Cisco Meraki
Cisco Meraki MR57 SES ESL Specifications
Overview
The Cisco Meraki MR57 is a tri-band 802.11ax-compatible access point with separate radios dedicated to security, RF management, and Bluetooth® coupled with dual Ethernet ports and a USB port for added connectivity options.
Please refer to the MR57 datasheet for detailed wireless-specific information.
MR57 supports SES-imagotag Electronic Shelf Labels (ESL) native integration. Please refer to our documentation for more information.
Note: All specified values are subject to change by SES-imagotag
MR Model
MR57
Integration Variant VUSION Gate N​
Product code (Vusion Cloud SKU) CE: 11663 | FCC/IC: 11663​
V:IoT Radio 2.4 GHz
V:IoT Radio Protocol Proprietary
V:IoT Radio Antenna Integrated
V:IoT Radio Channel Auto-Selection Yes
V:IoT Radio Encryption 128-bit Advanced Encryption Standard (AES) with secure key exchange
V:IoT Transmission Range Up to 25 meters in open-field deployments (about 1950 m² or 21 000 sq ft area)
Coexistence Feature Support (V:IoT radio + Wi-Fi) Smart Coexistence
Number of Labels Supported Up to 10,000 labels per access point​
Supported SES solution VUSION Cloud
Connection Mode Token-Based​
VUSION Cloud Specifications
Cloud Service Authentication
X.509 certificates​
Access Point Authentication Claim ID and JWT token authentication​
Connection Fully encrypted with TLS​
Compliance ISO 27001, PCI-DSS 3.2, CIS 1.1.0, SOC TSP, GDPR
  • Was this article helpful?
