHz: 2x2 multiple input, multiple output (MIMO) with two spatial streams 5 GHz: 2x2 multiple input, multiple output (MIMO) with two spatial streams 6 GHz: 2x2 multiple input, multiple output (MIMO) with two spatial streams |
Maximal ratio combining (MRC) & beamforming |
SU-MIMO, UL MU-MIMO and DL MU-MIMO support |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40* and 80 MHz channels (802.11ax) |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40*, 80MHz and 160MHz channels (802.11ax) |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40*, 80MHz and 160MHz channels (802.11ax) 320MHz channels (802.11be) |
Note: *40MHz channels are supported only in 5 & 6 GHz bands. |
Up to 1024-QAM on both 2.4 GHz & 5 GHz bands |
Up to 1024-QAM on all three - 2.4 GHz, 5 GHz and 6 GHz bands |
Up to 4096-QAM on all three - 2.4 GHz, 5 GHz and 6 GHz bands |
Packet aggregation |
Power
MR36H |
MR44 |
CW9162 |
CW9172H |
Power over Ethernet: 37 - 57 V (802.af compliant) |
Power over Ethernet: 42.5 - 57 V (802.3at compliant) |
Power over Ethernet: 42.5 - 57 V (802.3at and 802.3bt compliant) |
Alternative: Only PoE |
Alternative: 12 V DC input |
Power consumption: 15W max (802.3af) |
Power consumption: 30W max (802.3at required) |
Power consumption: 30.0W max (802.3 at required) |
Power consumption: 32W max with 802.3af Class 3 (15.4W) PoE Out on the LAN Port. 25.5W max with 802.3af Class 2 (7W) PoE Out on the LAN Port.** |
Power over Ethernet injector sold separately |
Power over Ethernet injector and DC adapter sold separately |
** features can be enabled via future firmware updates
Interfaces
MR36H |
MR44 |
CW9162I |
CW9172H |
1x 100/1000/2.5G BASE-T Ethernet (RJ45) |
No DC Power Plug |
1x DC power connector (5.5 mm x 2.5 mm, center positive) |
1x DC power connector (8 mm, center positive) |
No DC Power Plug |
1x Gigabit Ethernet (RJ45) with 802.3af Power over Ethernet output 2x Gigabit Ethernet (RJ45) outputs 1x Passthrough port (non-managed). |
Physical Dimensions
MR36 |
MR44 |
CW9162I |
CW9172H |
15.5 cm x 11 cm x 2.3 cm (6.1" x 4.33"x 0.9") not including desk mount feet or mount plate |
12.05" × 5.06" × 1.74" (30.6 cm × 12.84 cm × 4.43 cm), not including desk mount feet or mount plate |
7.8" x 7.8" x 1.7" 200 x 200 x 45.45 mm) , not including mount plate |
13 cm x 18 cm x 2.6 cm (5.1” x 7.0” x 1.0 in. , not including mount plate |
Weight: 17.35 oz (492 g) |
Weight: 28.22 oz (800 g) |
Weight: 35.27 oz (1 kg) |
Weight: 1.16lbs (572g) |
Signal Coverage Pattern
Client Serving Radios
2.4 GHz Radio
5 GHz Radio
6 GHz Radio
Scanning Radio
IoT/BLE 2.4 GHz Radio
