CW9178I Datasheet
Ultra High-Performance Wi-Fi 7 Wireless
Cisco Wireless 9178I Series Wi-Fi 7 access points are ideal for high-density environments and critical applications. These access points also allow choosing between on-premises and cloud management. Cisco Wireless' Wi-Fi 7 access points can leverage Wi-Fi 7 to support video streaming, augmented reality (AR), and virtual reality (VR) applications. These access points offer real-time insights and personalized user experiences.
The Cisco Wireless 9178I Series Wi-Fi 7 access points enable operation in the 2.4, 5 and 6GHz bands for higher throughput and capacity. These access points provide four 4x4 radios and IoT radios. The Cisco Wireless 9178I Series offers an Omni-directional antenna model, the CW9178I, suitable for most enterprise deployments
Operational management is flexible because the network management can be changed anytime. If a network with Cisco Wireless 9178I Series access points was originally an on-premises deployment, it can be changed to cloud-based management without the need to purchase and redistribute additional hardware
Cisco Meraki Cloud Management
Pairing Cisco Wireless 9178I Series access points with the Meraki cloud platform provides a unified IT experience for network monitoring and management. The Meraki dashboard has an intuitive and interactive web interface.
Through the dashboard, Meraki provides sophisticated and scalable tools to automate network optimization, deploy policy and segmentation configurations across thousands of sites and devices. It also can manage a full-stack network with SD-WAN, Access, and IoT technologies. The platform supports over 3.5 million active networks around the world.
The Cisco Wireless 9178I and dashboard allow for the integration of features such as:
Cisco Spaces
Cisco Identity Services Engine
Meraki Health intelligent optimization and assurance
Meraki Vision, smart cameras, and sensors for network closet monitoring
Cisco Catalyst Center and Catalyst 9800 WLC support
The Cisco Wireless 9178I access points can also be managed with Catalyst 9800 WLC and Cisco Catalyst Center. Cisco Catalyst Center allows you to understand your network with real-time analytics, quickly detect and contain security threats, and easily provide network-wide consistency through automation and virtualization.
Working together, the CW9178I Series and Cisco Catalyst Center offer such features as:
Cisco Spaces
Cisco Catalyst Center Analytics and Assurance along with Intelligence Capture (iCAP)
For information about Cisco Catalyst Center, refer to the Cisco Networking Solution Overview.
High-Performance 802.11be Compatible Wireless
The CW9178I is a cloud-managed tri-band 4x4:4 802.11be compatible access point that emphasizes wireless performance and efficiency. Designed for next-generation deployments in offices, schools, hospitals, retail shops, and hotels, the CW9178I offers high throughput, enterprise-grade security, and simple management.
The CW9178I provides a maximum of 24 Gbps aggregate frame rate with concurrent 2.4 GHz, 5 GHz, and 6 GHz radios. A dedicated fourth radio provides real-time WIDS/WIPS with automated RF optimization, and a fifth integrated IoT radio delivers Bluetooth scanning and beaconing.
The Cisco Wireless CW9178I supports a software-defined flex radio which can be operated in a Tri-Radio or Quad-Radio. The option to operate in Quad-Radio provides dual 5 GHz configuration that helps in high-density deployments.
With the combination of cloud management, high-performance hardware, multiple radios, and advanced software features, the CW9178I handles the most demanding of uses, including high-density deployments and performance-intensive applications like voice and high-definition video.
CW9178I and Meraki Cloud Management
Management of the Cisco Wireless 9178I is through the dashboard with an intuitive browser-based interface that enables rapid deployment without time-consuming deployment complexity and time-consuming staging process. Since the CW9178I is self-configuring and managed over the web, it can be deployed at a remote location in a matter of minutes, even without on-site IT staff.
24x7 monitoring via the Meraki cloud delivers real-time alerts if the network encounters problems. Remote diagnostic tools enable immediate troubleshooting over the web so that distributed networks can be managed with minimal hassle.
The Cisco Wireless 9178I firmware is automatically kept up to date via the cloud. New features, bug fixes, and enhancements are delivered seamlessly over the web. This means no manual software updates to download or missing security patches to worry about.
Product Highlights
Features
- Quad–radio Aggregate Frame Rate of up to 24 Gbps
A 6 GHz 4x4:4, Dual 5 GHz 4x4:4 and 2.4 GHz 4x4:4 radio offer a combined Quad radio aggregate frame rate of 24 Gbps*, with up to 11,520 Mbps in 6GHz band, 5,700 Mbps 5 GHz band (each Radio) and, 688 Mbps in the 2.4 GHz band. Technologies like transmit beamforming and enhanced receive sensitivity allow the CW9178I to support a higher client density than typical enterprise-class access points, resulting in better performance for more clients, from each AP.
* Refers to maximum over-the-air data frame rate capability of the radio chipset, and may exceed data rates allowed by IEEE 802.11be operation.
- Multi Link Operation (MLO)
With support for features of 802.11be, the CW9178I can operate in multiple bands simultaneously to achieve higher throughput and reduced latency. This improves network performance and the end-user experience.
