MA-INJ-6 Meraki Multigigabit 802.3bt Power over Ethernet Injector
MA-INJ-6 Reliable, standards-compliant power for your Meraki devices
MA-INJ-6 provides increased flexibility, reduced installation time and cost. One of the main constraints when designing your wireless network is the availability of power. Running power cabling is also a primary cost driver of wireless installations. The Meraki Multigigabit PoE injector allows delivery of both data and power to a Meraki access point over a single Ethernet cable, allowing deployment of devices exactly where they are needed to provide the best wireless coverage at a much lower installation cost.
The Meraki Multigigabit 802.3bt PoE Injector MA-INJ-6 provides fully-compliant 802.3bt detection, with disconnect, short-circuit and overload protection. This ensures that only 802.3bt, 802.3at and 802.3af devices receive power and non-compliant devices are not accidentally damaged.
Using this injector, it is possible to power the latest generation of Wifi-6, 6E and future WiFi-7 devices that require 802.3bt power delivered via 10G Multigigabit interfaces, as well as providing backward compatibility with legacy 802.11n devices with traditional 802.3af power. Regardless of the deployment scenario, powering Meraki devices with Multigigabit 802.3bt Power over Ethernet is a flexible and low-cost method to simplify the installation process while ensuring that network design is not compromised by power availability limitations.
Product Highlights
• Reduces cost and simplifies installations by eliminating the need to provide separate power line
• Increases installation flexibility by powering devices from up to 100 meters away
• Fully IEEE 802.3bt standard compliant
• Supports 10/100/1000BASE-T and 10 Gbps Multigigabit Ethernet
• Power, load detection and fault diagnostics LEDs
Power
Input voltage: 100 to 240 VAC
Maximal input current: 2.0A(RMS) 90VAC @ Max Load 1.2A(RMS) 240VAC @ Max Load
AC input frequency: 50-60 Hz
Output voltage: 55 VDC
Maximum output power: 60W
Powered device can be up to 100m away from power injector * Depending on the quality of cable and external factors, this could be reduced
Data
Compatible with Ethernet 10/100/1000/2500/5000/10000 Multigigabit Ethernet (10Gb)
Environmental
Operating temperature: -10 to 60 °C (14 to 140°F)
Storage temperature: -20 to 65 °C (-4 to 149°F)
Operating humidity: Maximum 90%
Additional features
Short-circuit protection
Physical dimensions
163.25 mm (6.4") * x 65 mm (2.5") x 40 mm (1.5")
* 163.25 mm (6.4") includes the mounting ears on opposite corners of the injector
Weight: 312 g (11 oz).
Mounting
Mounts to walls (anchors and screws not included)
Compatibility
Complies with IEEE 802.3bt standard Backward compatibility with 802.3af and 802.3at devices
LED indicators
Input power
Detected/connected to valid 802.3bt load
Power and load detection diagnostic LEDs
Solid Green: Detection/Connection Valid & Output "ON"
Blink Amber (short, slow): Waiting for a Valid Connection/Detection
Blink Amber (long, fast): Fault Condition
Blink Amber & Green: Detection Invalid
Regulatory
FCC Part 15 Class B
EN55022 Class B
EN55024, EN55032
CE, VCCI
UL 60950-1, UL 62368
Warranty
1 year hardware warranty included
Ordering information
MA-INJ-6 Meraki Multigigabit 802.3bt Power over Ethernet Injector world-wide unit
SKU for the power injector : MA-INJ-6
SKUs for the power cords (1.8m (6 feet) long):
MA-PWR-CORD-US (USA plug)
MA-PWR-CORD-UK (United Kingdom plug)
MA-PWR-CORD-CN (China plug)
MA-PWR-CORD-IN (India plug)
MA-PWR-CORD-EU (EU plug)
MA-PWR-CORD-BR (Brazil plug)
MA-PWR-CORD-AR (Argentina plug)
MA-PWR-CORD-AU (Australia plug)
MA-PWR-CORD-JP (Japan plug, SKU no longer active, same as US cord)
MA-PWR-CORD-TW (Taiwan plug)
Note: power cords ordered separately