- Multi User Multiple Input Multiple Output (MU-MIMO)
With support for features of 802.11ax, the CW9178I offers DL/UL MU-MIMO and OFDMA for more efficient transmission to multiple clients. Suited for environments with numerous mobile devices, MU-MIMO and OFDMA enable multiple clients to receive data simultaneously.
- Bluetooth Low Energy Beacon and Scanning Radio
An integrated Bluetooth radio provides seamless deployment of BLE Beacon functionality and effortless visibility of Bluetooth devices. The CW9178I enables the next generation of location-aware applications while future-proofing deployments.
- Automatic Cloud-Based RF Optimization
The RF data collected by the dedicated fourth radio is continuously fed back to the Meraki cloud. This data is then used to automatically tune the channel selection, transmit power, and client connection settings for optimal performance under even the most challenging RF conditions.
- Integrated Enterprise Security and Guest Access
The CW9178I features integrated, easy-to-use technologies to provide secure connectivity for employees and guests alike. Advanced security features such as AES hardware-based encryption, Enterprise authentication with 802.1X, and Active Directory integration provide wired-like security while still being easy to configure. CW9178I also supports WPA3 192-bit encryption for added wireless network security. One-click guest isolation provides secure, Internet-only access for visitors. PCI compliance reports check network settings against PCI requirements to simplify secure retail deployments.
- Dedicated Scanning Radio Delivers 24x7 Air Marshal and RF Analytics
The CW9178I’s dedicated tri-band scanning and security radio continually assesses the environment, characterizing RF interference and containing (in 2.4GHz and 5GHz only, since 6GHz mandates PMF) wireless threats like rogue access points. There’s no need to choose between wireless security (AirMarshal), advanced RF analysis, and serving client data - a dedicated fourth radio means that all functions occur in real-time, without any impact on client traffic or AP throughput.
- Enterprise Mobility Management (EMM) & Mobile Device Management (MDM) Integration
Meraki Systems Manager natively integrates with the CW9178I to offer automatic, context-aware security. Meraki Systems Manager’s self-service enrollment helps to rapidly deploy MDM without installing additional equipment, and then dynamically tie firewall and traffic shaping policies to client posture.
- Application-Aware Traffic Shaping
The CW9178I includes an integrated layer 7 packet inspection, classification, and control engine, enabling the configuration of QoS policies based on traffic type, helping to prioritize mission-critical applications while setting limits on recreational traffic like peer-to-peer and video streaming. Policies can be implemented per network, per SSID, per user group, or individual user for maximum flexibility and control.
- Voice and Video Optimizations
Industry-standard QoS features are built-in and easy to configure. Wireless Multimedia (WMM) access categories, 802.1p, and DSCP standards support, all ensure important applications get prioritized correctly, not only on the CW9178I, but on other devices in the network. Unscheduled Automatic Power Save Delivery (U-APSD) and new Target Wait Time feature in 802.11ax clients ensure minimal battery drain on wireless VoIP phones.
- Self-configuring, Self-Maintaining, Always Up-to-Date
When plugged in, the CW9178I automatically connects to the Meraki cloud, downloads its configuration, and joins the appropriate network. Administrators can schedule firmware upgrades for their dashboard network seamlessly. This ensures the network is kept up-to-date with bug fixes, security updates, and new features.
- Meraki Health
CW9178I supports analytics to provide machine learning-based anomaly detection, server root cause analysis, wireless client scoring based on performance and connectivity metrics and network benchmarking for networks of similar size and vertical. Additionally, the CW9178I provides advanced location analytics via API and graphs in the dashboard to provide a clear picture of client density and their movement across the floor plan.
- Choice of Mode
Cisco Wireless 9178I Series access points can be managed either on-premises with Catalyst 9800 Wireless Lan Controllers (WLC) or cloud-managed through the dashboard. Customers have the flexibility to deploy these access points in one mode and migrate to the other mode in the future.
Specifications
Category |
Specifications |
Radios |
Due to the 6 GHz band requiring PMF some Air Marshal functions may not be effective
GPS |
Built-in GPS/ GNSS |
Antenna |
802.11ax, 802.11ac Wave 2 and 802.11n Capabilities |
Note: 40MHz channels are supported only in the 5GHz band.
802.11be Capabilities |
Power |
Note: Actual power consumption may vary depending on access point usage. It is recommended that you ensure that Link Layer Discovery Protocol (LLDP)/Cisco Discovery Protocol is enabled to allow proper power negotiation.
Power cord - MA-PWR-CORD-XX (XX Country Code) should be ordered separately for the Ethernet injector |
Interfaces |
Mounting |
Physical Security |
Environment |
Reliability |
Physical Dimensions |
Security |
Quality of Service |
Mobility |
Analytics |
LED Indicators |
Regulatory |
Warranty |
Ordering Information |
CW9178I Power Negotiation and Features
Power Source |
2.4-GHz radio |
5-GHz radio |
6-GHz radio |
Link speed |
USB |
Max PoE power consumption |
802.3bt (Class 6) (UPOE) |
4x4 |
4x4(LB) + 4x4(HB) |
4x4 |
2x 10G |
Y (9W) |
47W |
802.3at (PoE+) (Quad Radio mode) |
2x2 |
2x2 (LB) + 2x2 (HB) |
2x2 |
2x 2.5 G |
N |
25.5W |
802.3at (POE+) |
2x2 |
4x4 (FB) |
2x2 |
2x 2.5 G |
N |
25.5W |
802.3af (PoE) |
1x1G |
N |
13.95W |
Note: With 802.3at, the AP will function as 6 spatial stream with 2x:2 on 2.4/5/6 GHz radios with 1 G speed. The restriction will be removed in the upcoming software release.
Compliance and Standards
Category |
Standard |
IEEE Standards |
Certifications |
Safety Approvals |
Radio Approvals |
For additional country-specific regulatory information, please contact Meraki sales
EMI Approvals (Class B) |
Exposure Approvals |
Context and Comparisons
802.11be, 802.11ax, 802.11ac Wave 2 and 802.11n, 802.11be Capabilities
MR44 |
MR46 |
MR56 |
CW9166I |
CW9178I |
DL-OFDMA, UL-OFDMA, TWT support**, BSS coloring** |
DL-OFDMA, UL-OFDMA, TWT support**, BSS coloring** MLO |
2.4 GHz: 2 x 2 multiple input, multiple output (MIMO) with two spatial streams 5 GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams |
2:4GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams 5 GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams |
2.4 GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams 5 GHz: 8 x 8 multiple input, multiple output (MIMO) with eight spatial streams |
2.4 GHz 4 x 4 multiple input, multiple output (MIMO) with four spatial streams 5 GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams 6 GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams |
Maximal ratio combining (MRC) & beamforming |
SU-MIMO, UL MU-MIMO and DL MU-MIMO support |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40* and 80 MHz channels (802.11ax) |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40*, 80MHz and 160MHz channels (802.11ax) |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40*, 80MHz and 160MHz channels (802.11ax) 320MHz channels (802.11be) |
Up to 1024-QAM on both 2.4 GHz & 5 GHz bands |
Up to 1024-QAM on all three - 2.4 GHz, 5 GHz and 6 GHz bands |
Up to 4096-QAM on all three - 2.4 GHz, 5 GHz and 6 GHz bands |
Packet aggregation |
Power
MR44 |
MR46 |
MR56 |
CW9166I |
CW9178I |
Power over Ethernet: 42.5 - 57 V (802.3at) or 37 - 57 V (802.3af) - low power mode ** |
Power over Ethernet: 42.5 - 57 V (802.3at compliant) |
Power over Ethernet: 42.5 - 57 V (802.3at and 802.3bt compliant) |
Alternative: 12 V DC input |
Alternative: 54 V DC input |
Alternative: Power Injectors |
Power consumption: 30W max (802.3at) or 15W max (802.3af) - low power mode ** |
Power consumption: 30W max (802.3at required) |
Power consumption: 30.5W max with USB support and 25W max without USB support |
Power consumption: 47W max with USB support and 38W max without USB support |
Power over Ethernet injector and DC adapter sold separately |
Power over Ethernet injector sold separately |
Interfaces
MR44 |
MR46 |
MR56 |
CW9166I |
CW9178I |
1x 100/1000/2.5G BASE-T Ethernet (RJ45) |
1x 100/1000/2.5G/5G BASE-T Ethernet (RJ45) |
1x 1000/2.5G/5G BASE-T Ethernet (RJ45) |
2x 1000/2.5G/5/10G BASE-T Ethernet (RJ45) |
1x DC power connector (5.5 mm x 2.5 mm, center positive) |
1x DC power connector (8 mm, center positive) |
Physical Dimensions
MR44 |
MR46 |
MR56 |
CW9166I |
CW9178I |
12.05" × 5.06" × 1.74" (306.0 × 12.8.4 × 44.3 mm), not including mount plate |
12.83” x 5.54” x 1.76” (326.0 x 140.79 x 44.7 mm), not including mount plate |
9.5 x 9.5 x 2.2 in. (241.3 x 241.3 x 56.9 mm), not including mount plate |
9.9 x 9.9 x 2.0 in. (250 x 250 x 51 mm), not including mount plate |
Weight: 26.07 oz (0.739 kg) |
Weight: 1.76lbs (0.800 kg) |
Weight: 2.2lbs (1 kg) |
Weight: 3.54lbs (1.60kg) |
Weight: 4.1lbs (1.87kg) |
Signal Coverage Pattern
Client Serving Radios
CW9178I 6 GHz Radio
CW9178I 5 GHz Radio Slot 1
CW9178I 5 GHz Radio Slot 2
CW9178I – 2.4 GHz Radio Antenna Pattern
CW9178I AI/ML-Driven Scan Radio Antenna Pattern
2.4 GHz Radio |
5 GHz Radio |
6 GHz Radio |
CW9178I IoT Radio Antenna Pattern
CW 9178I GNSS Antenna Pattern
